View Full Version : Nitrous Oxide
- NX pressure switch gone bad?
- BMN Window Switch problems...
- Custom bottle bracket fabirication begins. LARGE pictures
- Window switch rpm question
- New to Nitrous
- exhaust smoke on the juice
- Switch panel harness
- Custom switch panel (pics)
- what sponsors have the IC spray bar?
- BURST PANELS how to on FAST
- someone please explain
- HSW wet kits...
- Will it work?
- Wide bands
- nitrous and car insurance
- how to mount the bottle?
- Autolite AR93 Nitrous Plug
- need help with rotating assembly selection
- Intoducing.. The Black Widow!!!
- solenoid trouble
- Who has Nitrous Injection Rail
- Selling my NX bottle opener
- First N20 Pass of the year.... & ever! (Pics)
- Venom nitrous kit????
- E85?
- Post Purge Pics!!!
- Texas Heat, How Much is TOO Much bottle Pressure?
- Possibley going TH400,vig 3200 ok for spray?
- Which plate do you like and why?
- blow down tube
- Will Stock Clutch Handle 100 Shot?
- Can I build a Dry Nitrous System from Parts?
- Best N02 kit for my setup
- Any one spraying 150 on stock fuel pump?
- Is 27 degrees of total advance too much for 150 shot?
- nitrous timing
- ATTN Nitro Dave!
- New member
- New N2O list! If you spray you must vote!
- 200 Shot recipe
- NOS brand bottle valve question.
- What kind of times to expect on a 125 shot?
- People who've installed DynoTune Two Stage RPM Window/TPS Switch PLEASE HELP...
- Just orderd some parts
- Do I need a fuel pressure regulator and FPSS? Where are they located?
- Opinions on best/fastest bottle heater
- wire clean up
- Nitrous/race parts for sale -
- Purge Help
- Good Nitrous Converter? Have SS4000/Getting New Tranny Perfect Time
- need help planning
- I sprayed 200 today and!!!
- Nitrous on 90,000 Highway Mile Car? Help!
- 9.3 video with hood ejection!
- NX bottle heater will not heat to over 800psi
- will an Lt1 nitrous kit fit an LS1?
- purging
- First Run
- what improvements did YOU guys see?
- Need a new thermostat for my bottle heater!
- Paging next!!!!!!
- finaly got some shake downs!!!!!!! new setup
- main feed line install
- piston in nitrous solenoid
- dry kits with 5lb bottles?
- Wrapped up on the Dyno 2 Stage Nitrous
- Lt1 Dual Nozzle Installation
- Diagram Request TB and Timing Tuner
- NX Bottle Question
- Pics of N2O setup
- Any place to hide a 10lbs bottle?
- Solenoids Noise
- Any tips on REMOVING the TNT power ring from tb?
- my wifes numbers
- edge or timing tuner
- nitrous not working????
- 90mm plate and stand alone questions
- Problems with tnt power ring?
- Why does my car Idle up 200rpms when my Window Switch is activated?
- Someone please check my wiring
- Bottle difficult to open/close
- Need help troublshooting NX 200shot on 408ci - low dyno numbers
- BIG shots on ls1 block
- I Hate the tnt power ring!
- Those with single gauge pods...
- Brain picking time...
- Dry Nitrous Kit Installation Tips?
- Set up for WOT?
- Window switch, tps, progressive programmer...IN ONE BOX!
- Do I need a Fuel Pump?
- Cam for 150 shot?
- How to mount the N/X (shark ) nozzle
- Where are you mounting your Full throttle switch?
- Nozzel holder?
- Solenoid problem
- Do you need a MSD window switch for a tune?
- FJO tuning
- Race Fuel with Nitrous
- test
- Sweet, Sweet Hardline
- N20 (300+) - what fuel are you using?
- How many runs down 1/4 on 10lb bottle
- why no lt1 guys using dry setup?
- Nos?
- Iridium plugs and Nitrous
- What else do I need???
- TNT Fuel solenoid sticking?Any one else?
- Question after MSD Digital Window Switch Install?
- Paging Nitro Dave
- To much gas
- NX Bottle weight
- Where to find switch panel.
- DynoTune Gauges Kick Ass!!!
- Plate System ?
- Any alternatives to TNT power ring?
- n20 help
- A little help please.
- switch panel
- Nitro Dave plate kit and 3500 2.5 str stall?
- N2O cam ?
- something went wrong
- Best Nitrous Kit for 98 Z28 DD (mostly stock)
- Nitrous and new Impalla SS
- anything like this ever happen to anyone.
- mallory 685 users...
- Beta Testing
- am i an idiot for going N20???
- Turn the bottle on and kill the motor instantly
- What to gap my plugs at?
- Thanks to Matt @ HSW...
- NOS controller 4 sale
- 400RWHP tired of getting beat by nitrous.
- HSW question
- Any good Nitrous Installers Near Northern Indiana?
- how many 1/4 runs on 15lb bottle..
- New NOS Controller for sale
- Msd Ignition
- ZEX or NX
- 5.62@120 with a 1.29 60ft on drag radials
- Need help with nitrous decision
- NX MAF question?
- Gonna get tuned
- a/f vs jet size?
- Nitrous Plug Size?
- Should I bump the jets?
- Why does a wet kit make more torque than dry?
- Hitting the dyno tomorrow morning..
- A Question for nitro daves stand alone fuel cell.
- Thanx Dave new lines are awesome!!
- Quick Operational Check
- Plugs
- Burst disc went off....couple ?s
- GTO Custom Switch Panels.
- Synergy All in One product line....
- Problems with my 5177 kit - need help
- C6 Z06 Video on the giggle gas, Bad Azz
- Nitrous works jets
- Need connector for harness...
- times on the dual stage
- Kudos to Ricky at NX
- Dyno tune A/F nitrous cutoff switch Q's
- Nitrous Heavy hitters.....PCM/EFI managment systems?
- N2O clean wiring pics
- Kicking around the idea of a DRY kit. Step inside.
- Nitro Dave' Customers Inside!!!
- NOS bottle safe on the trunk?
- Timing Tetard
- newb - dry 2 wet - mix & match zex & nx
- Guys with H/C motors and advanced timin
- Best Piston for Nitrous
- Few questions about the "Edge" from Harris Speed Works.
- Injector Spacer Nitrous Systems
- Bottle valve opener
- First time nitrous, need advice.
- Time for Nitrous!?
- how much?
- Is progressive controller good idea for 150 shot or less?
- Sneak Peak at a New HSW Plate Kit
- Where to buy new Nitrous jets for TNT kit?
- NOS Mini-Progressive controller FYI
- anyone know anything about ZEX? please help
- Who Makes The Best...
- Noyzee, Next, ESP, chef and many more in GMHTP
- Where is the filter on NOS 5177 kit? Should I have a seondary filter?
- 3qt fuel cell how quick out of gas
- New track Problem!
- Will I max out stock 75mm MAF?
- Nitrous Direct! Scott, pm clean out.
- Wet kit on carb... without plate..
- Wet or Dry
- stand alone fuel cell
- is it safe to run spray
- Spring Nitrous Kit Specials!!!
- Quick wiring question MSD WS box.
- Zo6 On Nos
- Install is almost there (pics)
- Jacobs mastermind?
- Anyone spraying on a yank 4400??
- Help me with the rest of my setup
- Tons of nitrous stuff for sale
- Purge Install Question - Do you need to drill?
- best dry kit???
- Removing a stuck fitting?
- /help me choose
- First Gear Lockout--Robert?
- Engine Build up
- Want to see the Zex kit innards?
- 11's capable with 100 shot?
- With my mods and a 100 shot, what kind of 1/4 mile times am I capable of?
- yaaaaaaaaaaaaaaaaaaa sprayed the 120 tonight
- quick question on the fuel side of wet kit.
- Rev limiter and window switch
- lean a/f
- First time nitrous installtion BIG!!!PICTURESS
- Nitrodave Help
- need help. FJO bogging
- Need TnT jetting asap
- 200 shot on stock 2001 z28
- Safe Memorial Day Weekend!!
- LSX w/ DP
- want pricing for..
- Nitrous (high miles LT-1)
- Hidden Purge?
- system will only work w/ jumper wire in on side of window switch?
- Wiring diagrams for Dynotune TPSWS and Wot switch?
- Nitrous Not used all the time, What to look for/Maintence
- Daily Driver Bottle Question
- 175 or 200 shot safe or not?
- High Mileage N2O...
- purge ?'s
- Anyone use the cold fusion plate?
- Polish TNT Bottle
- Wideband
- Yank Pt4000 with 100 shot?
- Wondering about #7.
- Preparing for 300 shot.
- times w/ and w/o nos
- threads on nozzles
- another newbe no2 ?
- Purge kit
- C5 install??
- Pro Shot & Sportsman Fogger ??'s
- Opinions on best Nitrous system for LS1 GTO
- Stock Bottom End + 200 Shot = Carnage Pics/Video
- no jets ok?
- Can I do a 200 shot?
- I've been busy this week!!!!
- Who has the fastest nos.
- Adjust FPSS or bigger fuel pump
- discovered my problem
