View Full Version : Parts Classifieds
- -15cc forged wiseco for 4" stroke (4.030)
- T-A4756 - For using a LS1/LS6 injector with a LS2/LS7 harness
- ls2 cam
- looking for valve covers for adj. roller rockers
- Halltech CAI & NW 102 TB
- New single RHS Pro Elite LS1 head 54210 Price Drop
- Torque Thrust II wheels, BMR LCA etc.
- New 4.060 2816 stock stroke pistons
- NEW - FAST 102MM Intake Manifold Cathedral Port (LS1/2/6)
- TCI Paddle shifter - Polished brand new
- Powdercoated Coil brackets with truck coils
- LS2 intake manifold with fuel rails and injectors
- Nitrous Kit + Accessories
- Polished ls1 valve covers
- Tick Performance Blower Cam--idled 3 times.
- C5 engine harness
- FAST dual AFR for sale
- Diablo SLP tuner
- 3" Electric exhaust cutout brand new
- Pair of SLP Power Flo mufflers NEW
- f/s brand new ecs boost a pump
- f/s Ecs Siemmens Mototron 60lb Fuel Injectors - LS1 Style
- Lq9 aluminum 317 heads
- PRC .650 dual valve spring kit
- Single Turbo 76mm kit
- ls2 intake and rails
- Delphi MAF 85mm (GM# 25168491)
- Comp Cams lifters NIB 850-16
- Complete LS1 rear brake setup
- SOLD: Complete HSW Nitrous Plate System with Microedge and The Interface
- complete th400 swap for t56
- Throttle Body sensors with nice finish!
- PRO 5.0 power tower shifter for t-56
- LTCC kit, brand new in box
- 95 Z28 Part-out plus 5.3 LS Shortblock
- FS / WTT : 4 way steam vent / coolant crossover
- FAST 102 fuel rails New-black
- SLP Lid, SLP Ram Air, smooth bellow, LTs
- Lnc-2000
- rear diffuser 6LE 93-02 Trans Am
- SLP air box lid
- Zex nitrous kit
- parts for sale
- black TT2's with good radials!
- Turbo Ready L33 5.3 Aluminum complete motor Coils to oil pan
- FS: new bosch 80lb ls3/7/9 injectors
- 7.5" hardened pushrods
- Kooks afterburner axleback GTO $300
- LS1 built for boost - forged rods n pistons - arp everything!
- Gauging Interest: UMI Suspension(Roto/Poly)--Wolfe 6 Pt Cage--104mm FT Lid--MORE!!!
- F1x procharger/cog setup/bell Intercooler/ carbon belt
- 96/97 OEM SS Spoiler
- induction solutions 4150 black widow plate
- FS: 5.3 LY5 short block
- WTT Snap On Tools for parts
- F/S CSU carb hat
- Qa1 SA rears and 315lb from QA1 springs. cheap
- LSX Trickflow pushrods 7.425
- LS6 manifold, Hurst shifter and coolant hose
- Fs:bnib c6 z06 ecu
- BNIB Comp Trunion Kit SOLD
- F1A procharger kit for G8
- TSP MS3 @113 LSA cam w/ 5k, Hurst T handle
- F/S: Cats
- Arp main stud kit iron block ls lq
- Schwanke Road Race LS6 Short block
- UMI Torque Arm Relocation, Monster Stage 5, Tick Master, t56, Pro 5.0, SLP knob
- LS2-LS3 Connecting Rods
- Hawk Ceramic Front Pads (Used)
- 98-02 Camaro Chrome Halo Headlights
- Misc Items For Sale (Cheap!)
- Accufab 105mm 86-93 Mustang 5.0L Throttle Body
- 82-02 camaro/firebird rear Coil Over kit w/150 springs. NEW!
- FS: Two Kosei K1 - Damaged - $50
- LS1 standalone wire harness
- Ls1 cam 238/242
- Pontiac G8 GT 19" wheels
- 2 On3 turbo blow off valves
- 2002 Ls6 short block 1800 ORG Miles
- F-BODY LCAs
- LSX Cometic Head gaskets
- 82-92 d1sc procharger camaro/firebird
- eibach drag launch kit
- FS: Improved Racing Oil Pan Baffle for Gen 5 Camaro SS
- 2bar map sensors new
- siemens deka 60 lb new
- Rossler 4L80E Trans-Brake
- Fbody, Wolfe 10 pt, VFN roller
- WANTED: Auto Console Top Ebony
- Nos cheater kit with purge and leash electronics nitrous board
- SLP Oil Pump
- LS1 Victor jr intake and MSD 6010
- Mast carb intake
- CNC heads, 42lbs inj, carb jets
- efi live v2 with 1 credit
- oil pan windage pickup
- fast 90 with direct port
- Kooks 2" Headers Stainless
- ISO-WANTED F-Body Suspension
- SS emblem for Fender '69-72 camaro
- 93-02 camaro firebird oem shifter assembly 700r4 4l60e
- BMR extreme duty torque arm
- FAST 90 intake
- Sold - 95 Camaro Roller - LS ready Caged 8.8 Rear Full Suspension - Power Glide
- QA1 double adjustable rear shocks
- 2009 cts-v blower assly. Few extra parts.
- 98 Wiring harness
- LS2 Fuel injectors
- RED 98-02 SS Hood
- LS1 Camaro Radiator
- LS1 Camaro Flywheel
- Valvesprings, Air Intake, LQ4 Accessories
- LS6 Intake Manifold Painted Gloss Black
- LQ4,LQ9,5.3,4.8 24LB injectors
- Custom Alum Driveshaft - 4th Gen TH350->12bolt
- Accell DFI gen 7
- **** SOLD**L92 Short block -Fly cut pistons- priced to sell $2200.00****
- LSX stickers that fit the Ford emblem
- Seven gen 4 pistons (floating)
- ARP Rod Bolts 134-6006
- Morel Hydraulic Roller Lifters (Link Bar) (5206-HYD) Free Shipping & PayPal Fees.
- Two sets of interior for sale.
- Very good condition 243 heads
- camaro ss go fast parts
- Comp 7.4 hardened push rods
- LSAheads and built LQ4
- SLP Loudmouth 1
- LS1 Intake Manifold
- 10bolt, 2.73s, 3 channel
- 18x12 House of Wheels C5 Z06 chrome replica wheels
- 393 Stroker LS1 with Frankenstein heads - Complete motor
- 243 Heads, LS6 Cam, and more!
- LS1 LS2 LS3 LS6 L76 DBC bracket
- WTB: trans brackets !!!! NEED ASAP!!!!!!
- kooks stepped race header 1 3/4 1 7/8. 3.5 collector
- LS3 mast intake
- Tilton LS Flywheel
- FAST LS3 intake with injectors, rail, map sensor, hardware
- ls1 parts
- Ls6 intake and N20 plate
- FS: LS2 Oil Pan
- 2001 6.0 4l80e harness/411 ECM
- 5.3 parts and accessories
- Milled LS3 heads w/btr 660 springs
- Compete LS1/4L60E, complete rear end, chassis harness
- Comp Roll Cage, Edelbrock Subframe Connectors
- FS: Hotchkis STB and NIB ARP Main Studs
- 17" American Racing Tourque Thrust M rims with tires
- ls1 take out, misc covers, mwc torque arm, tires
- LS1 Forged rotating assembly
- Precision pro mod 91mm Turbo
- Ls6 intake, turbo hotside, 4l80e etc
- Painless performance 12 circuit race/prostreet wiring harness
- 02 Trans Am Part Out
- LSX Leftover Parts
- 98-02 Fbody carbon fiber sail panel
- 93-02 F-body Wilwood 6 piston brakes
- 98-02 F-body M6 crossmember
- Misc LS1 engine sensors
- 6L80 Transmission out of a 2012 SS Camaro
- aeromotive fuel pump m/t front runners optima solid motor mounts
- 4th Gen T-56 Trans mount
- 799 heads
- LS1 LS2 LS6 Rocker Arms with New Comp Cam Trunion Installed
- Msd 6ls2 #6012 SOLD!!!
- Turbowerx EXA Pump
- LME nitrous 408 for sale
- C5 corvette calipers
- Lid, seat belt guides & serpentine belt
- computer from 99 z28 w/ custom tune
- 99 Trans am LS1/T56 parts
- passport 9500ix
- 2005 GTO Stock parts. Under 5k miles!
- Zex Wet Nitrous kit
- trick specs cam/ Texas speed 1 7/8 headers and offroad y pipe/ diablo Trinity tuner
- Ebony Rear Seats
- 2 wastegates 38mm
- 2005-2014 Bolt on tacoma sliders
- jp performance dual timing chain set
- Some parts for sale
- LT1 MONOBLADE TB 1350 CFM (possibly Trade)
- Katech LS9X Clutch and Flywheel Kit-Brand New
- Aeromotive 13129 EFI fuel pressure regulator
- FS: Camaro LS3 and Procharger F1A Kit
- CTS-V Fuel Pump***Updated Price***
- LS2 C6 6 speed wiring harness E40 ecm DBW pedal
- nitrous kit,lnc200,msd window switch,ms3 cam,racetronix,hotwire kit,lid,prc,etc......
- 30K mi LS6 engine parts- covers sensors lifters trays more..
- Ported stock F body throttle body w/bolts
- LS2 Intake manifold and fuel injectors.
- LS2 Intake manifold and i8936+
- Trans Am Ram Air intake and consoles for sale
- FS LS7 Injectors
- 1995 Camaro Part Out
- Hub centric wheels spacers for CTS-V swap
- Mallary Hi-Fire VI-A part no. 6852M
- FS Fast 36 LB fuel injectors
- CTS-V Accessories
- -15cc forged wiseco pistons
- FS salad shooters and tires
- BMR Manual Rack Kit, AC Delco GF822
- New GTO 17 Spare tire rim, w/ BRAND NEW M&H Frontrunners and 1" Wheel Spacers
- Trans Am Ws6 Sportline Rims 17"
- Garage clean up, Ly5 and l33 parts for sale
- diablo trinity
- Gunmetal deep dish zr1's fbody Nto5r's
- OEM Gen 3 5.3 rods and pistons, 62k miles. 80$ shipped.
- black halo headlights
- ls6 intake
- FS: LS1 ls2 ls3 ls7 LSX CSR billet flexplate
- (UPDATED$$)Ported Fast 78 shaner S3 ported throttle body, stock rails and injectors
- 2x Red/blue pcm
- Nitrous/Fuel Solenoids
- 15k mile Iron 6.0 with ls3 top end
- Fast "309500' 95 lbs/hr Precision Flow Low-Impedance Fuel Injectors
- AC evap canister and bracket / Battery cables / exhaust bracket /
- Long block LQ4 w/ 243s and other parts
- Circle D Multidisk 4k stall. 4L80E
- LS swap parts C5 oil pan, Manifolds and more
- LS Swap headers for Fox mustang
- Pro 5.0 Power tower for t-56
- NEW MagnaFuel regulator, Rollmaster DBL roller timing set
- Texas Speed 1 3/4 Stainless Headers
- 317 heads, complete
- C5 motor mount brackets, crank pulley
- 2 Pirelli 18 inch radial
- Brand new built Ly6 370 short block
- 0411 PCM, Throttle body, knock sensors, and more!!!&
- 2010-13 camaro flowmaster axle back (american thunder series)
- 05 GTO Oil Pan, LS2 Oilpan
- delphi 85mm maf 25168491
- Catted Y-Pipe with Flowmaster Merge and Spohn Torque Arm Crossmember (Chicago)
- H&R Lowering Springs & Mighty Mouse Spacers
- MSD plug wires (12" truck wires"
- fast 90 intake fast 92 throttle body/ alpine amp
- Summit/Jeg wheels
- Thunder Racing 7.400", .080 Wall Pushrods
- Siemens deka iv 80lb injectors
- L92 truck intake 100% complete with DBW TB, injectors and sensors PRICE DROP
- FAST 102mm TB
- Ls1 fuel rail and racetronix injectors
- Prothane Motor mounts with claim shells
- C6 electric fan SOLD
- Cast iron 6.0 LS heads
- ls3 heads 27k miles
- Ls truck heat sink coils with wire harness
- SOLD Ls truck intake complet with fuel rails injectors and throttlebody
- (2) 85mm Delphi MAF's
- Ported 243 heads and LS2 Shortblock
- Laptop and hp tuners pro.. With 6 credits
