Ls9 Rod Length? What is it? I read somewhere that it is 6.00". Is this true? |
Bump. |
yeah. same as all LS based motors. but why you want to know. don't buy those rods. they suck. only rated to like 7,000 rpm. that is why the rev limit is 6,200 |
Originally Posted by Big Bird WS6
(Post 9397463)
yeah. same as all LS based motors. but why you want to know. don't buy those rods. they suck. only rated to like 7,000 rpm. that is why the rev limit is 6,200 They are 6.00" long (shorter than standard LS rods), Titanium just like LS7, have a larger diameter pin and are used in a production engine that's rated near 650hp. |
Originally Posted by LSX Wizard
(Post 9401540)
Not sure how you can say they suck? And where'd you get the rpm rating from? :confused: They are 6.00" long (shorter than standard LS rods), Titanium just like LS7, have a larger diameter pin and are used in a production engine that's rated near 650hp. |
(Post 9406543)
if you dosome research. GM only rates them to X amount or rpm. it aint like the LS7 rods. and they are the same lenght. all the ls9 is is a supercharged LS3. they just dropped compression. same stroke. same bore. same rod lenght. |
1 Attachment(s)
(Post 9406543)
if you dosome research. GM only rates them to X amount or rpm. it aint like the LS7 rods. and they are the same lenght. all the ls9 is is a supercharged LS3. they just dropped compression. same stroke. same bore. same rod lenght. Titanium vs. steel .984 wrist pin dia. vs. .944 dia. 6.00" lg. vs. 6.10" lg. Scalloped small end like LS7 vs. non-scalloped |
yea those rods look like they suck alright :eyes: |
hey. i never once said horse rating. i said RPM. lets do apples to apples. titanium strong at high rpm weak at high horse(info form MTI they have broke a LS7 rod with like 750 horse.) forged strong and strong at highg hosre. you will have less money in, well lets say oliver forged rods then the ls9 titanium rods. |
© 2024 MH Sub I, LLC dba Internet Brands
