View Full Version : Parts Classifieds
- Dynojet WB, Spec Stage 3 Clutch, Flaming River Batt Disconnect, LT4 Valve Covers
- 411 pcm programmed to your vin
- FS: 15x8s 5.5bs weld rts wheels
- TSP 231/236 LS3 cam
- Built LS1 engine
- Hooker long tubes, UMI strut bar
- Magnafuel 4303
- 98-02 LS1 Camaro/Firebird O2 Sensors
- Fast Fuel Rail ( Black ) & Line Kit
- CTS-V deck lid (lip wing) spoiler
- 2000 ls1 5.7 engine only 80k longblock with ls6 intake
- Magnaflow Competition Series Stainless Full Exhaust Gen 5 Camaro
- Bnib Holley dominator efi for Ls with built in trans controller
- Comp Cam, 243 heads, 317 and 862 heads
- F-body Tr6060 ZR1 MH3 ratio
- LSx F-body F1C procharger kit
- clean up for grand national parts
- stainless steel camaro headers
- Bunch of parts
- Bunch of parts
- 5.3 V8 + 4l65 transmission
- LSx Shorty headers
- LS1 Bolt on parts and custom stereo stuff
- Texas Speed 224R cam 111deg lob sep
- Powerglide WTS/WTS $1600
- Chrome Firebird rims with tires
- 98-02 original firehawk hood and wheels
- A2W Twin Turbo setup
- ls1 block, manley billet rods, covers, 6.0 crank and more
- WTT LS3 Nitrous Outlet Money Maker intake manifold for FAST
- BMR Xtreme Anti rollbar
- Ported LS6 Oil Pump Hubbard Racing-New
- 98-02 Camaro Front Clip LTX-LSX conversion
- 4th gen Griffin Radiator 6-598ae-jxx
- Kooks headers
- TH400 and converter for LS motor
- LS1 block, Trickflow heads, Jesel Rockers, valvetrain
- mallory fuel pump, holley fuel filter
- Like new cooling mist meth kit. (dual nozzle)
- 99-02 racetronix hotwire nib
- 0411 PCM with HP Tuners 3 bar OS, AMS 1000 boost controller, LNC2000 2-step
- PRC LS3 250cc 6 bolt heads
- ***SOLD***HKS SSQV BOV Black Series
- Forged ls1 shortblock
- T-Top conversion setup from 95 Z28.
- L76 heads
- Gentex Auto Dimming Mirror w/Homelink, Compass, Temp
- Fast 92 intake
- GM 6.0 Long block LQ4 truck engine 140K ran great
- ls1 stock cam
- Bose, ac delete, lt1 hoses, abs, misc
- OE Wheels
- ls1 style taillights, stock slave/master cylinder
- 4 truck coils, 2 brackets, 2 harnesses
- Sold! NGK AFX wideband
- C5 m12 tremec trans and 3.42 getrag diff
- Ls6 intake for sale
- LS6 injectors, 317 heads, stock lifters/trays, truck manifolds
- FS Lt1 Lunati Hyd Roller Cam and Springs
- Hankook ventus rs3 tires 225/45R17 & 285/35R18
- SOLD procharger 8 rib pulleys, 4.25
- Used/New F-Body parts, ECM Blackwing Wheels Tire Manuals WP Exhaust Calipers Convert
- Double adjust coil over shocks
- Spec lt1 flywheel sc85s
- SOLD!!!!6literdesign 2-guage A/C plate
- HP tuners pro SOLD!!!!!!
- NX Maximizer 2
- Vortech LS1 F-Body Supercharger Kit
- Built ls engine
- Stock parts (LS6 85mm 5-wire MAF, LS1 MAF)
- Team Z Motorsports LS K member mustang SWAP
- Stock LS2 Cam and LS6 Springs
- Ls1 coils, stock clutch master cylinder.
- Wcc air bridge for sale
- Prices Reduced: <<<95 OBD1 & 95 V6 F-body PCM >>> N.I.B. 1-7/8 Hedman Headers
- G-Force Black Camlock Harness
- Ported LS3 heads (821)
- Some car stereo stuff F/S
- FS: 345/30/18 BFG Drag Radials
- FS LS9 camshaft less than 100 miles on it
- SOLD Mast Motorsports LS7 305 Heads NEW T&D Rockers Precision Metalcraft Intake
- HP TUNERS PRO used
- New L92, complete from pan to intake. All accessories!
- 99 camaro manual trans crossmember
- FS: various fbody parts
- Sold
- Bmr strut tower brace
- WELD RTS front runners
- Precision 7675, Precision 46MM WG, TurboSmart BOV, other various turbo stuff inside:
- black trans am driver and passenger mirrors for sale
- sold
- flat black weld pro stars 15x3.5 and 15x10 7.5 bs
- MagnaFuel Fuel Pressure Regulator and Filter Assembly
- Racetronix 37# LS1 Fuel Injectors
- zr1 wheels and tires
- long tube header torque arm mount
- viper smart start..start car with smartphone
- 8.8 rear swap start
- FS: ls6 valley cover. #12568002
- garage clean out lt1 parts and ls1 header gaskets
- LS2 MAF sensor w/pigtail and adapter
- LS1 Parts-Priced to sell!
- Hp tuners pro
- Slp lid,stock maf, slp smooth bellow
- Ls parts
- New Comp Cam
- 4.020 Head Gaskets, LQ9 Crank, 317 Heads
- fast 65lb fuel injectors/ev6
- LS1 intake manifold
- Fuel fittings -6 AN and adapters & 2 bar map
- 16K DeCarbons
- Fast XFI engine management and harness
- BNIB autometer boost & fuel gauges
- Bnib 80lb injectors
- GM Test Motor/What Is IT
- 0 gauge and 4 gauge wire
- Stock Ls3 block 50k miles, oil pan,crankshaft
- 06 gto ecu/pcm e40 vats removed
- 98-02 Camaro Headlights Clean!!!!
- Powerdyne Supercharger, 98-02 F-body
- 98-02 OEM Camaro Headlights
- kooks 1 7/8 coated lsx mustang long tubes headers + bbk 2.5” h-pipe
- Fast 85LB For Sale
- Time Sert Head bolt hole repair kit
- A/C Compressor, 243/799 heads
- barely used CompCam LSR - 243/259 @.050 .624/.624 114 LSA
- KYB AGX Adjustable Shocks Front and Rears with Stock Springs
- SOLD!!! Front Cadillac CTS-V Brembo calipers; PRICE REDUCED!!!!
- BNIB 2014+ Silverado BakFlip G2 Tonneau Cover 5.8ft beds
- 02 Trans Am Part Out
- 6LE Carbon Fiber Sail Panel
- ls2 injectors and comp cam 918 valve springs
- Bosch 044 fuel pump NIB
- Powder coated covers
- YANK SC3000 4L80E Converter.
- Magnaflow Center Mount Exhaust Quad Y pipe
- Autometer C2 gauges for sale W/3 gauge pillar pod
- ****edit****factory C6ZO6 Speedline wheels
- Billet Specialies Street Lites
- LS3 DBW throttle body
- PRICE DROP *****T56 Crossmember, 3.42 gears, Auburn LSD, stock 4ch axles*****
- Gen 5 Camaro, Twin Turbo, Starter kit
- Sold!!!
- 98 Camaro V6 78k Part out, gray cloth
- 799 heads with patriot dual golds.
- ls2 243 heads rockers and throttle body #sold#
- Hendrix Engineering GTO strut tower bar.
- complete LS1 Engine (2001 Camaro)
- FS: Baer/Alcon Front Brakes
- CCW classic race wheels HOOSIER R6 c5/Fbody
- **TH400 drive shaft, MAF, timing/valve covers, flexplate**
- **SOLD!!***Turbo Smart 38MM Wastegate w/7# Spring
- Viking DA coilovers for 4th gen
- FS: Arp Head Bolts
- comp custom cam
- 93-02 Fbody Hotchkis Performance Rear Lower Trailing Arms
- Asp powerbond underdrive pully
- Trex v2 cam
- LS7S Texas Speed Cam and 80# LS7/LS3 injectors
- OEM LS3 Intake Manifold with Fuel Rail, Injectors, and Throttle Body
- Bbc eagle forgrd crank
- 4340 4" Forged Eagle Stroker Crankshaft
- LS7 Oil Pan+pump
- K-frame and coil overs
- Fs::: msd ls starter(sold)
- LS Items For Sale!
- Holley Blue pump brand new in box
- LS1 Water Pump
- rpm level V 4l80 w/transbrake
- Manton 7.500 11/32 Series 5 Pushrods with Tool steel tip on one end
- L92 heads 823 castings
- Corvette Accessory Drive - $450shipped to lower 48
- Factory WS6 Ram Air Lid/Air filter assembly
- V band Truck Manifolds, BW S366, Procharger Intercooler, Truck Intake, etc.
- 2003 5.3 truck manifolds
- PT 7675 turbo
- all pro -1 heads & 427 shortblock
- Performance Design Carbon XR Carbon Fiber Dual Plenum Dual Throttle Cross Ram Intake
- L92 Valley Cover (non-DOD), T56 shift knob with button
- 9" inch ford third member center section - $650
- FS: HP Tuners Pro w/3 Bar SD, ECU, Laptop, and Wiring
- Misc. parts for sale, PCM, LS1 acc. parts, Intake
- Stock lq4 heads an rockers block an more
- wheels/tires and misc parts 4th gen
- LS6 Intake
- 2007 Corvette Z06 NPP Exhaust + Exhaust Commander
- Flex a lite 118 16" puller fan only used once!!!!
- LS3/LS7 60lb Fuel Injectors
- Dirty dingo alt/ps ls1 bracket
- BRAND NEW DIABLO inTune i1000
- Cp coated 4.185 bore pistons
- Pro 5.0 shifter with Lou's Short Stick
- FIC1000's
- Jesel Y2K For ETP heads
- Ls6 Intake ls6 tb
- Dart LS Next oil pan Stef's
- LS3 offset rockers used with Comp Trunion Upgrade
- Nitrous Kit. SOLD...
- 2002 WS6 Wheels with M&H 325/45's on them
- Everything has sold.
- Stock 10 bolt and springs
- Ls3 maf,speartech ls1 to ls3 adapter and corvette filter/regulator all parts new
- 6L90E transmission
- Front Bumper Cover 2001 Trans Am WS6
- Nitrous parts FS:
- NOS Remote Bottle Opener
- FS: Truck intake and 862 heads
- SALE! Cleaning out shop
- LSX Motor Swap Part Out - LS1 Parts
- Racetronix fuel pump & hotwire kit
- Sun Scope Engine Analyzer
- FS: 2002 Camaro z28 coupe hardtop (No sunroof) 92K 1owner Black/Black Leather Roller
- LQ4 intake,fuel rails,injectors,sensors and throttle body
- Gauging interest 93-97 sail panel
- BRAND NEW sparco chrono road seat
- F-body ORY and full Magnaflow exhaust
- FS: LME LSX 427 Longblock
- Ls1 t56 six speed everything but pedals
- AC Delco Fuel Filter
- Weld Prostar Wheels (15 X 3.5) & Mickey Thompson Sportsman Front Tires
- Hurst lineloc *NIB*, Stock Rockers w/ Stands, Truck Intake w/ Rails & Injectors
- c6 corvette covers bnib obo
- LS1 ecu and engine harness
- Iso: dual valve springs (.650 lift or more)
- 799s Advanced Induction 226cc heads
- Nitrous outlet 78mm plate
- 3 chrome 10 spokes and eibach sportlines
- BBK LT Headers and ORY Y-pipe
- Bosch Injectors, LT1 cowl hood, 98 T56 engine harness, PS rack,
- Parting out 2000 SS Camaro
- Stock LS1 Parts, Vette Bell Housing, Diablo Tuner U7193
- Comp Cam 251-268
- Strano Springs Koni Yellow Shocks Control Arms
- 4L60E Tranny: 3.4L V6 Camaro/Firebird
- WTT: 408 Stroker Iron Block w/LS3 Heads for Stock LS3 with Cam
- Fast 92/92 and 46lb injectors
- LT1 Powdercoated Valve Covers FBody SOLD PLS RMV
- LT1 Ported Intake and TPiS 58mm Throttle Body
- Cometic 383 LT1 SBC gaskets .40 thickness
- Jesel 1.5 SBC/LT1 Shaft Mount Roller Rockers
- Scat 4340 LT1 383 Crank
- Canton Oil Pan LT1
- FAST billet fuel rails, installed but never run
- NEW LS3 Valves. LS2 Flywheel. Other parts.
- 6.0 parts clean out
- ***SOLD***Brand New Exedy Clutch Assembly for LT1
- MSD Ls 2step
- FS: JL Audio Slash 300/4 V1
- MAC Midlengths + gutted cat ypipe, and pacesetter cat ypipe
