Gen 5 pistons (5.3) Ok, I have been looking for some time now and Cannot find the answers I am looking for. If I missed a thread please let me know. I have a new gen3 block and I am wanting to put the gen5 flat top pistons (w/reliefs) installed on Scat I-beam rods(icr6100-927). I am building a high compression 5.3 and i was told the cam might cause PTV issues. The questions I have..... --- will the gen5 fit correctly in the gen3 block, I have not seen any builds for it, or any info on the pistons at all. --- do the valves reliefs allow for more PTV clearance on a 862 heads.(I don't want to assume). Plan for the build Gen3 5.3 block Gen5 5.3 piston Scat I-beam rod 862 heads (61cc) Stock head gasket 10.5:1 compression Carbed Cam motion "little chopper" cam If the clearance is there I would go to a Cometic .040 gasket and have the heads milled to 59cc, for 11.0:1 maybe a bit higher. Thank you, I have been snooping in the shadows for some time and thanks for the forum it is full of useful info. |
Gen5 5.3 pistons arent flat tops. Maybe you mean gen4? Your scat rods wont work with any ls piston. The pin is too small. They are all a .945 not .927. Gen4 5.3 floating pin pistons will work just fine but not with those rods. Youd need a scat 26100944P for them or a 66100945 h beam. |
1 Attachment(s) #19208675 (2010-14 Hummer) only descriptions I could find is flat top with reliefs. Is this considered a gen 4 ? |
Also the part number you have (26100944p) comes up as press fit. Atleast on Summit Racing. I will try to call scat today. |
That is gen4 vvt you have a picture of. The P at the end stands for Pressed. No one makes a stock length I beam floating rod in a 944/5 pin. |
Thank you for the knowledge. |
© 2024 MH Sub I, LLC dba Internet Brands
