454 Lsx Mpg? Hey, Anyone know what sort of gas mileage ill get out of a 454 LSX with ITBs... 650RWHP. t400 with a 3500 stall.. not sure on cam, something with a mild to rough idle with lots of down low power would be going in. DAILY DRIVER. THANKS GUYS scott. |
who would drive a 454 lsx and worry about gas mileage? thats a decent size stall... I'd guess about 7-8mpg High end... |
Little>>>None. Somewhere in the middle of there. |
Originally Posted by nd4spd22
(Post 9447006)
Big engine + no overdrive + decent stall = don't plan on it being remotely economical to drive on the highway. If this is going to be a daily driver plan on just signing over a very large portion of your paycheck to the gas station. Depending on your gear I'd say 6 to 9. Close to 4.10 gears, 6 mpg. 3.08 gears, maybe 9 mpg. Takes a lot of gas to turn that big engine that many rpms going down the road. |
I get about 23-24 mpg on the highway, staying at an easy 70mph, and easy on the gas. I'm running a 500+ rwhp 427ci LS2, LS7 top-end with a pretty radical cam. I'm also running with a 6-speed, which makes it easy to keep rpms LOW when cruising. You're automatic setup is what is REALLY going to suck down the sweet juice. Now city mpg is a whole different story. Even I'm pushing about 9-10 mpg, which is not too shabby for the setup lol. |
Originally Posted by Lilscottie
(Post 9446984)
Hey, Anyone know what sort of gas mileage ill get out of a 454 LSX with ITBs... 650RWHP. t400 with a 3500 stall.. not sure on cam, something with a mild to rough idle with lots of down low power would be going in. DAILY DRIVER. THANKS GUYS scott. When I drive aggressively in the CITY on a tank I have to fill up at around 150 miles from that 14 gallons. So it drops to about 10 mpg. Its more about driving casual and normal to get the best mileage. But with your heavier tranny I would say you'll get 10-12 in the CITY if you drive casual. But once you get on it hard in CITY driving, with a 454ci, you'll be getting 7-8 mpg. Cruising on the highway, well you'll have to find your engines sweet spot. But I think you can get 20+ mpg. |
Originally Posted by needadvice
(Post 9447531)
I have a VIG 3700 stall in my 427ci (500 RWHP) and in the CITY I get around 200 miles from a full tank. So if I use the 14 gallons and then I'm "EMPTY" and have to get more, so thats about 14 mpg. NOT BAD AT ALL for 500 RWHP. Highway cruising at 70 and I get about 25 mpg. When I drive aggressively in the CITY on a tank I have to fill up at around 150 miles from that 14 gallons. So it drops to about 10 mpg. Its more about driving casual and normal to get the best mileage. But with your heavier tranny I would say you'll get 10-12 in the CITY if you drive casual. But once you get on it hard in CITY driving, with a 454ci, you'll be getting 7-8 mpg. Cruising on the highway, well you'll have to find your engines sweet spot. But I think you can get 20+ mpg. |
I'm with Bane, no way in hell, he'll be lucky to get 10 on the highway. |
Originally Posted by Stang's Bane
(Post 9447722)
There is no way he will touch 20 on the highway with a 3 sp auto. That thing will be turning 3K+at 60 with 3.73's |
if ya got 15k to drop into an engine, you arnt worried about gas |
What is the compression ratio? |
Originally Posted by pdd
(Post 9449058)
if ya got 15k to drop into an engine, you arnt worried about gas The engine in this case is not his problem with possibly collecting a decent highway mpg number, it is his driveline. That big stalled, non-od auto is KILLING him. |
(Post 9449058)
If your worried about gas millage, go with fuel injection. You should be able to get decent millage with that. High teens I would think, a c6 z06 get's 18/26. You should be able to pull somewhere around that with fuel injection. |
Who care you have a 454! ! ! |
Originally Posted by lov2xlr8
(Post 9449646)
If your worried about gas millage, go with fuel injection. You should be able to get decent millage with that. High teens I would think, a c6 z06 get's 18/26. You should be able to pull somewhere around that with fuel injection. He is planning fuel injection. ITB |
Do you already have a 454 or planing to build one? I wouldn't even consider it for a daily driver. |
Originally Posted by JScamaro
(Post 9450103)
I run the LSX454 but I changed the A4 to a M6. At 70MPH in 6th gear I see just over 17MPG. With the T400 and stall you will be lucky to get 10-12MPG at 70MPH. Around town in stop and go traffic it drops quite a bit. And I have to say, I love the 454 as a weekend warrior, but would not run it as a daily driver....no way. |
© 2024 MH Sub I, LLC dba Internet Brands
