View Full Version : Parts Classifieds
- ***SOLD***799 heads all clean up check last post
- Simpson hybrid pro rage harness (large)
- 317 heads
- Double Din radio bezel
- LS factory valve covers
- Ported 853 heads
- l92 intake, rails and injectors
- Ms4 cam, tsp pushrods , 92mm tb ,etc
- 28# injectors, b&m trans cooler, and transmission mount
- SOLD - K&N FIPK Intake - Pontiac GTO LS2 57-3053
- Crane Cam full 1.6 Roller Rockers 3/8" stud
- LS6 valley cover
- Speedline WS6 wheels and tires.
- BNIB Spec stage 2 clutch
- Pt-88 solddd
- NEW! Complete D1SC Procharger Kit for fbody with extras!
- 1998 camaro z28 m6 roller
- B&M Hammer Shifter - Auto
- 799 Heads
- In need of a 4L60E
- Need to Sell ASAP!
- Fuel system
- Brand New On3 Turbo, Wastegate, and Blow off Valve
- Zr1 blower with nitrous outlet spray bars and more goodies
- F/S JE pistons 4.125 -29cc 427
- JGS 50mm Wastegate
- Pacesetter shorties
- AIS meth injection kit, Huron Speed A/C Turbo kit, PT7475 Turbo, 3.70s and more
- 799 heads
- Spring cleaning sale
- Sold
- on3 38mm wastegate
- C5 Corvette Headers - ARH - Ceramic Coated
- fs:billet polished manual belt tensioner
- 2 $100 gift certificates for nitrous express
- Sbc cast aluminum tall valve covers
- Hooker Catback
- HUGE parts sell off to cover medical bills and treatment
- Sold please delete
- lt1 bose 5 speaker system
- 2000 cfm 4 barrel Throttle body 4500 bolt pattern
- LS1 Procharger Pulley
- ebony 4th gen leather seats.
- FS:true duals,n2o,lid,motor mounts and more
- NOS heavy duty nitrous refill pump
- Anyone have a TSP lid for 85mm maf
- LSX Mustang Swap package 9.20's NA e85 750 HP
- Want yank or ? 4l60 conv 36-4000
- 2002 LS1 and T56 dropout T-56 6 speed manual
- F/S Brian tooley racing 660 platinum spring kit $150 shipped
- LS2 LS3 EPS custom grind cam by Pat G
- Intake elbow 90mm 4150 flange $100 cut to fit cable
- 19inch ADR wheels and tires with Nitto 555
- Random stuff. ARP,MSD DMH,COMP/317s PTP
- c5 auto parts
- LS1 Short Block
- th350 stall, motive 9" 4.10 gears, jegs sport stars SOLD
- Camaro tail light; lt1 style
- 07-13 silverado nnbs lift. Brand new!
- exhaust 2.5" y w/ fake cats into 3" w/ dynomax bullet
- Circle D Billet 3600 Stall only 5 Passes
- LSX454 badges
- Used TSP Tsunami w/ new LS6 oil pump/LS2 timing chain
- McLeod hydraulic clutch setup for ls foxbody
- ls6 Intake with ported and polished T/B
- Lt1 wiring harness abs pump cruise control ect.
- Set of 8 white Bosch III injectors -- 41 lbs/hr (LS1) or 36 lbs/hr (LT1)
- Bmr torque arm relocator trans crossmember and lca's
- cam kit
- delete
- Cam, 921 Springs, Oil Pan, Push Rods, etc.
- LS1 Motor Parts
- Bmr kmember
- 4 sets of ls1 rockers
- 90mm Nitrous Outlet Plate
- NIB LS7 Clutch and Slave
- vortech v1 procharger a trim
- Sts complete turbo kit
- LS1 Passenger Side T-Top
- Parting out z02 ws6
- High pressure oil pump same as LPE
- Red top injectors 37 lb/hr
- T-56 shifter B&M
- Racetronix 42 lbs flow matched injectors
- Lsx. Sbc. Third gen. 4th gen stuff
- ls parts
- $50 takes all...CHEAP EXHAUST PARTS! LS1 Exhaust Manifolds, Y pipe, Catback
- Procharger Big Red Race Open Valve
- msd window switch, metco breather etc.
- FS: LS7 Z06 manifolds, cats, and H-pipe.
- Trans am & Camaro signs 35$ shipped
- ls1 tsp 224/224 r14 camshaft
- Set of 4 silver 17x9 ZR1's for sale, $700 shipped obo - SOLD!
- Camaro Parts!!!
- GTO Spare Front Runners...
- Garage sale Misc parts LM4 F Body parts wheels
- lc1 wideband, 98 dual pump sender,racetronix dual hotwire,T56 shifter base
- Fully built race trans TH400
- Holley 12-1800 Dominator fuel pump with filters
- Holley HP EFI complete kit with extras
- Brand New Air Suspension Set up Complete!
- FTI Pro Series Powerglide Level 4+ with 1.58 gearset
- Brand new TSP 418 Short Block for sale(Never used or installed)
- 317 heads Manley valves comp push rods
- FAST 102 Intake Manifold OVERSTOCK ITEM!
- FAST 92 Intake Manifold OVERSTOCK ITEM!
- lost my job ned to sell stuff asap sale!
- Aeromotive 13129 EFI Fuel Pressure Regulator, Radiator, valve covers, K&N filter
- procharger big red blow off valve
- walbro, vette maf, d/s, etc...
- 799 heads
- hsw 90mm nitrous plate .. nitrous parts
- Callies Magnum 4.000 stroke crankshaft (NIB)
- ls1 240sx part out
- Ls6 short block and 243 heads
- Bnib set of 8 ls1 coils 12558948
- T56 Crossmember and torque arm bushing
- 28x10.5 tubes, 98 oil sending unit
- New Pair (2) of Toyo R888 Tires 255 35 R18 18
- 98-02 Firebird Trans Am headlights
- LS1 Misc Parts and accesories! Lets get these sold!!!
- forgestar f05s 19x11 and 19x9
- Intake, TB, injectors fuel rails computer and harness
- Gates Micro-V Blower Belt P/N K060380
- Intercooler Charge Pipe W/ Procharger Big Red BOV Flange
- LS6 Coolant Crossover Tube W/ Rear Blockoffs
- SLP Smooth Air Bellow W/Meth Nozzle Provisions
- Stainless 10lb nitrous bottle brackets
- 02 extentions
- GlowShift Digital Fuel psi gauge
- PCM out of 02 SS Camaro
- Boost a pump, scavenge pump muffler ect.
- Ported 243 heads Ported TB LS6 intake racetronix flow matched 42 more package deal!
- Walboro 255's GSL392
- HP Tuners Pro
- SOLD!!! LS3/LS7 42lb Injectors
- SOLD-58x reluctor crank & shim kit
- SOLD- FAST 4150 throttle body SOLD
- LS1 TURBO SET UP 673HP NOVA buit by yatesefi.com
- 98 - 02 Professionally modified Double Din Radio Bezel
- 60lb/hr Injectors (from A&A Vortech Kit)
- comp cams 7796-16 7.425 pushrods
- pac 1218 valve springs
- Lunati/Morel High RPM Link-Bar lifters
- C5 DD 18x10.5 w/ BFG KDW2
- Stock 5.3 parts
- L33 aluminum 5.3 shortblock
- SLP Blackwing Stage 2 Cold Air Intake Camaro SS 6.2L
- LC1 Wideband, Missing sensor
- 2010-2012 Camaro SS OEM Exhaust System
- Prochargers 8 rib pulleys for sell, 4.38, 4.25, 4.0, 3.7 ALL SOLD!
- Trick Performance Products Dual Window Switch
- console, ported oil pump
- FS: EV6 to EV1 Injector Adapters (For LS2/ LS3/ LS7 Injectors on an LS1/ LS6)
- NOSzle direct injection setup FS
- 2.8l Kenne Bell
- Turbo on eBay
- Z06 Cam, Blue and Yellow Springs
- LS Rear Cover - LS7 Clutch & Misc LS Parts
- LS1 to LS3/7 MAF Harness
- C5/Fbody parts for sale Intake Injectors Exhaust Ect.
- Sold 2002 lq4 engine wiring harness complete
- FS: Carbon Fiber LS Valve Covers
- Brand BRAND NEW in box msd 6012 from gm performance parts 58x
- Wilwood 6R front, 4R rear brake setup For Sale or Trade
- Bogart D10 15x3.5 front wheels
- Fresh L33 Shortblock - Price Reduced
- Trickflow 245 6 bolt heads
- ltx parts, aftercooler, lsx clear lid
- LS3 fuel rail LS3 fast injectors
- 18 Aza Z8 wheels
- comp lifters,918 springs,wideband etc. all NIB
- Autometer wide band 4378
- Lil John turbo cam
- Lt1 4l60e
- 2002-2004 ls6 cam camshaft
- Bosch 160lb white top low impedance fuel injectors
- Nitto nt05 for sale
- FS: 3 Sets of Injectors
- 265/40/17 Conti Extreme Contact DW
- Circle D 4C $550 shipped
- Procharger Steel J-Bracket
- Cheetah SCS Shifter for TH-400/350 Reverse Manual Valve Body
- FS: DMS Lowering Springs F Body
- A1000 fuel pump
- Comp cams 231/237 585/595 112lsa $250
- SS Trailblazer K&N cold air intake kit SOLD!!!
- 4" eagle crank
- Prothane LT1 motor/trans mounts, Monroe Strut Mount
- Ford 160lb. injectors for sale/trade
- PTM 92mm T/B $210 shipped
- Ls6 intake rails injectors sensors and t/b
- Built 4l65E transmission & billet Precision Ind. converter
- FS: Yella Terra, ARP, SVO, Comp PR's
- Ms3 112 lsa
- Cleaning garage: aps, stock parts, 5/8 wheel studs
- ls1 nitrous kit
- FS - Stock 4l60e torque converter--UPDATED PRICE
- comp hi-tech 7.425 pushrods
- Dark Grey Convertible Covers (Cracked but fixed)
- c5 tr6060 conversion with b&b bullet exhaust
- Brand New Parts for 1500hp Turbo Build
- Stock LT1 and LS1 Stuff
- d1sc kit (update 1/24/14) (Price drop!)
- SLP LM1 Resonator
- 25% UD pulley, powder coated valve covers with Truck coil brackets 4th gen
- FS/WTT SS wheels w/dr
- WTT OR SALE ZR1 wheels and tires
- Stock stall converter for 4l60e
- Lt1 t56 , works perfect!!!
- Ls1 ecu
- m/t 28x10.5-15 stiff sidewall
- 98-02 trans am bumper cover to fender brackets
- RPM 505 18x8/18x9 chrome wheels
- 90mm LS2 Throttle body and swap harness
- LS6 Clutch & Flywheel
- *Sold* 2010+ Camaro SS complete Brembo brakes (front & rear)
- LS1 t56 harness and ECM
- SSR Wheels, LSX Harness, LS1, PARTOUT
- 2000 ws6 part out
- Lou's short stick
- 317 heads complete
- Stock LS1 Rotors from 1999 T/A WS6
- Stock lq4 cam
- Complete 317 heads for sale
- turbo Cam for sale
- Custom LS Coil Brackets
- LS1 Fast 102, Fuel rails and LS2 DBW
- LS1 swap headers and Heatsink coils.
- FS: LS1 Motorsports Whisper lid/Direct flo lid
- ls1 parts
- 06 GTO Front Bucket Seats
- Melling HV/HP Oil Pump
- NIB Prothane Motor Mounts!
- F body PS Reservoir, Patriot .650 springs, & more
- WTS: Used LQ4 Pistons only
- 99-02 M6 engine harness
- FS: T56 Clutch & Pressure Plate
- msd boxes, mwc ta cm, nitrous stuff
- SOLD: Bosch 160 lb/hr high impedance injectors (FIC)
- Mickey Thompson Sportsman S/R Radial Tires
- FS: 2 BN Gas filters, Case of Redline oil, 4 10 spoke caps, BNIB turn signal relay.
- 383 lt1 partout
- NIB Stroker Kit
- Kooks 3" x 3" Catted Xpipe USED C5/C6
- OEM Z06 Front Bumper (Lemans Blue)
- For Sale: CAMS, PUSHRODS and more CAMS!!
- Parting out 1994 Z28 Camaro 6 Speed
- Camaro stuff, T-Tops, Mirrors, Hubs w/ extended studs, spindles, interior stuff
- 4.10 gears for 7.5 10 bolt
