Post Up if you are buying a set of L92 Heads for a 370ci or larger setup.
Old 11-18-2006, 01:19 PM
WizeAss's Avatar
Default Post Up if you are buying a set of L92 Heads for a 370ci or larger setup.
I plan to get a set for a 408......... I have already bought the L76 intake... heads are my next purchase before the prices go up.... I am curious how many are seriously considering these heads.
and does anyone know where you can get aftermarket valves... I know they have a 1.60 valve... but what do ya do about the intake valve??
Old 11-18-2006, 01:24 PM
fast98's Avatar
i bought a set im just waiting on the redesigned gm valves to come in, im expecting them on tuesday
Old 11-18-2006, 04:02 PM
NemeSS's Avatar
me goin with 375 ci 6.0 TT TH400/9 in.
using stock LS6 2.00 intake, sodium filled stem valves turned down to 1.625 for exhaust with 3 angle vj
stock 2.16 on intake polished and bowl work runner
machinist tha did them for me cost less than 100$ (SAM grad.)
i alredy had the valves, i believe the stock ls1 2.00 intake will also work
or if u have some truck 1.89 can also be turned down to size
Old 11-18-2006, 04:44 PM
See5's Avatar
Waiting for some on motor results.
*Edit- results are in and heads are ordered.
Wegner to port and mill.
Old 11-18-2006, 08:13 PM
Dave_62's Avatar
LS1Tech 20 Year Member
What's the rumor on the price increase?
Old 11-18-2006, 09:58 PM
AVB
AVB's Avatar
Eventually...
Old 11-18-2006, 10:53 PM
skipperbisket's Avatar
basically same setup as NemeSS but only 369.6CI
Old 11-19-2006, 01:15 AM
280Z28's Avatar
Already have the heads and intake. It'll be next summer before y'all see the result though... we're using an LSX block. 400-427ci, exact stroke still TBD.
Old 11-19-2006, 05:18 AM
Ellwood's Avatar
I'm seriously thinking 'bout it... but I take a long time to make up my mind. The price, big valves... Sure make 'em tempting.
Old 11-19-2006, 07:24 AM
WKMCD's Avatar
Not me.
Old 11-19-2006, 10:45 AM
WizeAss's Avatar
Originally Posted by WKMCD
Not me.
your still just a rumor.....
Old 11-20-2006, 04:57 PM
Oscar Will's Avatar
My 6.0L block is at the machine shop getting .040" over Mahle pistons and a balance job. The L92 heads are assembled, the L76 intake is on the bench and the cam has yet to be determined. After the holidays things will move a little faster and hopefully by spring I'll have some comparative data with this engine vs. the LS1 motor that is currently in the car.
Old 11-21-2006, 01:30 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We hope to have the first available CNC ported L92 heads ready sometime late next week! I've been working on several things for them....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-21-2006, 01:52 PM
9 Second Club NA
Dragaholic's Avatar
Jason 98 TA, who are ya'll out-sourcing for the CNC on the L92 heads?
Old 11-21-2006, 01:54 PM
forgedbluess's Avatar
I just got off the phone with my machinest and im doing the l92 heads with on a 370 and all im waiting for now is if i can use the edelbrock victor jr intake or not with these heads?
Old 11-21-2006, 02:33 PM
michael402z06's Avatar
nope.
Old 11-21-2006, 02:51 PM
Rock_Daddy's Avatar
My L92 engine obviously has L92 heads but in totally stock form. I have a second set waiting for someone to really figer them out so they can be ready for a swap at any time. I won't be on the chassie dyno for a while yet as a cage still needs to go in before I get that far. Its a long winter here in Mi.
I can't wait till we start seeing what modifying can get these things up to.
Old 11-21-2006, 11:17 PM
Tom@SpeedInc's Avatar
I'll sit back and watch, no suprises yet.
are L92 heads 12* and 15* valve angle?
Old 11-22-2006, 09:21 AM
WizeAss's Avatar
Fraser, whuts up?..... I love the new rearend, those 3.90 gears where the perfect choice....... too bad the motor didnt last much longer. I am planning a 408 w/ L92's on a L76 intake..... just need to pinpoint the right cam size..... needs to be a little over barely streetable....
I plan to keep the SD tune though.
Old 11-22-2006, 09:40 AM
WKMCD's Avatar
15* valve angle
