L92's and solid cam Anyone on here run a solid roller with L92's? Just wondering what springs/spring pressures and rockers are being used? |
I am building a set up with l92 heads and a solid roller. I am not sure on what spring and retainers I am using yet, but I have a set of T&D Rockers on the way to use with it. I suggest useing either T&D or Jesel rockers for any solid roller build. My big problem right now is that no one makes a intake for these heads yet that will take the rpms that I wont to turn. |
Originally Posted by Badmire68
(Post 9503144)
Originally Posted by O6DODGE
(Post 9504567)
The T&D rockers for the LS stuff are junk IMO. We got a set for my solid L92 build and the pushrod cup was WAY off. i can get you a GOOD set of sportsman style rockers from a company here in texas if you want. My 414 did 710 at 7300 when it started floating valves. It has not been put back on the engine dyno since the new rockers. We will just have to wait to see what it does on the chassis dyno. Got a 200+ direct port too :) |
Originally Posted by sixt9er
(Post 9504623)
Alot of guys are running the GMPP 4-bbl style intake with a elbow on it with these heads. There are several fabricated intakes ($$$$) offered for these heads also. |
Not all of there stuff is junk. The Ford stuff they sell is very nice. I stated the LS version of their rocker is no good. Erik Koenig (HKE Racing Engines) will agree as well. The changed the design to fit under a stock valve cover for some reason and now the geometry for anything over 600 lift is so skewed its not reliable and costs quite a bit of horsepower. Their customer service leaves alot to be desired as well. The owner of T&D told the shop they were right and that he would call them back. Didnt happen. Do a search for DRE in Texas. Good stuff. Jessels stuff is nice too but the only thing offered for L92 heads is a Mohawk design which is $$$$. |
yeah I was going to go with the mohawk pros but I got a good deal on the T&D rocker who were recomended by the guy who is building my motor. I will give these a shot i9f they dont work I will try the Jesels. |
(Post 9504610)
Yella Terra makes a nice set of adjustable rocker arms for this L92 head. They are alot less than the Jesel and T & D set-up. I would suggest the Jesel and T & D set only if you are racing with your vehicle. |
| All times are GMT -5. The time now is 12:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
