Taller installed heights for L92 heads?
Can anyone tell me part #'s and brands of aftermarket L92 valves for taller than stock installed heights? I only see stock length valves listed from manley so far with standard size 2.165"/1.570" heads. Any help is greatly appreciated, TIA
I haven't seen any taller than stock valves yet, but there may be some I don't know about. If your installed height is near 2.00" you could remachine LS7 valves to work. They're tall enough that you can step cut the spring pockets for a 1.550" spring diameter and still avoid water jackets and port roofs. Of course you'll have to rework your rocker stands too (which you'll probalby have to do anyways).
Good luck,
Richard
Good luck,
Richard
