ls2 cylinder head torque sequence
Old Oct 26, 2006 | 09:02 AM
Black93Z28's Avatar
Default ls2 cylinder head torque sequence
is the torque seqence the same from the ls1 to ls2? if so can someone post the diagram. thanks!
Old Oct 26, 2006 | 09:10 AM
fjpelkey2001's Avatar
http://www.ls2.com/forums/showthread...hreadid=416670
Check the helms
Old Oct 26, 2006 | 12:49 PM
strokedls1's Avatar
Same as the ls1 for the torque pattern. The ls2 just uses all long head bolts instead of having shorter ones at the ends. Here is a link. http://www.ls1howto.com/index.php?article=3
Old Oct 26, 2006 | 12:59 PM
speedyss's Avatar
Ls2 uses all short head bolts not long. same pattern tho. 22ft/lb 90* then 50*
