Got the build sheet for my 427
.. this motor is capable of well over 600rwhp N/A as you have all seen from some recent posts.
). 11.5:1 compression...1 month to go and it will be finished!
Here's the build sheet:
New GM block - Darton Sleeved - Decked - Squared - Line Honed - 4.125 bore
Callies Crank - 4.0 stroke
Callies Rods
Mahle pistons
Mahle Ring Set
Clevite Bearings
ARP main studs, head studs, rod bolts
GM LS-7 Heads
GM LS-7 valves
Harland Sharp Adj Roller Rockers
Custom Spring Set
Titanium Retainers
Custom Comp Cam --- very docile
Comp Lifters, Push Rods
Rollermaster Dual Row timing set
GM gaskets
Cometics Head Gaskets
GM Block Set
Custom Ported Oil Pump
GM LS-7 Intake Manifold
GM Performance Valve Covers
Katech Belt Tensioner
Custom RevXtreme 90mm TB & Fuel Rails
Ron Davis Dual Pass, Dual Row Radiator
Thunder Coil Relocation Kit
LS-2 Water Pump
SLP Crank Underdrive Pulley
GM 85mm MAF
42lb Injectors
This is going to be daily driven. I'd like to take it out to Sebring soon.Bravo... I will take a look at the Evans. There's a little time left.
Just my .02
good luck.
The T56 has upgraded synchros, shift forks, bearings, etc.
It has a SPEC 3 right now, but a SPEC 3+ is planned.
Some other stuff on (or will be on) the car:
Kooks 1-7/8" x 2" stepped LTs to a Corsa Catback.
Racetronix in-tank fuel pump
BMR K-Member
Kirban shifter w/Lou's short stick
KBDDSFCs
Bilstein HDs
BMR LCAs & STB
Granatelli Adj PHB & Lowering springs
Fikse FM5s.. Black anodized centers
VFN "Sunoco" Hood
SS Spoiler
32 & 21 mm swaybars
Strange Dana S60
It's meant to be a fun daily driver. Take it to the strip, Sebring, Saturday night hangouts, car shows, and the grocery store.
