Would I benefit from a cam swap in my 413 L92/L76?
I am running a 413 cid LS2 in my Camaro. It has all forged internals and is 11.1: 1 comp. It has a set of TSP ported L92 heads and a stock L76 intake. The cam is the Livernois stage 3 L92 specific cam, 242/248 .610/.618 114 . At the time I choose this cam there werent too many guys running these heads yet and nobody really had a proven cam grind that worked well with these heads. Now that there are quite a few people running L92's I think the custom cam gurus have a pretty good handle on what these heads like. My car put down 480rwhp with the 6speed through a 12-bolt, but now I swapped to a th400 with a Yank 4000 stall. I know the th400 is not going to make good dyno #'s but I would like to see some impressive 1/4 times. The engine is out of the car as we speak so if I am going to do a cam swap now would be the easiest time to do it. But would it be worth it?
I have a Custom Cam Motion Cam Brand New made for a 408 with L92 heads
259-266 621-628 114.
Made 530 RWHP in a 408 iron block with a Turbo 400 and went 10.09 NA.Going Solid Roller so I have this one available
$395.00
http://fastlsx.vidiac.com/video/7417...6a016bc787.htm
Ray T
$395.00
Ray T
I'm also looking into a cam swap for my l92 heads. I have a 402ci w/ported L92's,a stock l76 intake and threw a 12bolt w/ gears on a mustang dyno I made 517hp 468tq. I ran a 10.86@128MPH in my 3,700lbs car. My cam is a 248/254 515 /605 112lob. Lg motorsports and Pat G.Feel this cam is too big and not giving me the mid range power and tq I should have. So I'm going to try LG's G6X3 cam. I was told I would not loose but maybe 2hp on the topend but gain 30lbs of tq through the midrange. So...In about a month I should have the results of that. Maybe you should try something new also,like you said....these heads did'nt have as many cam options as they do now.
Goodluck to ya.
Goodluck to ya.
