Ls7
Old Dec 21, 2005 | 08:09 PM
Blktie8's Avatar
Default Ls7
Anybody know what's the differences between the LS7 and the LS2 Beside the (Bore)
Will the ls7 be a similar install with a stroker kit as the LS2
I am feeling there is issues with oil pump and timing chain on the ls7
Are all the bolt holes the same .
Will it be as simple as an Ls2 conversion in a C5
John Sr.
Old Dec 21, 2005 | 08:29 PM
Wet 1's Avatar
LS7 = 4.125", LS2 = 4.00" bore.
Bolt holes are the same. The issures are the reluctor wheel and oil system depending on what you want to do.
John, you might want to do some reading in this section regarding the conversion. All your questions have been answered many times over.
Old Dec 21, 2005 | 09:29 PM
Bill Reid's Avatar
Originally Posted by Blktie8
Anybody know what's the differences between the LS7 and the LS2 (Bore)
John Sr.
John,
There are several guys, including myself, involved with LS7 crate motor projects going into vehicles other than a C6. Potential issues have been identified and workarounds are in progress. Depending on what your intentions are... buying a crate LS7 or waiting for the bare block to become available... and what vehicle you plan on using as a platform will determine degree of mods needed.
Bill
Old Dec 22, 2005 | 03:28 AM
Blktie8's Avatar
I really have read most everything on the ls2-ls7
The bare block comparison ,is the question
I haven't seen any one build a ls7 ,block yet with pre 05 rotating assembly
I read of one that changed the reluctor wheel .
It is not clear yet if the blocks will be the same ,understanding the bore size difference
