View Full Version : Parts Classifieds
- ACCEL 32 lb fuel injectors
- ls1 intake manifold
- Callies SBC/LTx 4340 Forged Rods w/ ARP2000 Bolts
- brand new siemens deka 60lb injectors
- Ported LS3 Intake
- ls1, ls3 , 67 camaro parts and more
- ls1 Supervictor FAST 4150 Induction Solutions
- ls1 fuel rails and injectors and tb
- Forged flat top pistons LS2/LQ4/9
- 2 bar map sensor band new
- 98-02 ls1 borla catback exhaust
- LT1 F-Body Pacesetter coated LT Headers
- Nice c6 Z06 wheels and tires $1000 no shipping
- prc 650 lift springs
- 93-97 & 98-02 f-body transmission crossmember
- Huron speed alternator relocation kit. (Top mount for turbo setups)
- TA performance 10 bolt rear end girdle
- Adjustable throttle cable adapter
- Gen 5 Camaro Fire Extinguisher Mounts for sale
- DEMOD SALE: Procharger, RPM Trans, 9", Forged Engine & MORE
- FS: Bosch 60 lb Ls3 Injectors
- SLP Center Caps
- Kwik Performance A/c bracket and 4665 Sanden compresssor
- G-Body BRP LS Swap Headers
- New MSD 8.5mm plug wires - 5
- fs: s475 stock cover
- Livernois Motorsports Dart Pro 1's clearance
- LT1 Cam - 230/246, 605/605, 107LSA - $100
- 12 ctsv rear diff Front runner tires
- 4 x 265/35R18 Brand New Yokohoma Advan sport A/S tires
- FS: OEM GM C6 Grand Sport Wheels
- Stock Valve springs and Pushrods FS
- SOLD Holley Hi-Ram, cathedral port, 105mm
- trex cam v2
- tuned by frost 4L80E swap harness
- Crower LS1/LS2/LS6 shaft rockers, BMR trans crossmember, MSD Coils for LT1
- 6.0 Iron Block (used)
- LS7 clutch, Ls2 fuel rails, C6 Manifolds Throttle body spacer and more
- WTT Hurst T handle shift knob!!
- Ported 243 Heads Patriot Performance
- CXRacing Aluminum Coolant Water 5 GAL ICE TANK intercooler Air-Water Drag Racing
- Ls1 f body turbo kit for sale
- 3.90 gto diff
- T56 6-speed manual trans crossmember
- MSD Timing Twister
- tbss intake and engine harness
- Racetronix 96 lb Injectors
- 60lb injectors matched flow rates
- 317 Heads
- Meziere Radiator Mount Water Pump
- Clear 6LE Honeycomb Tail Lights
- Siemens Deka 60 Lb Injectors SOLD
- 6.2L LS3/L99 Camaro JBA Shorty Headers
- Borg Warner S476R Billett T6 Turbo
- SOLD LS Oil Pan 12577396 SUV Truck
- HP Tuners VCM Standard
- f/s like new 799 heads with new brian tooley racing springs
- f/s like new ls6 rocker arms with new trunion upgrade
- f/s custom blower cam from martin at tick performance
- Red Top injectors, Edelbrock nitrous controller
- Lingenfelter 58x to 24x Conversion Module
- Rb brakes zr1 - rear rotors
- Lunati Cam
- Dsteck 2.5 bar map sensor
- comp cam solid lift camshaft
- 10 second 383 partout
- Meziere WP319U Water Pump
- Ported 243 heads and more.
- delete
- WTS: Fast 92mm TB
- LOW MILE 799 heads (SAME AS 243's)
- Big Stuff 3 w/ Wire Harness
- Heat/Sound shield, MSD Wires, AN fittings and access., Radiator ties, engine lift
- 15x8 weld draglites
- Holley 12-1400 Pump & Ricks Filter
- BNIB Comp cams trunion upgrade SOLD
- (4) Chrome Trans Am Wheels
- Autometer Gauges
- Yank converter f/S
- BER Ported LS3 intake, LS3 injectors, Holley Fuel rails
- LS valves, pin kit, ls6 MAF
- FS: 15x10 Polished Racestars
- 2015 corvette C7 exhaust maniolds. like new.
- Heads/Cam LS1 engine
- Sold
- Dirty Dingo LS1 conversion mounts for 73-87 2wd chevy trucks (BRAND NEW)
- 4" exhaust piping (misc bends, etc...)
- FS - Stock LS3 heads, complete - 35k miles
- Edelbrock Pro Flo fuel rails and Scoggin Dickey 90 mm
- Libertys built LS1 T56, Spec clutch
- (SOLD) Hurst T-Bar Shift Knob (SOLD)
- MMS larger 6 Rip crank pulley for procharger
- C6 Z06 Manifolds and Mid-Pipes (Cats)
- RPM FBody Level VI T56 Magnum Transmission *NEW*
- FS: Brand new ARP 134-4701 Stud kit
- Somebody get this 10 bolt out of my garage
- Ls2 engine harness
- Corvette C6 OEM drivers side airbag
- 2 OEM Firehawk Wheels
- Corsa Exhaust C5, Meth and a bunch of other parts
- 99 Camaro Z28 1SC, 1SZ, Y3F partout (Roller). 30th Trans Am Seats
- LS1 Engine parts, Wheels and tires, Car Audio Amps
- 93-02 Low Mileage Camaro Parts.....
- PRC LS6 heads brand new in boxes
- Performabuilt Level 2
- LS2 engine covers
- Scat H-Beam Rods SOLD
- WTS C6 Rear Drag Pack
- FS: TBSS Intake Manifold + Fuel Rails
- "big shot" wet nitrous kit for efi with purge
- Viper spec T56
- Walbro 255 intank pump and custom ground cam
- 6.2 engine & 6l80 stall
- Turbo Trans am Roller moser 9"
- LS1/4L60E standalone harness
- Professional Products 85mm TB
- Procharger Bellmouth Truck Hat
- GTO LS2, oilpan, tray, pick-up
- Eps cam
- Truck magnacharger trade
- For Sale - LS9/LSA injectors
- Nitrous Setup for sale! add-ons not just a kit
- Rotating assembly
- Turbo Cam 226/235 .605/.610 HR118 +4
- nitrous power ring, ls3 head studs, solid mounts
- FS: Comp Ultra Pro Mag LS3 Rockers & New LS7 Camshaft
- Magnaflow exhaust fbody
- yella terra 1.8 rockers
- WTB 04 Z catback
- TEA/Trickflow 220 As Cast LS1 heads SOLD
- T-56 Complete Transmission 79K miles
- Diamond Pistons 4.010" bore 4" stroke SOLD
- LS3 heads complete 0821 castings
- Fs::edb-30174 4 series positrac
- Garage Sale, LS2/3 Cams, f body ac,strut tower brace, arp crank bolt...
- WTB F body accessories
- clean F-Body oil pan SOLD!
- 1998-2002 Camaro SS hood real oem "grill" SOLD
- brand new gm clutch master cylinder
- ls7 clutch, and flywheel low miles
- Parts for sale
- Injectors 60# and 30#
- fast 92mm intake
- WTT/WTS 17x9 and 17x11 Staggered zr1
- SLP Blackwing Lid - First $200 gets it.
- Built T56 2.97 1st
- Nitrous outlet Direct Port kit price lowered
- Fast LSXR 102 intake/NW 96 TB/RHS tall deck adapters prices lowered
- 315/60-15 Mickey Thompson ET Street Drag Radials
- FS: RPM 4l65e Conversion
- FS: NW 102, ARH 1 7/8 to 2" headers, SD 60lb Injectors
- 42lbs Bosch injectors - $100 shipped
- Parting out 383 LT1 LE2 Heads LE3 Cam PSI Harness
- Built 4L60e Trade for T56
- 1998 LS1 Firebird Complete Part out
- Sandblasted front/rear covers, valley covers, Pistons/rods with ARP, 24x Crank
- l76 6.0 crank rods pistons
- Misc parts - MAFs, O2 Ext's, injectors, TStat / Neck
- 87lb fast injectors.sold!!
- stock untouched 243s
- C5 Corvette 17 in magnesium wheels.
- Valley Cover Plates (waterjet aluminum) w/ Knock Sensor Delete
- ls1 Scat H Beam rods/ARP-Mahle Forged Pistons
- Ice Water to Water Fast Turn Around Radiator Complete System
- Ls1 parts
- $300 off!! NEW in BOX Magnaflow Quad Tipped Cat Back Exhaust Southern California
- LSX swap headers for 82-92 Camaro / Firebird
- l92 truck intakes complete with rails and injectors
- BNIB Magnaflow 3 Inch Muffler
- Pro 5.0 Fbody Shifter w/ UMI Short Stick
- 98-02 oem headlights
- 4l60e Valve Body - LS1 MAF Sensor
- AMW aluminum oil catch can
- ARP rod bolts LS1 134-6006 new set
- fS: LS6 intake with TB
- Autometer gauges
- Tick Performance custom LS3 cam, 4.065 Cometic gaskets, ARP head studs
- LS6 fuel rails
- Auto meter gauges for sale
- Yank 4000ss
- F-body 4l60e 20k miles
- POR 15 super starter kit and Blackcote paint
- GZ Motorsports vacuum pump kit
- Spal 11" Curved Blade Puller Fan
- sold
- SOLD - Car cover for midsized cars - SOLD
- 6.0 LQ4 Complete Intake with TB, sensors, injectors and wiring harness
- LT1 1LE Induction Elbow and SLP STB
- (2) Berger Panels
- Cam and 78mm nitrous plate!!
- prc 2.5 5.3 cnc ported heads
- Ls3 heads, new valvetrain, decked .035
- P-Ayr foam LS1 block, ARP head bolts, fuel injector spacers, GTO covers, DBW stuff
- Garage Clean out 1967-69 Camaro stuff and More!!
- PAC 1518 Springs, Rockers with trunion upgrade, LS6 Block
- 01 camaro ls1/a4 engine harness
- LSx Parts Sale:Pullies,Tensioner,Swap Oil Pan,Boost Controller,Electric Water Pump
- Callies LS1 6.125" Forged H-beam Rods
- 2001 Camaro Ebony Front seats
- aeromotive stealth fuel pump 11140
- FS 2014 LT1 Z51 C7 dry sump 6.2 motor
- LS3 ThrottleBody-NEW
- LS3 Head Gasket-NEW
- Holley Intake Package
- solid roller comp cam and lifters
- 2004 5.3 Engine
- Wilson Elbow
- Painless car wiring kit (sold)
- ARE Dry sump for sale (Sold)
- Motorsport Tech 1.75 Hub & Wheel Centric Spacers - NEW
- 6.0 LQ4 crank pulley
- LS1, SBC and misc. Parts
- 93-02 Weld Prostars Powdercoated, 28x10.5 with hoosier front runners, trade for ?
- Universal air ride kit
- LSx Centrifugal Supercharger Cam - 252/274 .646/.629 113Lsa+4 - $250 shipped
- Fresh Complete 243 heads cleaned and milled .040
- UMI ROD end upper and lower control arms brand new
- BUILD PART-OUT: stock LS3 w/ 5K miles, CTSV Accessory Drive, T56, E38 PCM,Aftermarket
- Complete AFR 210 heads like new
- LS2 Blocks and LS2, LS3 and LS6 Intake manifolds in South Jersey
- SOLD: Nitrous kit with NANO, MSD RPM window, Dynotune Progressive
- Tick solid roller cam and main bearings
- 799 and 317 heads for sale
- 383ci LS forged short block
- LSX Race Car Part Out Houston Tx ^v^
- 411, 896, 242 PCM's
- WS6 Wheels, Tokico Rear Shocks For Sale
- 10 bolt rear
- PTC 4l80 converter
- FS: LS1 motor 800rw+ on 93 octane, 155mph 1/4, 185mph 1/2
- Fbody Accessories, brakes, and etc.
- Billet Specialties and UMI performance
- K&N 599-57-3022-2 bbk long tubes
- 1.8 roller tip trunnion rockers
- ASA cam, springs, seals
- Factory ls1 injectors
- comp custom grind turbo cam w/springs
- C5 Corvette 50th Anniversary Wheel/tires 18/17 $800 INCLUDES SHIPPING
- accel dfi gen 7 with pro key software
- FS/FT 1998 CAMARO Z28 6spd ROLLER - FULL SUSPENSION & CLEAN TITLE
- D 85 coils take off, full brackets and harness with new ls2 red wires.
- 2005 C6 corvette Rear diff
- LSA valve covers
- FS: LSA new valve covers with gasket/bolts
- N20 full kit
- BRAND NEW IN BOX Tial 38mm Wastegate - comes with 2 springs!
- 0411 PCM's
- LQ4 parts: intake, oil pan, water pump, along with gen2 parts
- 243s with Brand New Valves
