LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   Any De-Stroked LS7's Yet (https://ls1tech.com/forums/generation-iv-internal-engine/645633-any-de-stroked-ls7s-yet.html)
NemesisC5 Jan 23, 2007 12:41 AM
Has anyone here has put together De-Stroked LS7. I have been considering something for my A&A Vortech supercharged 99 Vette and thought about LS7 block, L92 heads, L76 intake, etc. My purpose is to build a quick revving rpm machine. Any Thoughts?
SStrokerAce Jan 23, 2007 12:53 AM
Y? I'd rather see a stroked LS7.
Katech_Jason Jan 23, 2007 08:31 AM
We have a 5.7L LS7 called our Sneak Attack LS7.
Whistler Jan 23, 2007 09:41 AM
You could put in a stock LS1 crank and get 387 c.i.
I wouldn't want to... but you could do it.
Old SStroker Jan 23, 2007 11:52 AM
How about the original (2004?) CTS-V R engine? Wasn't that basically a small LS7 about 3 years early? You guys had some part in that, didn't you?
Katech_Jason Jan 23, 2007 12:46 PM
Yes, the Street Attack LS7 design came from concepts originally developed for that program.
Cop Car Jan 23, 2007 01:40 PM
the short stroke 5.7 is a 7.0 block and a 4.8 crank
BLK02TA Jan 23, 2007 01:47 PM
That would sweet!!!
gnx7 Jan 23, 2007 03:34 PM
Dave (aka 427 LS1) just told me about a 388ci LS7 block setup with Callies 3.62" stroke lightweight crank setup/Oliver rods with ARE dry sump oiling that had crazy throttle response. All-Pro LS7 heads and LS7 intake....
They built the motor for a C5 road race Vette. I think it just got running and no dyno numbers yet. He said you blipped the throttle and it revved instantly.
Nine Ball Jan 23, 2007 04:08 PM
I had the first all-bore 382ci LS1 on the net, and that sucker loved to rev. Probably one of the best all-around daily drivable engines I've owned yet. But, now I prefer more cubes since cranks are much cheaper now than they used to be.
Plasticman Jan 23, 2007 05:07 PM
I have a 3.41" crank in a c5r which was , I believe , designed to run in the under 6 litre class at Le mans. I don`t now how it runs yet as I am still trying to source parts and detune it . It currently has 4.175" pistons running in a dry liner.
http://i125.photobucket.com/albums/p...s/100_0810.jpg
DoesSpeedTurnUon Jan 23, 2007 05:12 PM
that'd be an incredibly fun motor :D
NemesisC5 Jan 23, 2007 06:05 PM
Responses are mostly what I expected, mixed but with mostly good responses for the combinations excellent higher rpm response :rock: The desire for High Performance Street Cars is driving sales up in the growing tuner market like never before. It is a reality today to those of us that went through the times of gas rationing and absolutely NO NEW HIGH PERFORMANCE AMERICAN MUSCLE CARS were being produced. I remember from my high school days a friend that had a De-Stroked 400 down to 377cid and it was a screamer. I also remember the old Z-28 with the 302cid that was developed so Chevy would have a car to compete against the Boss 302 in Trans Am racing. My point is that the "short stroke" combination can really make a car fun to drive with the faster building revs and the HP to turn some quick laps. Different STROKES for different folks :barf:
THE_SUPRA Jan 23, 2007 06:10 PM
...just how high reving are we taliking?
DoesSpeedTurnUon Jan 23, 2007 06:12 PM
I think my next one will be high revving like that
NemesisC5 Jan 23, 2007 06:16 PM
I don't think this combo would necessarily rev any higher than other combo's due to lifter technology, but as mentioned by other posts it will build revs quickly
racer7088 Jan 23, 2007 06:45 PM
The way to make an engine accelerates faster is not with shorter stroke but with lighter parts. Then with a short or a longer stroke the engine will accelerate faster!
Whistler Jan 23, 2007 06:57 PM
Like said above- the fast revving nature of an engine can be attributed to the weight of the reciprocating assembly, but also the cam specs, dynamic compression ratio, and timing table of the tune. A 382 LSX with more stroke than bore can rev just as fast. If anything it might rev a tad quicker in theory with a few less grams in each piston and in the counterweight.
NemesisC5 Jan 23, 2007 09:22 PM
Just the physical nature of the shorter stroke will make an engine turn 1 revolution quicker. I certainly agree that lightweight internals and valvetrain components contribute towards increasing an engines ability to build revs quickly & to sustain them. I also agree that cam selection, compression, timing, etc., play their role in the acceleration ramp of the motor. As far as a longer stroke building rpm's quicker, I disagree. Please correct me if I am wrong, but it seems to me that statement is confusing piston speed with engine revolutions. On 1 revolution of an engine the engine with the longer stroke will have faster piston speed. Conversly speaking, the same two engines with piston speed remaining equal, the engine with a longer stroke travels more distance thus slowing down the turn of a crankshaft.
racer7088 Jan 23, 2007 09:56 PM
Longer stroke engines certainly accelerate the car faster when in gear and going down the track so I guess they must also be accelerating the engine faster too!
If you're just free revving an engine then who knows but if you can do something to make more power and the engine's internals do not weigh much more then it will rev even faster.
Have you ever heard a Top Fueler blip the throttle? These engine have massive big block stroke and yet have only small block bores and also super heavy rotating components by they also have extreme power so they rev up like nothing you've ever heard!
© 2026 MH Sub I, LLC dba Internet Brands
