Rocker Arm Sequence
Old May 6, 2008 | 11:29 AM
bluethunder364's Avatar
Default Rocker Arm Sequence
What is the correct way to tighten the stock rockers down. I know that they have no adjustment. Do you just install them and torque them down. I also plan to prelube the motor. That should put some oil into the lifters. Will that have any impact on the outcome. I also want to check my pushrod length while I'm at it. Any info would be appreciated
Old May 6, 2008 | 11:40 AM
dlove's Avatar
just torque them down any order to 22ft lbs. Then turn the motor over a few times and check the torque on them again.
If your heads are ported, then the intake bolts will need thread sealent on them to seal them up. Thats if your heads have a decent port job where the rocker arm bolts will stick threw into the port.
if the lifters are new then they need to take an oil bath for about 30 mins or so. If they have been sitting in the engine it would be a good idea to pour some fresh oil on them, although the rocker arm torque wont be affected either way. Just a precaution on preventing any damage on startup with dry lifters.
pushrod length can easily be checked while doing this. if you dont know how to, get on comp's website or google how to do it.
Old May 6, 2008 | 12:06 PM
Thanks very much, Appreciate the info
Old May 6, 2008 | 02:12 PM
vettenuts's Avatar
Not exactly, there is a sequence.
Old May 6, 2008 | 02:23 PM
dlove's Avatar
I have had my rockers on and off 20 times without a single issue with just torquing them down. you just have to turn over the motor a few times to make sure they are seated all the way.
Old May 6, 2008 | 04:04 PM
vettenuts's Avatar
There is a reason for the GM sequence, LS1howto is not correct.
Old May 6, 2008 | 04:07 PM
Fratsit's Avatar
Man...lots of these questions popping up lately. Follow the sequence vettenuts posted.
Old May 6, 2008 | 05:14 PM
The sequence makes good since to me. If I understand this correctly your taking the pressure off the rocker to torque it down while your off lobe lift.
Old May 6, 2008 | 05:37 PM
vettenuts's Avatar
Correct, ensures correct bolt preload and prevents pushing the valve into the piston on the overlap portion of the stroke.
