International Members For our members outside of the USA
Ls 1 overheated and turns over but does not start.
Old 09-26-2017, 10:08 AM
Christiaan93's Avatar
Default Ls 1 overheated and turns over but does not start.
Hello I have a 2005 Chevrolet Lumina 5.7 v8, which has the ls 1 motor in I stay in South Africa. I am finding it difficult to get any information on this matter. The car overheated and blew out some smoke and was dead. I towed it back home and started it after it cooled down it started idle for 5 seconds and then died. After that the engine turns but does not start. A local shop told me that the car has a bearing knock, which I am not sure is correct as my understanding goes the car will still then be able to start? I have little knowledge about engines and would like any help in this regard.
Old 09-26-2017, 10:16 AM
fst100's Avatar
drain the oil and see if the oil is milky or not. also check the coolant condition in the radiator and see if it also looks milky/slimy. but it sounds like the motor's spun a bearing.
Old 09-26-2017, 10:19 AM
The motor overheated due to a whole in the coolant reservoir tank where the water leaked out while driving and the oil had metal shavings is what the local shop told me.
Old 09-26-2017, 10:30 AM
fst100's Avatar
what color shavings and how big were the shavings? sand-like/grains or various sizes?
Old 09-26-2017, 10:38 AM
They did not say. Will try to find out from them. I have subsequently put in oil again as they only did diagnostics and did not replace the oil. Will it help if a drained the new oil again to see if I find shavings or should I look at the oil filter maybe? What type of shavings is bad news for me?
Old 09-27-2017, 07:30 AM
fst100's Avatar
cut open filter. if you see gold/bronze colored stuff in filter/oil pan, motor's most likely toast.
Quick Reply: Ls 1 overheated and turns over but does not start.
