Gen V lt1 (allen key) bolt torque spec Hello What is torque spec for cylinder head bolts ? also did anyone noticed the 13mm allen key head bolt on bank 1 ? it is shorter than the rest of the head bolts but with the same threads. also I need VVT bolt torque spec Thank you guys |
No one know the torque spec ? |
Have you checked a manual?? They do exist.. |
Originally Posted by G Atsma
(Post 19999767)
The torqueing order should be the same, but the actual torque figure should be able to be googled. |
from BTR , internal hex bolt ( 59 lb-ft - 90 deg - 40 deg ) , standard hex bolts ( 59 lb-ft - 90 deg - 60 deg ). |
© 2024 MH Sub I, LLC dba Internet Brands
