TFS 225's on a L92? Toasted the bottom end on my LS2. I am considering buying a L92 stroker and using my existing heads. What are your thoughts? |
Sounds good to me. |
not bad at all- they might work better on a 4.035 bore- |
What did you do to your bottom end??? Are ya selling it :) |
Originally Posted by Zturd
(Post 8371457)
Coincidence??? Do you have any idea why it happened? That really sucks! |
Originally Posted by ss1
(Post 8376503)
Diesel fuel.....? |
Originally Posted by sprayjunkie
(Post 8376728)
Diesel fuel.....? |
The 225's will work very well. Would be a great start to a nice combo. |
well if you wanna snatch the motor out i'd like to have the block :D |
I filled up at a Shell station one time and the water seperator had defected. Little did I know that I ended up w/ a quart of water in the tank. You might check for water contamination. It makes the motor sound like hell. Mine hydrolocked. Cleared the cylinders and ran the fuel pump w/ the fuel line off to clear the water. I was lucky it didn't hurt the rods since they damage easily to hydrolocking. |
225s will work great |
I definately think that would be a good combo. The l92 418cid strokers we stock should work very well with that TFS cylinder head. We currently have 4 418cid l92 short-blocks instock & on special!! |
Originally Posted by Jason 98 TA
(Post 8407189)
I definately think that would be a good combo. The l92 418cid strokers we stock should work very well with that TFS cylinder head. We currently have 4 418cid l92 short-blocks instock & on special!! Jason, work me up a deal and shoot me a PM. |
IMO a great combo! |
| All times are GMT -5. The time now is 10:41 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
