Gauging Interest in L-92 Sheet Metal Intake
Don't mistake my ignorance for being rude but I'm not very versed on sheet metal intakes. Is the fact that its really just straight tubes to the intake ports mean you can take a good guess at its performance or RPM range might be? I'm interested, but getting in on this GB without knowing anything about what it will do is a bit hard for me.
Thx in advance.
Thx in advance.
Rock - tell you what give us a call if you want more info on the intake I just to want to fill up pages and pages about Sheet Metal Intakes, we would more then happy to talk to you about it.
Originally Posted by Dune-LS1
A 90mm T/B will be fine for 402/427 CID engine... I don't think you will see a benefit using a larger unit until you go above that CID. JMHO.
And with a set of LS7 or ETP 265/41 heads flowing near 390-400cfm, there ain't know way a 90mm TB can keep up.
What about us fly by wire throttle body guys, what would my options be for the throttle body besides a ported LS2 throttle body which i already have. And how many do we have in on this GP so far.
Originally Posted by jjw3477
Also another question, what size are the chambers on these things and what if i needed them milled down to say 62cc could it be done without affecting the flow numbers.
Nate
We are considering leaving the TB's out of the Kit if most people want to pick random size TB's then we will need you to tell us what size and style and we could make the intake to fit.
If we left the TB's out then the price would be around $1250.
But we need a total of 10 orders at least or we will not make this kit.
Here is what we have so far: If you would like to do this setup then add your name to the list please
1.jjw3477
2.Nate
3.Hellbents10
4.
5.
6.
7.
8.
9.
10.
1.jjw3477
2.Nate
3.Hellbents10
4.
5.
6.
7.
8.
9.
10.
#34
boy that might rule me out also i need to get to at least 62cc so i can get my compression to at least 11.5:1
Nate
#35
1.jjw3477
2.Nate
3.Hellbents10
4.
5.
6.
7.
8.
9.
10.
1.jjw3477
2.Nate
3.Hellbents10
4.
5.
6.
7.
8.
9.
10.
AND....The only reason I would get one is because the FAST 90/LS7's are quite cheezy and the weak link for big cube engines, therefore I would want to know, FOR SURE, if it's going to outflow them by a LONG WAY, not just a little bit. The Harrop is very expensive, so if yours (with a 105mm TB) flowed like a Harrop I'd certainly buy yours.
#36
Originally Posted by Quickin
I'd love to add myself to the list and send you a GP deposit. But the questions that I have are will it be streetable, will you lose power down low like all the other sheetmetal intakes do and how much more would it cost for a 105mm TB built into mine.
2) A 105 mm tb wont add much if anything in the way of power unless you're building a solid roller 8500 rpm 402, or a 430+ cube motor.
3) A FAST 90mm intake wont work with the LS7 heads. End of story
4) The harrop is 8 54mm throttle bodies. That is a pretty big surface area advantage over the single but I don't even see you needing bigger than a 90mm. However the single will be much cheaper.
5) If you're really worried about having enough air for your motor, just buy the LS7 heads and intake combo and play away. You'll have enough air to carry your motor to 7000 rpm and still make 650 rwhp with enough cubes and big enough cam.
Nate
#38
Thank you Nate you beat me to it. But to add we did make the runners longer on the intake in order to help salvage some of the low end power.
I would use a sheetmetal intake or Harrop with either the LS7 or ETP 265 heads.
#39
Originally Posted by Nate_Taufer
1) A sheet metal intake will always lose power down low at the expense of carrying power higher into the rpm band. It's because they have a shorter runner and is the nature of the beast that is sheet metal intakes.
Nate
Nate
