View Full Version : Parts Classifieds
- brand new SFC!!!
- Zo6 Exhaust Manifolds + gutted cats, Bi-Mode axleback with "Mod"
- Almost complete turbo kit
- ZR1 wheels 17x9 and 17x11 black with thin silver lip
- Snap-on roll chest and topper (DFW)
- Turbo cam with under 500 miles
- NEW!! Lower control arms!!
- Moser 9" Rear w/ Billet Center Section & 35 Spline Axles for 4th F-body
- FAST 90, 40lb injectors and LS1 fuel rail
- Brand New Built TH400 w/ TCI 3K Stall/flex plate
- ****SOLD****Ported LS3 Head/Cam Package
- Go F.A.S.T. parts, fast 90/90, nitrous, sbc, textralia.....
- LS1 Crank Pulley and Belt
- fast toys performance 104mm lid 125 shipped
- 05-06 LS2 6.0 Fuel Rail Covers
- Garage sale Autometer Glowshift ect....
- yank ss 3600
- 2010 Camaro Diff
- GTO Front runners
- LS3/L76 FAST Intake
- 2004 GTO tail light lenses
- stainless borla 3 inch cat back with electric cutout
- LS6 intake manifold, GTO balancer, T6 flanges
- Sleek Beak 98 - 02 Firebird Hood - Brand New
- Weld Pro Star
- Wilson N2O plate, Nano kit, Magnafuel pump/filter, Fluidampr pulley CHEAP!
- 35 spline detroit locker for 9"
- Mac 10 bolt rearend girdle cover
- Mtx 12" subs
- Texas Speed, Texas Giant cam
- RaceStar 15X3.75 Front Wheels Brand New
- Edge 3200 stall
- Harland Sharp LS7 Roller Rockers
- Brand New ATI Ultra Bell, PG Supercase and Non-roller Tailshaft for sale. Only Mockup
- NEW PRICE Brand New Richporter Vented Opti Spark $150 shipped
- FS: Smoked '02 Camaro Tail lights
- Jet DST tuning software and LT1 ignition parts
- Wtb 2nd gen s10 ac delete box
- Garage cleanup factory LS1 parts
- Sold!!
- gto spair tire and rim
- Ly6 6.0 motor forsale
- New Vredestein Vorti R's - 265/35/20 & 305/30/20 for sale
- Ported Intake Manifolds and Throttle Bodies in Stock!
- ***SOLD***LS6 intake, fuel rails and injectors- LIKE NEW
- ZR1 Replicas with Tires/LS1 Intake/ Fast 78
- HpTuners Pro
- 2004 Gto LS1 Harness and Computer
- Misc Parts IAC/TPS/Hoses etc
- 93-02 Camaro and Firebird T Tops
- FS: LS2 Engine, Intake to Oil Pan Low miles Stock
- Lots of ls parts!!!!!!
- Boost Ready Forged Iron 6.0l Shortblock
- Tick Performance adjustable master cylinder
- COMP Cams LS Series Retro-Fit Trunnion Upgrade Kit [OPEN BOX]
- A few parts for sale
- OEM LS2/LS3 red plug wires perfect
- TrickFlow 7.4 Pushrods like new
- K&N panel and Red STB
- NOS dry kit , TNT jets , Compucar EfI wet nozzel
- GM 2 bar MAP
- Stock LS7 rockers
- 98+ honeycomb firebird tail lights
- Speed Inc LS7 Street Cam 227/243
- LS3 injectors, Stock C6 shifter
- 5.3 take off intake and oil pan f/s
- QTP cutout Y 3" with plate/bolts/gasket
- nib....Auto meter electric fuel pressure (phantom #5763)
- SOLD low mile 799 heads SOLD
- GTX5518R 88mm turbos
- LS1 Camshaft Lamp
- Timing Tuner
- Performance Parts and Stock
- GM 12557840 Pulley Bolt LS1
- camaro pcm 2000 auto
- c5 fuel rail cover
- bare cylinder heads, LS1 manifold, LS1 front cover, other odds and ends
- Rearend 7.5" 3:73 gears T/A cover
- asp corvette underdrive pulley ls7 lifters
- 2002 b4c camaro motor and tranny
- Brand New 15x10 Drag Rims NEVER Been Mounted No Scratches No Scuffs
- FS: LSA / LS9 Valve Covers with Coils
- Lingenfelter ASA LS1 for sale
- McLeod clutch and flywheel
- 8 42lb bosch green giant fuel injectors
- Complete car stereo sysytem
- Misc. F-body parts (t-top shades, window kit, speed bleeder, hurst knob)
- 2004 2wd 4l80e 84k miles
- Comp Custom Cam
- SLP crank pulley / balancer LS1/6
- WTT/WTS 243 heads, LS6 Intake, P&P Throttle body and MAF (Traded!)
- Nitrous refill station,NOS#4251 SOLD !
- (2) 275/35/18 (sold)
- ls6 engine ctsv part out
- M&H 17in front runners, radials 185/55/17
- 02 ws6 gauge cluster
- 2006 Truck Ignition Coil Set
- Custom turbo kit
- Surge tank with 3 Walbro 255's
- FS: HSW LS1 plate kit full nitrous setup
- Sold
- TSP 100mm MAF housing w/o cartridge
- LS3 heads and fast 102
- C5 RTD Simulators BNIB!!!!!!!!!!!
- 3:73 gears, 3 series carrier limited slip 12 bolt. 4150 throttle bracket
- GI Brand new TEA Stage 2 LSA heads and Holley Hi Ram
- Ls1 oil pan
- ls6 intake manifold, 80lb injectors
- NIB Diamond Forged Blower/Turbo Dish Pistons 4.020 bore
- ls6 cam
- ls6 intake
- wtb ls7 1m8 ratio t and d adj rocker set asap!!!
- SLP ls6 intake,headers,Maf etc
- Pair (QTY: 2 pieces) of 1" Billet Fbody Wheel Adapters
- Nitrous Express wet kit, NX remote bottle opener
- PTC 4000 stall converter
- AFX Wideband/C6 Tips
- Gear vendors 4L60E electric overdive
- Holeshot rims and tires 5x5 lug pattern
- LS Oil Pan & Corvette LS3 Accy Drive Bracket
- FS: NEW F2 Procharger Supercharger
- Big Stuff 3 EFI System
- hurst firebird car cover
- SOLD-Texas Speed 100mm Mass Air Flow Sensor, 4" Tube, Card Maf
- AMS 1000 boost controller
- lsx rx catch can
- FS: 5.3/5.7/6.0 turbo cam, 5.7 block/crank, torque converter..
- ligenfelter 100mm maf
- 305 35 r20 nitto drag radials
- ls1 garage sale *********************************************
- aeromotive a1000/regulator/filters
- harland sharp roller rockers, b&m, PAC springs, trick flow........ aftermaket Ls1****
- Ls1 valve spring compressors
- Gears, stock intake
- Innovate Wideband
- LSX Accessories, Starter, Coil packs, Mustang swap mounts
- LS6 Intake
- 24x stuff(d585 coils, ecu, front timing cover)
- racestar 15x3.75 wheels direct drill
- Performance and stock parts
- bmr th350/glide crossmember with torque arm bracket
- LCa non adjustable silver , stock injectors
- Yellow ls6 valve springs , Ls6 Clutch , Magnaflow cat back , stock ls1 injectors ,
- NX Nitrous Kit, Stand Alone Fuel System, Opener, Heater, Blanket, etc
- Ls1 243 p&p nx nitrous
- rockford fosgate old power 1000.1 bd amp
- Procharger D1-SC Head Unit
- Pro Yank 3600 stall NEW!
- TCI 4L80E controller
- Complete Lt1 with accessories
- C6 Kooks 1 7/8 Longtubes, 3in Catted H Pipe, O2 extensions
- ****SOLD ***C5 Corvette SS front brake lines, Ate super blue brake fluid
- LS1 engine parts (241 heads, lifters, cam), GTO parts, ARP studs and various C5 parts
- Goodyear Eagle F1 Supercars (275/35/18's) 1mm shy of new
- cloyes hex-a-just timing set
- Kent-moore 4l80e rebuild tools and other lsx parts.
- Stock 3.23 10 bolt
- 10 bolt 28 spline axles***FREE
- Stocker rear brake rotors
- LS1 853 heads
- Nick Williams 102mm DBC Throttle Body
- BS3 EFI 24x COP ETM Upgrade
- SLP 1.85 ratio rocker kit
- 93-02 Camaro Aluminum Driveshft NEW U joints
- LS7 Heads & Intake Manifold
- FS: 1 wire oil pressure sending unit
- steering column for sale
- Boosted blow out sale!!
- NIB Eagle 6.125 H-Beam rods
- (4) LS1 flyhweels (RAM billet, stock OEM GM)
- ********Complete LS1 Intake Manifold & T/B
- 4000 stall TH350 LT1/SBC
- LOTS -LT1 parts, stock & perf. Accel 300+ FAST dual wideband, LCAs, AFPR, BBK headers
- Callies Dragonslayer Crank
- 1999 Camaro SS Partout
- LSX block bare
- 3 Auto Meter Phantom Gauges and Triple Gauge A-pillar Pod
- 1999 trans am part out
- fast 102 tb new and comp cam for 416
- Sold!!
- Delphi 96 LB. Flow matched injectors
- Crew Cab chevrolet/gmc nerf bars
- Holley 12-890 Fuel Pump
- 02 LS1 Rockers, 28.8 Injectors, 85 MAF
- F/S - 00' LS1 parts, oil pump, timing chain, lifters, rockers, 853 heads w/LS6 spring
- 2001 camaro speedometer
- 15X8 Pro stars (powder coated black) 275/60 GY radials
- Vortech Maxflow bypass valve - supercharger
- Walbro Dual Pumps
- LS3 2010+ Camaro uncut manual engine harness
- 93-02 Camaro California car cover
- 98-02 F-body UMI k-member
- Complete Upgraded Procharger Setup
- Gauging Interest: WTS/WTT Anthrocite Torque Thrust M's w/Tires
- Lt1 parts,truck pan,lt1 t56 parts.
- Fs: 2-275/40/17 MT ET Streets Mounted on Stock 17s. Like New
- FS: 98 EBCM, 98-02 A Pillar with gauge pod, 00 PCM
- 00-02 F-body Ebony Upper Console
- New in box off road tsp y pipe // magnaflow cat back
- Ft: 2005 5.3l
- cams for sale
- Corsa Pro-series 3.5" dual tips
- brand new yank ss4000 stal
- 98 Fobody Helms Manuals
- FS: Brand new Vmax 87mm TB less than 100 miles
- RKSPORT Body Kit for 98-02 Camaro
- BBK SSI Intake & 80mm Throttle Body
- FS: Stock Heads, Cam, injectors, CHEAP LAST CALL
- SOLD: LS1 Alternator Bracket Idler Pulley, PS Bracket
- Complete LS2 intake (less TB)
- 243 heads
- 2010 camaro brake and clutch pedals
- 4L80e
- Weld Wheels/MT 315 Radials
- ls7 long block $4000 or trade plus cash
- ls1 shortblock and turbo hotside
- 2001 yukon parts for sale!
- ls1 Camaro parts
- 2002 LS6 block FS
- 383 rods and pistons
- All Sorts of Stuff
- BB PRT exhaust for sale
- Nitrous/Stock/Swap/suspension Parts for sale CHEAP
- New 918 springs and 224/224 Comp cam on 114 - SOLD
- Brand New Melling 10295,Arp Head Bolts,Ls7 Lifters
- HRI Ported LS6 oil pump
- Magnetic Base and Dial Indicator Kit
- F-body oil pan pickup tube dipstick
- Thunder Racing 7.40 Pushrods
- Hooker Headers
- Nitrous-Accessory MPH/SPEED Based Controller Lingenfelter STOV-002
- 99 T56 Trans
- brand x nitrous kit with extras
- 99 LS1 Engine
- FS: Complete F1R kit
- Slp dual/dual low milage *SOLD*
- 1 in spacers 5x4.75 f body
- E85 Drag Race Carburetor
- Huron Speed hotside turbo kit
- FS: LG motorsports fbody harness bar. Discontinued
- wilwood brakes,intercooler,c5 a/c compressor
- selling new in box comp cams solid roller lifters
- Few 4th gen fbody parts
- C6z06 wheels, et streets, corbeau forza seats, g force harness
- LS / Vortec Series Engines Corvette LS2 LS3 Oil Pan
- Comp 6262 Billet Ball Bearing Turbos
- FS: Edelbrock 2-Piece LS Timing Cover
- F/S F/T Stock set of 243 heads 42k miles
- Procharger 3 core intercooler
- FS: Fast 85lb Injectors $315 Shipped
