Oil Pump Pressure Relief Valve
I've just removed a front hump sump from a new LS2 crate engine for the fitting of a new rear hump sump, but found the new sump does not have an oil pump pressure relief valve.
The front hump sump, GM p/no. 12599397, has a provision cast into the sump for the valve mounting.
The rear hump sump, GM p/no. 12581810, is listed for the Corvette LS2 engine. The new sump fits perfectly but there is not even a casting provision for the valve.
Has anybody found this before and how important is it to use an oil pressure relief valve.
Any assistance would be appreciated.
Sorry we mostly call it a Sump but it seems you guys call it an Oil Pan.
The GTO uses a front oil pan compared to some other models using a rear pan.
I will remove the pan and see if my GTO LS2 oil pump has a blank installed where the pressure relief valve would normally be located.
Looks like the GTO may use a remote pressure relief valve in the pan. Fingers crossed the valve can be relocated back to its original position.
GTO oil pan.
Corvette oil pan.
GTO oil pan.
Corvette oil pan.
