What is needed for LS7 heads and LS7 intake to install in 2003 Z06??
I have 03 Z06 with Cartek H/C, FAST 90, 90mm Tbody, other bolt ons. Looking at possibly a Katech 427 short block and purchasing some ls7 heads and intake. Just trying to weigh my options before deciding. I assume the ls7 intake would need different injectors and fuel rail? I haven't done too much research on the ls7 heads and intake, I thought i read in GM HIgh tech that you could buy the ls7 intake with fuel inj and rails and tbody for a good price??? Or was that the L92 truck intake for those heads?
thanks
thanks
thanks
thanks
LS7 intake
LS7 injectors
LS7 fuel rail
injector clips
fuel rail bolts
intake manifold bolts
MAP sensor (or reuse your old one - double check the PN, I think they are the same)
LS7 throttle body
Katech throttle body adapter harness KAT-4752
Katech injector adapter harness kit KAT-A4758
MAP sensor extension harness KAT-4751
ls7 katech
thanks for quick reply, I've been looking at the part# list for the ls7 stuff. I have an ls2 90mm dbw tbody already wired up and working. The car runs 11.0's at 127traps driving to track and then back home. I assume the ls7 fuel rail inlet is the same as my stock one?
Do you sell the ls7 heads assembled, if so price? And do you offer any type of porting, or is it really needed? Looking for 550-575rwhp with a cam that will allow descent drivability. any suggestions on a cam you might recommend that you have some experience with?
thanks again
thanks again
thanks again
thanks again
Originally Posted by LostCauseZ06
ummmmmmmmmmmmmmmmmmmmmmmmmm... correct me if im wrong.. but im pretty sure im right...
LS7 heads WILL NOT WORK on a stock bore LS1.. the valves will hit the cylinder walls.
Originally Posted by Ratical
You are completely right, but he mentioned buying a Katech 427 shortblock. Not sure why he asked if they'll work on an 03 vette since the motor isn't going to be original one.
woops lol missed that part
