LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation IV Internal Engine (https://ls1tech.com/forums/generation-iv-internal-engine-80/)
-   -   So who's ready for the LSX? (https://ls1tech.com/forums/generation-iv-internal-engine/664494-so-whos-ready-lsx.html)
KurtRardin Feb 23, 2007 08:10 PM
I believe that I heard that the LSX is suppost to be released in March, this year, and it should go for anywhere from $1800 to $2500. Anyone have any plans?
I like how this block is suppost to be extremely strong, and since the cylinder walls are so thick it can be rebuilt many times, or bored out to a monster.
I am thinking that as soon as i get out of college I will go with an LSX block and a pair of assembled L92 heads from SDPC.
Who sells LS2 rotating assemblies?
My plan, which i am certainly ready to hear debated, is to buy a pretty much OEM LS2 rotating assembly and use the L92 heads and LSX block. This motor should last forever, especially without boost or nitrous.
Are there any drawbacks to the L92 head/LSX 6.0 combo?
My headers will still fit on L92 heads, correct?
And since the valve springs on the L92 heads from SDPC are rated to .650 lift then I should have no problem with majority of the cams available.
Katech_Jason Feb 23, 2007 08:11 PM
Katech is ready for the LSX. Should be an interesting summer ;)
CougarL92 Feb 23, 2007 10:39 PM
im still dreaming
qqwqeqwrqwqtq Feb 23, 2007 11:20 PM
Hell yeah I'm ready. Plans are 427ci, ETP LS7 heads and twin turbos.
Quickin Feb 24, 2007 12:20 AM
Dare I say....I'm on a list waiting patiently :)
red90cobra Feb 24, 2007 01:35 AM
wish i could afford another build this year
383ss Feb 24, 2007 08:53 AM
pretty much any sponsor on the right is going to sell aftermarket LS2 rotating assemblies. they are all the same for the LSX family. why you would want to use stock LS2 parts, I have no idea. the crank is fine, but why use the rods and pistons?
Mssingkid Feb 24, 2007 09:46 AM
Wish the block wasn't so heavy, but i'll probably still end up buying one. Bring on the BIG cubes! :judge:
Red99C5 Feb 24, 2007 02:17 PM
I agree. Why have a extra strong block if you aren't going to put the extra strong compenents inside. Might as well just use a LS2 block.
aggiez28 Feb 24, 2007 02:41 PM
why?
sems like a great way to waste $$
VENGEANCE Feb 25, 2007 04:08 PM
Since the block is supposedly good to 511 cubes, have any companies come out and said they have pistons/rods/etc for a 511 cube motor?
Are there pistons out already that would work for a 511 cube LSx? prices?
I did a search but came up short....
11 Bravo Feb 25, 2007 04:24 PM
I'd be more worried about having to have custom headers made for the tall deck than pistons.
VENGEANCE Feb 25, 2007 04:33 PM
Why? where would the headers hit? is there that much of a physical difference between 9.22 and 9.7 to the point where a good set of kooks wouldnt work?
Whistler Feb 25, 2007 04:39 PM
Probably. The engine decks are 90' to each other, so as the decks increase in height they also increase in width.
VENGEANCE Feb 25, 2007 04:53 PM
good point, i didnt really think about that. i guess its going to be one of those things well find out after the block is released.
back to my pistons question, anyone?
KurtRardin Feb 25, 2007 06:23 PM
The reason i was considering stock ls2 internals was because all the stroker kits that i found were almost $4000. If there's a budget rotating assembly out there then please let me know. I dont even know what a oem ls2 kit would cost or where i could get one.
I really just want to take advantage of the cheap L92 heads, and the l76 intake, and a strong block that would last for a long long time.
11 Bravo Feb 25, 2007 06:48 PM
A stock LS2 piston is too small for this block.
KurtRardin Feb 25, 2007 06:52 PM
The write up in GM High tech said that you could take the LS2 out of your vette, take all the interanals out, and put them over into this block. Doesnt it start out as a 3.999 bore?
11 Bravo Feb 25, 2007 07:03 PM
Hmmm, maybe it does. Still a waste imo. An Eagle setup is cheap. Aftermarket cranks, pistions and rods are no less reliable than GM stuff.
Wnts2Go10O Feb 25, 2007 07:10 PM
well... you could use a stock ls series crank and just get a decent piston/rod/ring setup. OR just get a used LS2 because the block hasnt been broken.
what I would do is a stock LS crank, 6.125 Eagles, and a 4.125 or more bore. LSX block isnt really for a budget street build
© 2026 MH Sub I, LLC dba Internet Brands
