402/408 w/ AFR 205's?
I am in the early stages of planning a 408 or 402 build. My question is has anyone ran AFR 205's on a motor like this with good power success? I know the heads might be on the small side for this size stroker just wondering if it is worth it or if I should sell them and get some 225's. This is a street car that sees the track once or twice a year. Any info would be greatly appreciated. I'm sure i'll have more questions as I get into this further.
ill let you know in a few weeks when i get my motor from weber racing. i had a set of mamo ported 205s on my stock CID LS2 before it let go. now they are getting fixed and going on a weber racing 402 LS2, with a 240/244 dur cam, .600 lift and 112LSA
I read a post some were by Tony were a guy built a 402 I think and ran a set of 205's on it with very good results and it was a very mild cammed street car that made great power. Do a little digging and you will find it. I think they are fine on a 402. I think they did a little work to open up the chambers to un shroud the valves a little more.
I'm building a 383 and re using my afr 205's with a vc jr intake and 750 demon carb and T rex cam. I hope it will be pretty nasty!
402 w/ 205's is one potent little combination on the street. That is what my winter build is comprised of.
https://ls1tech.com/forums/showthrea...334&highlight=
https://ls1tech.com/forums/showthrea...645&highlight=
