View Full Version : Parts Classifieds
- Innovate LM-1
- madman TQ Arm for 12 bolt
- firebird tail lights
- FS: Performabuilt 4l60e $1100 SHIPPED
- Bunch of brand new parts for sale!
- Pistons, Rods, Heads, QA1, Katech, Kirkey, and More!
- PT80 Turbo New with hot side coated
- BMR T56 torque arm relocation crossmember
- FS: TTS headers and catted y-pipe
- Pro charger, Vortech ysi v27, CDS drive
- from sale or trade 6.0 iron block 4.070 bore
- *NEW* ARP head bolts 134-3610
- carb'd ls parts and g body ls swap
- FS: 2001 Z06 Waterpump, 59k miles
- FS/FT: LS3 intake, Street Sweeper Cam
- Holley EFI intake Manifold sold
- AI Turbo Cam SOLD
- 2001 LS1/4L60E combo
- Trans Am WS6 Speedline Wheels / Tires 17X9 / 17X11
- New LS3 Intake w/short LS3 stock Injectors
- Sold
- 317s rocker arm set and cowl hood
- Holley meth/water injection nozzle 1000cc
- Stock MAF, P&P Ends
- Mickey Thompson Sportsman tires and Skinny fronts
- Tan Leather Rear Seats
- STS turbo kit
- 2002-LS1-engine-12k-miles-complete-from-LS6-Intake-throttle body.
- NEW 91mm turbo, blow off valve, gate, headers, intercooler...
- brand new lsa heads
- 93-02 Camaro Spoiler - White
- 42lb Bosch 0280155811 injectors ev1 connector [sold]
- 19 inch C6 Z06 Wheels
- d585 heat sink coils 4 single spares
- LS1 Granatelli MAF/Housing
- DA QA1 Rears
- Borla Exhaust Tips
- Stock Fbody Suspension Parts (tq arm, lcas, etc)
- HRE Style 549 Completely Refinished
- MONSTER 28lb ls1 flywheel FS
- Corsa exhaust dual tips!!
- F Body Parts For Sale
- LS2 408 Stroker build for boost NEW
- Wtt my 17" for your 15"s or drag setup
- 295/50R16 Hoosier DRs
- Quicktime 4l60E bell housing
- 5.3 with harness and computer
- McLeod RST/GMM Ripshifter Street
- Borla exhaust for ls1
- Ls1 Bare Intake Non/Egr
- auto meter Hall Effect Speedometer Sender
- ls2 Longblock complete SOLD!!!!!!!!
- Procharger Air to Air intercooler
- Intercooler
- -15cc wiseco dish pistons forged
- magnaflow 3.5 race mufflers 3.5 in and out
- 2008 18" c6 corvette wheels with tires
- ls1 intake complete 300 shipped
- *SOLD*LS6 Ignition Coil packs, brackets, harness and mounting hardware $100*SOLD*
- FS: Ported LS6 Intake and TB
- Jesel Sportsman 1.7 ratio rockers - Part # KSS-307070
- FS: 36lb. Fuel Injectors
- Factory LS3 parts for sale
- Stock motor turbo build parts
- Aeromotive , Trick Flow, crossmember, LS2
- LS1 Corvette Cam....42K Miles
- ALL PRO small bore ls7 heads For sale
- 99-up camaro cluster
- New Comp Thumper Cam
- Schock relocation mounts
- Aeromotive Fuel Regulator
- Tons of parts!!
- Tons of parts
- tons of parts
- Vic Jr Setup
- New and Used Parts For Sale!
- 2 Trans Ams Parting out, 00 ws6 And 02 Base
- Monster Lvl 6 Clutch, T56 Parts, Stock Fans, Dynomax Muffler
- 2000 a4 pcm
- LS3 parts block,crank
- 8.5", 10 Bolt Chevrolet rear end
- FTP 104 lid $120 shipped
- Complete ls1 intake manifold
- Sale or trade 99-02 wiring harness and PCM LS1/T56
- Chrome 17x9 and 17x11 ZR1 rims
- 02 Trans Am Part Out
- t56 setup
- 241 heads with .625 PAC's fresh
- New gm Crankshaft gear
- ls1/lt1/ls3 Building cleanout- Thunder racing pushrods, rollsmaster double roller..
- lingenfelter adj 2 step
- Painless Wiring Harness, Computer, O2 Sensors
- weld prostar wheels with M/T
- Time to Clean out the garage again
- 98-02 Arctic White Z28 Hood
- Vigilante 3k stall converter and B&M trans cooler for sale
- Truck intake setup
- ls3 valve set hollow
- New GTO 17" Spares w/ Brand New M&H Frontrunners w/ New Wheel Spacers
- 2004 GTO 5.7 Engine pullout
- Tr6060 from 2010 camaro ss 27k miles
- FBody Parts, turbo hot parts, 9" rear, etc.
- Pro flow surge valve (procharger)
- Walbro 255, Taylor plug wires, valve covers, Springs, PRs.
- SBC Hooker LTs, Bowtie Mini Starter, Deep Pan
- FS: Comp Cam
- Walbro GSL 392 255L/Hr Fuel pump - SOLD
- Monster Trans TH350 and 3400 stall
- RK Sport 98-02 SS style rear spoiler. SOLD
- LT1 impala B-body f-body parts
- new ls1 hypertech powerstat #766
- Original Ram Air WS-6 Hood
- LS2 Parts cleanout
- Yellow CTSV Calipers
- headlight bulbs, center caps, lug nut covers
- Lunati rods and crank
- SJM ABS delete/linelock Brand New
- OEM SLP Camaro SS Key Fob
- NX digital window switch
- Fidanza aluminum flywheel for ls1! random 3rd gen parts too.
- Wilwood/McLeod clutch master with quick disconnect AN line
- Huge LT1/LS1 parts lot... Boosted Forged everything must go
- Lightly ported ls3 heads
- Arp 04+ head bolts/ arp 8740 rod bolts
- ls1 fbody crank pulley 6 months old
- fast fuel rails
- Gforce billet shock extenders
- 27 spline chomoly slip yoke for t56 trans
- LQ4/l92 Long Block
- OEM SS Hood
- ls2 402 stroker
- 98Ls1 Camshaft, ls1 lifters, pistons+rods...Ls7 lifters.
- Set of 8 SVO 39# Ford Blue Top Injectors (2R3V-B5A)
- Sold
- HP Tuners Pro for sale
- Used GM 8.5 10 bolt 3.42 Gears
- F/S Used Ls3 intake and ls3 throttle body
- nitrous/fuel solenoids for sale
- Siemens Deka 80lb Injectors (8) EV1 110324
- 30k mile OEM springs, struts, and shocks
- Rear Camaro tail panel (berger panel)
- 2 Chrome OEM ZR-1's with new tires
- T-Top Seals
- 2006-2007 GM OEM engine harness
- Summit SFI balancer for sale
- Nitrous 95mm Plate, NOS MINI, AND MORE
- SET of 317 Heads & 241 Heads
- F/S NEW Cirlce D 4l60 3k stall convertor (Houston)
- MSD 6010 Box
- F/S , 5 SETS of fuel injectors ( HOUSTON )
- torque arm bracket F/S
- New Pair MT ET Street (Bias Ply) 26x11.5x16
- CME valance and tips
- Turbo ready 5.3 part out, speed inc cam, lunati springs etc
- LS3 Parts, Oil pan, valve covers, etc...
- WCCH LS7 Heads/LS7 Rockers/LS7 Fuel rail and Injectors
- Hurst shifter with ws6Store stick
- umi strange brakes and more
- Corbeau 4 pt. bolt in harness
- LS3 823 Heads Lightly Ported
- Huge Twin turbo z/28 partout
- 4.125" Dry Sleeved LS3 Bare Block $1600 OBO
- 95mm Nitrous Outlet Plate: SOLD
- UMI Dual-Roto LCAs
- CCW Drag pack C6 ZO6
- Derale trans pan 4L60E
- WTT/WTS Forged LS1
- D1SC Procharger Kit -Rebuilt Head unit - FMIC-
- Random parts and ls parts
- Midwest Racing Converter 3800 stall, 4l60e, single disk lockup, fresh clutch!
- Emblempros LSX Badge, Founders pan hard relocation kit
- Tons of Parts
- STS rearmount turbo kit
- fs twin intank 255s and fbody coilovers
- 98 Firebird Mystic Teal Partout
- Lightweight stuff k member and all
- 8 bosch 160 lb white tops
- Strano Springs and PHB
- 12 Bolt Detroit Truetrac Differential
- Texas-Speed Lid
- (SOLD)VMax 95mm T/B w/Inverted IAC
- Fast Toys Ram Air (SOLD)
- tci flexplate 399753
- Dakota Digital SGI-5 Universal Speedometer Signal Converter
- Whipple 8 rib 3.1 and 3.5 Blower pulley
- 2010 SS Camaro ECM SOLD!!!!
- FS: LS1 Intake manifold
- MagnaFlow race mufflers 3.5
- like new BTR mild boost camshaft
- Ls1 used oem clutch kit and cxracing ls1 240sx oil pan
- BNIB Yank SS3600
- 414 CI LS engine Aluminum block and L92 heads
- sold
- NIB ARH 1 3/4 headers and Y pipe, 2000 Camaro air and egr
- 05 cts-v t56, rear differential, front and rear brake calipers
- Ls1 long block
- PRC ls6s, efi super vic, custom cam.
- 93-97 Trans am front bumper cover
- 2004-06 gto 1 piece performance driveshaft
- 6le side splitters firebird/Camaro for sale
- TCI flexplate
- 35th anniversary wheels and tire
- 4 gen Firebird Trans Am part out /complete 6 speed swap
- yank ss4000
- Rebuilt Performance TR6060 Corvette Transmission
- Ls1 & f-body parts performance & stock
- TSP 1 7/8 headers and off road y pipe
- LS2 block
- 99-2002 Plastic Stock Fuel Tank
- F-body/GTO LS1/2/6 Fluidampr
- >> new in box Cams for sale <<
- 241 heads
- nx gemini maf kit , msd timing twister , bottle heater , tunnel mount
- SOLD Siemens Deka/ Mototron 60lb injectors SOLD
- 98-02 Fbody Poly motor mounts with clamshells already installed
- WTS f body 4l60e shift lever with 10mm ball
- LT1 PCM and ignition parts and rear end
- LS6 Intake, LS6 Cam, 799 (243) heads, LS7 lifters
- FS: NMS-1000 Best Nitrous Progressive contoller!!!
- 06 GTO parts
- LS1 waterpump 21,000 miles
- LS2 LS3 fuel rail with bolts
- LSX Timing Cover with bolts
- GM crate engine Valve Covers LSX
- GTO shorty headers, Turbo headers
- NOS window switch
- Sold Innovate LC-1 (PT# 3769) wideband kit
- SOLD Ford 9" 4.30 gear set
- Ls1 Camaro M6 transmission crossmember, 1996 and 1998 camaro ABS units
- 3" Kooks bullet mufflers
- LS2/3 Cam Sensor harness & pigtail
- 05 CTS-V part out
- Twin turbonetics turbo kit
- 2 x 38mm wastegates
- LQ4 Performance Rebuild Long Block
- Nitrous Outlet Fuel Cell C5 Corvette
- Ported Fast 92 (peak port shop)
- Price drop, complete coil relo kit, burkhart manual master, dash pad, and more
- 6L90E transmission with torque converter and flex plate
- Ls7 fuel rail
- FS Camaro 98-02 OEM SS hood and spoiler $800
- Set of Eight (8) LS1/LS6 Siemens Deka 60lb/hr @3 Bar fuel injectors
- Carbon Fiber Hydro-dipped Valve Covers
- UPR Ls1 mustang swap adapter plates and 4.6 solid motor mounts
- 383 LT1 24x Built for Boost
- BNIB Kooks 1 7/8" C5 Corvette race headers with off-road x-pipe
- FTP 98mm lid 9/10 Condition like new Fast toys performance
- 06 Gto 6 speed transmission
- th400 setup, vac pump, bead locks, more.
