aftermarket rockers for L92 heads?
You may want to follow up with Jesel. They had an L92 setup on display at PRI. Looked like one of the higher end setups. I'm mad at myself for not taking the time to ask about it, but there was sooo much to see.
LS1Tech Premium Sponsor
I have a set of shaft mount 6.2l rockers from Jesel in stock. I've had them about 6 months or so
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Are these the offset ones needed by the L92?
Ratio?
Pricing?
Ratio?
Pricing?
