1.7 or 1.75 non adjustable roller rockers?
Anyone have a set of non adjustable roller rockers installed from Jesel, Scorpion or other? If so, what are your cam specs and do you have valve reliefs in you pistons? I have a fairly healthy cam (595/605 lift 232/238 dur) and have Mahle 1cc valve relief pistons.
I would like to install roller rockers and put in either 1.7 (stock) or 1.75 ratio rockers...Maybe 1.85 if they will work. Problem is, I don't know if I'll have piston to valve contact with anything more than the stock 1.7 ratio. Anyone have any thoughts or experience with this?
Thanks,
Bill
Thanks,
Bill
