View Full Version : Parts Classifieds
- ARP head bolts
- LS3 Plug Wires - AC Delco
- ls t56 fbody
- MGW Short Shifter - 93 to 02 FBody T56 Trans
- LS1 intake, On3 turbo, Mufflex, 10lb nitrous bottle
- N2O to Turbo- so all this stuff has got to go!!
- TCI Super Street Fighter #243110
- LS1 Exhaust Manifold / Header Gaskets (GM)
- Rajay turbocharger. Vband.
- Holley EFI Touch Screen
- LS Scat H-Beam Connecting Rods
- 97-04 A&A corvette supercharger kit complete
- LS7 Clutch, disc and flywheel
- Lucus 42# injectors
- ls1 f body oil pan ONLY
- Sold!!!!!
- FS: Injectors, pushrods, oil pump, brake pads
- Tubular LCA
- Texas Speed 347 short-block for boost - Good for 1000whp
- 60# FIC LS3 style short injectors - set of 8
- ARP, Koni, Edlebrock, Rollmaster, etc!
- Texas Speed Ported LS6 Oil Pump (SOLD)
- Lonnies Double pumper setup
- Tick Performance Blower Cam (SOLD)
- ls1 edelbrock victor jr...like new
- F/S Ross, NX, Aeromotive, Eaton, Reichard Racing
- Brand New All Forged 383 Short Block For Sale
- C5 Z06 transmission
- Ls2 throttle body
- ARP Thread chaser for Headbolts LS1/LS6
- Timesert headbolt thread repair kit ls6/ls1
- 80lb injectors, FAST 102mm TB, Methanol Injection kit
- SLP lid and Holley washable filter
- GMPP LS3 Valve spring kit
- Garage Sale
- SOLD: BLS Premium Kit (highs and lows)
- siemen/deka low imp 83# injectors
- WS6Lower Air box w/SLP lid and smooth bellow
- F Body power steering pump
- 36lb injectors => Ford Racing 30lb Red "Skinnies"
- LS7 Clutch and flywheel
- Ls6 intake with ported throttle body
- brian tooley racing stage 3 cam for cts-v zr1 cam
- LSX Gear of all kind- Keychains, License Frame, Trees, Hats, Hoodie and More!
- FS - Stock LS3 Cam shaft
- GT47-88 w/race cover & billet wheel
- SOLD Eibach lowering springs and bilstein shocks
- black door panels
- momo race steering wheel with adapter ready to bolt on
- LS1 parts,New CAM, lifters, rockers, MAF, timing chain
- ls1 intake ect
- Professional Products 85mm Throttle Body
- LM7 5.3 Build for Boost
- Tick Polluter V1 Cam- Used
- 4L80E trans fs with some goodies
- WTT/WTS 04 TI catback
- 17x9.5 Polished Weld RTS
- 2003 Z06 part out
- Aem UEGO wideband
- Custom comp cam caddy lifters
- LSX Turbo 400 ATI Converter!
- Hooker Aerochamber muffler
- C5 wheels and tires drag radials
- M6 Manual Trans F-Body wiring harness removed from 02 ls1 trans am t56
- ARE LSX Dry Sump Oil Pan, Moroso 22641 4 Vane Vacuum Pump and LSX Mount
- Lt1 t56
- new dynomax i-pipe
- Aeromotive A1000 regulator
- LS engine parts and management ,OLIVER,FAST,PRW
- ls1 short block. cnc ported 243's with springs
- Wolfe Racecraft 10 pt roll cage
- FS: new ARP main studs
- Texas-SPeed PRC stage 2.5 CNC ported 5.3L heads
- Parting Out WS6 and Formula
- Nitrous parts
- Ls6 heads and Ls3 heads for sale
- race star wheels package
- B&M sport shifter
- Basically Brand New Depo Headlights
- RPM 4L60e w/TransBrake
- Procharger Pulleys - Gates Green belts.
- PT 8285 CEA Ball Bearing Turbo
- Tick cam and nitrous parts
- TSP chromoly 7.400 pushrods
- Magnafuel 4303 - 3hrs engine dyno time only (SOLD)
- FS: Moser 9" for 4th Gen
- Ls3 boost cam
- Flowmaster y-merge and 40 series delta muffler
- Fbody console lid
- RHS Race Block *New*
- FS: ETP 215cc Heads, FTI cam, Manton Pushrods
- Sold
- (4)Nitto 555 275/40r17
- fast 65# injectors
- 5.3 and 6.0 parts
- LS1 stock cam, lifters, and pushrods
- 1998-2000 corvette wiring harness,ecm,DBW pedal.
- WS6 Hood Mirrors
- Fs - fast 92
- Clutch pedal from 02 Silverado
- Strange S60 + driveshaft. $1600
- LS1 SUPER STORE....Stock / Race Fbody / GTO PARTS
- c6 corsa exhaust, gm indoor cover, nav disc
- Sold sold sold
- Potz Ported LS1 DBC throttle body
- LS7 heads and Misc LS stuff
- Wiseco Pistons Upgraded S718 wrist pins
- d1sc procharger off of a tbss needs main brackets
- QA1 Shock Setup
- SOLD Brand New GM ETC 90mm Throttle Body Gold Blade 12605109
- LS1 coil wire pig tails
- Mallory Mech 0-80 psi fuel pressure gage
- Built 4L80E 2wd
- Ls1 crankshaft
- Ls2 low miles lifters
- LS1 Crankshaft and bearings
- 02 5.3 parts
- Odessy Battery hold down
- 85mm SLP MAF and stock MAF
- big cam for sale
- Carbonfibre LSX emblems
- Brand New TSP 228r and PRC springs
- Nick Williams 102 MM Cable TB.
- Nitrous outlet plate kit and stand alone
- 3 bar map gm bmr k member not a turbo one
- Madman sya bars, umi upper adjustable control arms.
- Stainless brake lines new bmr stainless radiator cover
- Professional products 85 mm satin intake, polished pp throttle body, and rails
- Tsp 1 7/8 headers new (they are out of stock)
- Procharger front mount intercooler (only drove to dyno)
- COMP CAMS 1.8 roller rockers BNIB
- Aster bracket water pump, cbr pulley 8.65 new ATI dampener used
- ls1 shortblock, patriot stage 2 cnc 243s, fast 90 direct port, Pat G cam, and more
- Ls1 t56 trans / Efi vic jr 2 stage spray bar setup
- Ls3 boost cam
- 98-02 F body headers
- QA1 rear f body rear shocks used 20 passes
- Fbody oil pan, bolts, and pickup tube
- Edelbrock Carburator Nitrous kit Universal EFI kit and parts
- Crane cams gold race rocker arms ls1/6
- Ricks SS tank for 69 Camaro
- 100mm maf sensor
- Racecraft black anodized lug nuts
- SOLD-GM LS3 Oil Pan Windage Tray & Pickup 12640748 Chevy Camaro SS L99 LS LS1 LS2
- Nexus boost gauge
- katech rod bolts
- LS1 Shortblock
- LS1 Shortblock
- 6an NOS nitrous line 14ft
- 4AN Nitrous body line
- GM LS3,LS2,LS6,LS1 12499224 Valve Springs with retainers and locks
- LS3 3 bolt cam 235/244 .621/612. 112+2 cam
- C6 LS3 Slave Cyl and flywheel
- Huge Fbody Part out
- Stock parts- power steering cooler,hatch glass, hood hinges, ABS harness...ect
- 4L60E with 90k miles
- ls1 and lt1 cleaning out party
- FJO Nitrous controller f/s
- efi live tuner
- moving to cal, garage clean out. kooks true duals. ss hood and more
- Accel 44# injectors (8)
- FRESH low mile 799 heads
- 3 channel 10 bolt 3:42 gear
- Crower LS1/LS2/LS6 shaft mount rockers, MSD LT1 Coil
- Boost Ready 370 w/ AFR 225's & ARP Hardware
- Tick adjustable clutch master cylinder
- Corvette crank pulley
- Delphi / MSD 50lb Fuel Injectors - Set of 8 EV1 LS1 LS6 Ford
- 15x10 race star wheel for 93-02 f-body
- Ls swap fox body turbo kit no turbo
- LS/A4 Engine Harness & PCM
- Wtt/4$ale s500sx 88mm t6 1.0
- Spec 3+ clutch, TSP headers, TSP cam
- LS6 intake manifold
- Good condition stock gen 4 rods, pistons, crank, front acc, valve covers
- LS1 fbody parts
- LQ4 partout
- Victor jr./Aarons 6061.com Elbow combo
- engine harness trans am taillights, seats shifter
- Tubular Bumper Support & Radiator
- 78mm FAST intake, Shaner ported TB, FAST 36lb injectors, stock rails...
- C6 Z06 wheels and Dark stars. California p/u
- Parting Out 1997 Trans Am ws6 Turbo LT1
- 2009 silverado injectors
- Monster transmission built 4l65 and 4000 stall converter
- hoosier bias ply 28x10x17
- Sleeved LS2 440", and 402 shortblock, and misc stuff.
- Et streets. C5 parts
- Brand New Felpro PermaTorqueMLS head gaskets.
- Clean LT1 Camaro tail lights
- SOLD - LG Motorsports F-Body C5 Brake Adapter Brakets and Stoptech SS Brake Lines
- MAP Sensor - Brand New Stock LS1
- On3 76mm turbo and On3 44mm wastgate
- Stock 04 Z TI mufflers
- Pcm green and blue
- 99 Firebird PARTOUT V8/AUTO
- victor Jr efi intake w/rails
- NEW Superhawk ram air hood, in gelcoat. 98 - 02
- 1 7/8 Hedman G Body Headers
- 2000 Camaro Ebony Dash Complete
- Complete 6.0L 2008 Pontiac G8 GT pullout L76 engine and 6L80 trans
- Brand new ls6 - 500+ hp long block
- ***Fast 90 nitrous direct port setup***
- Bunch of Fbody parts, GTO T56
- Complete A/C Turbo kit, 4.8 LR4
- AEM EMS 30-1220 Plug and Play standalone Engine Management
- CXRacing Aluminum Liquid Heat Exchanger Air to Water Intercooler Racing A2W
- Various auto meter gauges
- Lq9 D585 truck coils, Lq9 (non-egr) truck manifolds and 2002 Corvette cam
- Brand new Black 17x4.5 Weld Alumastar 2.0 w/ M&H tires!!!
- LSx Bullet Racing cam & swap parts
- Stock oil pump, LQ9 cam, manifolds
- FS:Fbody oil pan
- fast 90mm intake
- Gbody LS swap headers.
- UD Pulley, Fast 65lbs Injectors, Ev1 to Ev6 injector adapters
- TH350 trans, ATI manual valvebody/internals, ATI 8inch converter
- WS6 lower air box
- 98+ tail lights taillights from trans am
- 2009 aluminum 5.3 block
- Fast 92mm tb
- Comp cams 13755 rocker arm upgrade kit 1.75
- Stainless works long tube headers with y pipe
- S60 3.73 gears & 3.27 gears 2012 Camaro SS
- ls1 long block
- Nitrous cam, lifters, pushrods, and rockers
- LS2 402 shortblock or long block
- Sold please delete
- LS1 T56 transmission & Parts
- TSP CM Pushrods 8 7.350" 8 7.325" NEW
- Truck Engine Parts
- TSP LS3 grind Cam BRAND NEW
- TSP ported LS6 Oil Pump with o-ring NEW
- UMI Torque Arm relocation kit 98-02 F-Body
- viperized t56 blowproof complete setup
- ***brand new Harland sharp rockers
- 03 6.0 block ((sold))
- LS3 Engine part out
- 2800 torque converter driveshaft safety loop
- 98 Fbody parts
- Ls1 misc engine gaskets / bolts
- FIC 106 lbhr injectors @ 58 psi for sale
- 5.7 ls aluminum block
- Like new custom Turbo Cam from Tick
- ls6 384ci boost/nitrous ready short block
- Repro ZO6 wheels with tires
- Snow Wheels & Tires
- GZ Sportsman Vacuum Pump +
- FS:Holley LCD touchscreen
- UPR LS1 motor mount adapter plates for Mustang
