Give opinions on these rod and main bearing clearances.
Mains:
1) .0027
2) .0026
3) .0025
4) .0029
5) .0026
Rods:
1) .0023
2) .0024
3) .0023
4) .0024
5) .0024
6) .0025
7) .0025
8) .0024
Seems alittle loose to me compared to some things I have been reading. Should I be running thicker oil than 10-30 with a loose motor like this? Thanks for the input.
1) .0027
2) .0026
3) .0025
4) .0029
5) .0026
Rods:
1) .0023
2) .0024
3) .0023
4) .0024
5) .0024
6) .0025
7) .0025
8) .0024
Mains:
1) .0027
2) .0026
3) .0025
4) .0029
5) .0026
Rods:
1) .0023
2) .0024
3) .0023
4) .0024
5) .0024
6) .0025
7) .0025
8) .0024
1) .0027
2) .0026
3) .0025
4) .0029
5) .0026
Rods:
1) .0023
2) .0024
3) .0023
4) .0024
5) .0024
6) .0025
7) .0025
8) .0024
Hot idle is around 32 and cold is around 45 and cold driving goes to almost
60. Found that I have a bad sending unit. Used a mechanical gauge to get these readings. Seems all is good, I would like alittle more idle psi but running a vac pump does cause a lower psi from what I have been told. Just want to make sure all was good for atleast the rest of the season. Come winter I plan on pulling it apart for the solid roller setup and then have the bottom end gone over for peice of mind. If there was to be a problem I would just pull apart now and get ready for the winter. But all looks good, I appreciate all the help guys.
That is not an abnormally loose engine. Are you using a stock aluminum block? If so, your main clearances are just fine since a big cube motor making a lot of power will move that block around quite a bit and if you don't give it a little more room to move, it will wipe out the mains.
GM LS7 block.
eq2 plat
Farming for eq2 plat isn't easy, but you can buy eq2 plat, guides, accounts & items on sale. We have revolutionized the exchange of money to eq2 plat. Purchase eq2 plat& power up your character ot the next level. Our world class customer service will make sure you are more than satisfied with every purchase. Feel free to contact our 24 hour live support with any questions you may have. Shop now and play as a VIP!
