Precision Race Components LS7 Cylinder Head Engine Dyno Results!!
#61
Thanks for the support JMB! I wasn't trying to impress people with what these things can make, hell I have dyno numbers of that engine making anothe 30+hp with different cams & stuff. I was just trying to show power potential from a simple head swap.
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#62
You get water temp numbers, oil pressure numbers, etc. for each pull and the ONLY part that was changed was the cylinder heads and disuse of the vacuum pump. The purpose of the test was to show the difference the heads could make on that setup. What are you expecting, an ET difference from both heads? Come on man....
#64
Yeah buddy!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#68
Excellent numbers! Was that the vp 113 or another brand of 113?....the oxygenated VP is making some good power from what I've heard. Next time you're on the pump, it would be interesting to see if you could make it run on 93 octane. The bsfc was interesting...It's not often I see a "relatively" low compression engine run best that lean. Good work on the heads! We're going to start seeing a lot of 700+ crank pump gas 454 and larger cube engines in the near future. -Brian Nutter
#70
We've shipped about a dozen sets of them so far with typical gains of 35rwhp-45rwhp based on decking. We gained something close to 100rwhp with heads & cam change in our c6 z06!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#71
How do these heads perform in the lower RPMs. Your dyno pulls start so high in the RPM range, I would love to see what they would do in the lower range for a daily driver.
Oh and what did the GTO make?
