Quick Question for you l92's gurus I have a 408 that made 452hp/425tq with afr 205 66cc heads, -12 pistons, and The cam is a 244/248 .612/615 115 This was with a stock auto,rear end, intake and compression around 10:2 to 1 Also, had 1 3/4 headers. My question is, Would it be worth it to change to some ported l92's and the l76 intake or just upgrade to a fast intake and better headers? Do you think with l92's I can get over 500rwhp? |
give it a little more compression, i don't see why not? |
You would not be able to get any compression out of the l92 with your dished pistons. I am building an l92. If I were you I would go with the fast and better exhaust. If you did that and got the comp to 11/1 you would get some gains. |
What about milling the l92's? |
Originally Posted by ChucksZ06 You would not be able to get any compression out of the l92 with your dished pistons. I am building an l92. If I were you I would go with the fast and better exhaust. If you did that and got the comp to 11/1 you would get some gains. |
Originally Posted by bcs I have a 408 that made 452hp/425tq with afr 205 66cc heads, -12 pistons, and The cam is a 244/248 .612/615 115 This was with a stock auto,rear end, intake and compression around 10:2 to 1 Also, had 1 3/4 headers. My question is, Would it be worth it to change to some ported l92's and the l76 intake or just upgrade to a fast intake and better headers? Do you think with l92's I can get over 500rwhp? |
Originally Posted by Quik something cant be right. those numbers are low!!!! those numbers what some cammed LS1s make |
definately better money wise to sell the AFR 205's, intake, little headers, etc. Get a set of ported/assembled L92's, L76 intake package, and 1 7/8 to 2 " headers. If you can manage to easily raise the CR, you will gain a lot of power. Stock auto aint gonna live long, get a RPM built 4L60E for $1600-2000 and stick a nasty converter in it. |
I have -9cc pistons, .051 gasket and a 65cc chamber on my L92 408. |
Originally Posted by 2c5s I have -9cc pistons, .051 gasket and a 65cc chamber on my L92 408. |
Originally Posted by ChucksZ06 So what is your comp ratio? |
Originally Posted by ChucksZ06 So what is your comp ratio? It's 11 to1. |
| All times are GMT -5. The time now is 07:47 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
