What other bolt-ons can I do that are easily reversible to preserve warranty?
Honestly. When you slapped the cai on there, it would've been best to tune it then. You're not benefiting much by wasting your money there. Just made the car a little louder is all.
As far as other mods...not much else guy...maybe a slightly smaller pulley. Although boost changes usually require a tune, I imagine the stock tune is super conservative and can handle an extra psi or two without needing to be changed.
Intake and exhaust is about it as far as performance mods go.
You could lower it or put different wheels on it, but I don't see the need on a new Z06.
+1 for wash and wax!
i wouldnt put it past ecm designers to have a record somewhere in the puter which shows the load data that exceeds oem specs. my onstar has a record of hard braking and hard acceleration data file. soo you should check your info before blowing your warrantee and motor
What to do to preserve warranty???? INSTALL NITROUS!!!
And then what? Rip the bottle, bracket, lines, plate and wiring out if something goes wrong? Or every time he goes for service if he does?
Possible to get an additional computer? It's not hard to swap those. Assuming yo u can get to them on these cars.
