View Full Version : Nitrous Oxide
- spark plug selection/ timing retard
- How much HP do the little NX Piranha nozzles flow?
- How much is this Nitrous setup?
- Forged 408
- Diamond Nitrous Pistons FS
- 408ci motor ?
- Damn it, I maxed out the 4AN nitrous line.... 680RWHP & 770RWTQ.
- Closed November 23,24,25
- Hard line plumbing?
- 4 degree retard "feelable"
- TNT 150 shot!
- Nitrous install write up
- How much tq with a 100 wet shot???
- You won't believe what I was quoted to fill a 15# Bottle!!!
- NX Maf Plate...
- Timing Tuner Question ???
- What are some good head gaskets.
- Gauge Pod
- How can you build a standalone fuel system...
- Nitrous for the only mod?
- What Switches/Bezel Do You Have?
- Who here is running a NX Maximizer
- Nitrogen push pass tech?
- I need your input..
- Anybody have the Purge LED cloud illuminator?
- "Q" on what size oj inj.
- Anyone else done a purge like this before?
- Compucar "pills"?
- Anyone need any nitrous/fuel hoses?
- Picked up a partial kit...what else do I need? (Dave?)
- Need help hooking up fuel pressure guage
- do's and not do's of the nxl kit?
- Blow Down Requirements to pass Tech?
- Safest/Best wet kit for stock engine.
- NX-Cam Shaft Clearence Sell!!!!
- N/X wet kit for sale or trade!!
- Problems - Need advice
- Source for the cheapest FPSS
- NOS Pill sizing for a single Nozzle dry kit
- 5177 wiring ?? (Pic)
- Bolt On Motor. Dry Or Wet?
- Are Air Fuel Gauges that hook to the stock o2s "close enough"
- Introducing the DynoTune Time Delay Switch!!!!
- does n20 go bad if it sits too long?
- Solinoid Maintenace
- tr-6 question..
- Need some opinions on DP
- Question about wet vs. dry.....
- Winter Storage
- Rather safe than sorry!
- Wiring 2 Stage Kit to Work with 6-Speed.
- Nitrous question....can't find an answer
- Cold Fusion Kit Questions.
- NX Purge kit(pn#15600) tube
- Question about using tubing from 'noids to jets
- Wet conversion (shopping list)
- High Pressure or Low Pressure for DP
- hell fire rings
- Fuel system questions on wet shot in the S10
- TR6 is .040 cold enough?
- Props to Nitro Daves
- higher compression and spray
- How Many Of You Guy Are Running Your Nitrous Off A Button?
- Another direct port for you guys!!
- Inventory Moving Sell!!
- wiring diagram for NOS purge
- Nitro Dave's Halo Video
- The Christmas gifts are already arriving
- Big Props to Nitrous Daves
- New NX MAF kit!!!
- Dynotune Electronic Nitrous Activation switch - $65!!!!
- how come i never see any ADMIN's in this section????
- Getting Ready To Go On The Bottle
- Tnt Pro Dry Nitrous?
- New model NX Maximizer
- NX window switch killing my battery
- FS:Nitrous Express NXL Kit
- Opinions wanted on new solenoid type openers
- O2 voltage on the spray
- How much ET should..
- want to help me pick a cam?
- Looking for a basic/cheap controller
- You guys asked for it A TRUE 90MM Collier!!!
- extra fuel pump?
- Wiring a two step with spray
- My new bottle warmer
- need a cheap kit?
- New Nitrous Best at Thunder's ShootOut-Almost 9's
- what do u guys think my NX kitt is worth
- Ambiant temperature and bottle pressure
- what cams can/cant you spray
- TPS and FPSS acting up…
- Need some of your input on the Zex kit
- Nitrous tuning, spark plugs ect
- nitrous?
- NITRO DAVE insdie please
- F2 solenoids flow DP?
- Dry nitrous???
- C6 150 Shot ~ NEW ET
- 180 shot on mostly stock motor???
- NOS progressive cutting out?
- NEW!!!! Billet microswitch brackets....
- Nox question/ safey
- Dry vs. Wet Jet Sizes for HP levels
- FPSS Help! Please!
- Finished my fuel system.
- questions about shot size, timing retard, plugs and fuel pumps..
- 300 shot,on a 408?
- remote bottle opener?
- ALMOST done plumbing 2 stage Sheetmetal Intake
- nx bottle warmer solenoid
- Nitrous question
- radio 12 volt sufficient for bottle heater relay
- LT1 NX EFI Wet kit jet sizes
- Zex Direct port N2O set up for the LSX intake...
- Turning of the timing tuner
- Corvette WOT help
- Need higher octane?
- nos remote bottle opener wiring- HELP
- Please Help!!!
- Nitro question for a noobster
- New to Nitrous
- New Direct Port Kit!!!!
- Nitrous Switches
- msd window switch woes
- NX Nitrous parts for trade/sell?
- Icon Autosports does it again Nitrous, Nitrous, Nitrous!!!!
- how much hp can a stock 01 fuel pump support?
- What fitting for a FPSS?
- nitrous converter and a 2:73 gear question
- What gears with the juice
- 47 fuel 53 n20 = 100 shot?
- what other creative way have you hidden you bottle ??
- Bottle Warmer
- Bottle mounting problems?
- Dry shot -- Limits on H/C cars..
- Can my setup handle a 175 shot?
- Any new NX Dual stage pics out there?
- Paging Nitrous Dave
- Burst Disc HELP!!!!!!!!!!!
- NOS 5177 problem
- finaly, 9's!!!
- where to put a bottle pressure guage.
- tricks to heat up bottle faster
- How about this wacky idea...
- New to Nitrous ... 100 dry vs 125 dry?
- TR-6 plugs
- Direct Port Kit and Install for $135 ?????
- What Jets will TNT kits take?
- can you pull the fuel off of the return?
- Window Switch help!!!!!!!!
- Timing advise on spray
- Anyone spraying on a stock 10bolt?
- fuel press gauge after noid?
- safe n20 level for street?
- With a TH400, can I spray though the shifts - can I ditch my window switch
- How much do you pay for nitrous?
- NX question about jetting, need jet rec's for a 75 wet shot....
- Denny's Nitrous Ready Drive Shaft 4 Sale
- Halo kit install pics
- Anyone without window switch
- Spraying a 427
- Best N20 progressive controller?
- Where can you get brass nitrous/fuel tubing like in a carb plate?
- I need a NOS Fogger Chart "Jet Size"
- Should I upgrade the FP and which one??
- Something we got for the cobra's and lightnings
- Dry Nitrous Question
- Anyone use the HPE 90mm Nitrous Rings?
- Nitrous specialists come in.Who's running a dry kit and a cam on stock injectors?
- TNT Purge kit for sale!
- New times with TNT kit.
- Propane Pusher system...
- A/F ratios and N20.
- lt4 km and nitrous?
- Any such thing as a lay-flat N2O bottle?
- Will NOS solenoids handle 58psi?
- Custom Nitrous Pistons Pics
- HELP!!!! Stock injectors not good enough?!?!?!
- Tips to remove Nozzle from intake (locktite)
- dry kit
- question about timing
- Upgrade fuel system for a NX dual stage 150?
- looking for nx maf kit pics
- were and how much
- Who's running a progressive controller?
- newbie ? relay info.
- window switch instructions
- Best kit for stealth
- N2O Problems
- Dyno #s on the 225 shot......I need a bigger nitrous feed line
- Nitrous storage
- nitrous arming question
- Anyone use the Cold Fusion Opener
- Dynotune Nitrous 10% Off Halloween Sale!!!!
- 10.78@125 stock intenals DRY SHOT
- what is a good converter with a 231/237 cam and a 100 shot
- how easy is it to hide a halo system and how do you like it?
- 346 + H & C + 150 shot: Post your ETs
- here's a nitrous setup for yall
- NX Accumulators
- TNT 150 shot A/F 10.3-10.5:1
- Wiring TPS Switch to a Timing Tuner???
- Hey Admin's!! what do U think about Cold Fus Kits???
- Lets BUILD the BADDEST stock ci 346 Nitrous Motor..
- Free Shipping On All Nitrous Products Ordered During The Last Week Of October!
- Which Fuel Pump
- Which plugs do you prefer?
- Guys This is for you!!!!
- where is your purge at?
- TNT 150 - 250 shot + LS6 intake questions
- How much N20??
- got flamed today about nitrous
- M6/4.30 GEARS,26IN TIRE & 100 SHOT,WILL I MAKE IT THROUGH THE 1/4MI IN 4TH GEAR?
- 10% Off SELL ON PRODUCTS ON OUR WEB SITE.
- Running around with the bottle open?
- How does an electric nitrous guage work?
- how much does bottle pressure effect hp?
- Where to get these parts?
- Tall skinny bottle brackets?
- Nitrous Wet Kit Sale
- "Sneaky Pete Nos" kit?
- Another safe n2o question
- Setting up purge through Raptor Hood Nostrils
- Does the jetting for a dual stage kit change over a single stage kit?
- Question for the DP users.
- Serious wiring issues on my NX kit....
- compression and no2?
- 100 shot on a stock car. times?
- Please Advise on My 2 Stage Fuel System
- Lowest gear that will hook on the street with TNT 100 shot
- Hidding A Wet Kit ???
- nitrous filter???
- MAF screen removal, the final word please???
- need fitting for 5177, anyone have a #
- Any chemistry buffs?
- Pushed out a head gasket today
- N02 nozzle location question??
- Purges
- Opinions on these kits???
- Can this set-up cause problems?
- Am I going to run into problems running the FAST 90mm and the NX MAF kit?
- How important is it to use....
- Anyone sell single NO2 jets?
- Why does 5 and 7 cylinder always go lean
- Another newbie question.......
- nitrous question
- DP 300shot
- NOS nozzles VS. TNT
- n2o + TR230 111 LSA cam?
