Head sealing issue's we have been having head sealing issue's well atleast with one head on are 440LSX The right side was leaking (pushing water into the cooling system) after a set of heads where installed, It started leaking within 30 miles so we pulled the heads and went to the machine shop with them and the head that was leaking was not flat so he decked the heads just to get a flat surface. We use a new set of cometic gaskets and yamabond, at first it seemed ok but after two spray passes (180 shot) it blew the same gasket so now we are thinking that the blocks deck isnt square on the side and now we are hearing that the early blocks had issue's with head sealing (metallurgy) is this true and if so how early is an early block we have #272 |
Was the block decked? (seems like a silly question but you never know) I'm guessing a 4.185 bore x 4" stroke. |
Originally Posted by 99blancoSS
(Post 9897465)
Was the block decked? (seems like a silly question but you never know) I'm guessing a 4.185 bore x 4" stroke. I just pulled the right head and it was blown on cylinder 2 and 8, And when i just had the heads decked he told me when i picked them up that the right head was the only one that wasnt flat and that it was worse around cylinder 2 and 8 so i'm thinking that when the head is bolted down the block is warping the head. And yes 4.185 bore 4.0 stroke |
| All times are GMT -5. The time now is 03:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
