101mm TB's
Old Aug 9, 2008 | 12:42 PM
JayplaySS's Avatar
Moderator
Default 101mm TB's
I just found this on Ebay today just looking around. Wow, big Professional Products throttle body. Too bad they dont have one for the DBW C6's in 101mm.
Some of you may have seen it, not sure. Still a big azz throttle body.
http://cgi.ebay.com/ebaymotors/NEW-P...4506.m20.l1116
Old Aug 9, 2008 | 05:37 PM
abbaskhan's Avatar
i was wondering the same thing
anyone???
could you retro fit any of the electronics to get it to work
on a c6
Old Aug 9, 2008 | 08:29 PM
josht's Avatar
Default Professional Products Throttle Bodies for LS2 Engines
http://www.professional-products.com/throttleLS2.php
LS2 Engines
Polished Satin Application
69728 69729 96mm Throttle Body for LS2 engines where a cable throttle linkage is being used. Available second quarter of 2008
69730 69731 96mm Throttle Body for LS2 Corvette and GTO
69732 69733 101mm Throttle Body for LS2 engines where a cable throttle linkage is being used.
69734 69735 101mm Throttle Body for LS2 Corvette and GTO. Available third quarter of 2008
check with one of the sponsors like byunspeed if the 96mm or 101mm comes with the dbw motor
Old Aug 10, 2008 | 02:29 AM
JayplaySS's Avatar
Moderator
LS2 Engines
Thanks man, very good to know. I had thier 85mm on my SS with no issues and I would be more than willing to give this a try, but I doubt there is a way to open up an intake to 101mm UNLESS you just literally hog out the opening with the intention of using traditional type gasket material to seal the tb to the intake since the 90mm O-ring seal will be useless.
