View Full Version : Parts Classifieds
- FS - McLeod Clutch Discs p/n - 61072-07
- TCI EZ-TCU Brand New...
- Monsoon Headunit
- Kicker speakers - C6 Upgrade Kit
- 02 ws6 ls1 4l60e complete drop out 74k
- 01 ls1 complete motor
- 2000 Camaro 6 speed wiring harness and computer
- EFI Live Scan tool
- C6 Accessory drive for sale with balancer
- T56 bell housing
- Engine harness and PCM
- Stock 3.42 gearset from 2001 6-speed F-body
- NEW Custom Made 200 Amp Alternator 98-02 F-Body or 97-2005 Corvette
- 10 bolt rear 2.73 gears
- stock 799's
- Turbo Smart E-Boost controller
- *SOLD* FIC 1000's 107lb injectors/EV1 Adapters
- Monster Stage 3 Clutch FS -- $600 shipped (That's $400 off)!
- FTI converter (brand new) TH350-th400
- LT1 Twin Turbo Kit F/S
- foxbody ls swap headers and carb set up
- ls1 with 18000 miles
- stock lq4 parts
- SOLD!!!!! AFX NGK Powerdex Wideband
- LS1 Fuel rail and Injectors
- Stock 10 Bolt Axles, Non TC $100.00 OBO
- BNIB umi torque arm
- FS Complete AC system (Will Part Out)
- Pro Yank 3400 4L80 Converter - LS
- 6.0 LQ4 Piston/Rods w/ ARP Bolts, line honed 0.002in over w/ brand new rings
- Full-Race custom intercooler **NEW**
- Tick Master, Turbo K member, brakes, parts
- Stock and aftermarket G8 stuff for sale
- wiseco pistons and hptuner pro
- BNIB cam swap parts. timing set, pump, etc
- ARP head bolts
- ls1 performance parts for sale
- F-body heater and a/c unit complete***SOLD***
- Stock LS1 TB
- Comp Cams 5/16 Magnum Pushrods 7.400 NIB 7638-16
- 438cid LSX Mast CNC Callies Edelbrock LS1 LS2 LS3 LS7 MUST SELL!! FS/FT
- Hoosier qtp 28/14.50/15
- 10-Bolt Rear End Kit
- 6.2 Truck Manifolds
- Brand New Goodyear F1 Supercars 275/35/18, 285/35/19!!
- borg warner s472*****pics added*******
- F/S Ported LS2 intake manifold & Ported LS2 90mm/tb
- F/S Stage 2 CNC Ported Livernois 243 heads.
- Wilson ls1,2,6 FAST90,92 Fuel Rails for sale
- Truck coil packs complete (heat sinked)
- Black Powdercoated Prostars For Sale With Tires!
- Stock LT1 lifters, Intake manifold, Throttle Body, Fuel Rail & Valve Covers for Sale
- L92/LS3 shortblock
- Tr6060 6 speed. 30k miles
- ls whipple for 6.0 GM truck/suv
- LS1 oil pan, coil packs, valve covers, LS1 PCM
- LS1 5.3L motor 34k miles with extras!
- GTO Wheels and tires
- Ls7 Lifters Like New!
- LS3 bare block, trick flow 235's alum 5.3 ARH
- 5.3 turbo notchback part out
- Parting out 2000 Camaro V6
- LS1 and other parts
- 2000 camaro Z28 Part out
- Fuel injector connection 80lb flow matched injectors new in box !
- lucas 42lb injectors
- sold! circle d 3200 stall
- C5 Custom Sub boxes! cheap! OBO
- Manley Nextek Dual LS springs & Titanium retainers
- 4l60e Transmission
- LS1 F-body notched oil pan
- Morel 5206 pro series SOLD!!
- USED,C5R Valve Covers,317 heads !
- Spohn Short Torque Arm With Cross Member (Spohn #405)
- Crank pin kit, injectors, c5 stuff
- LY6 parts! Wiring harness, cam, exhaust manifolds, etc.
- 04-06 GTO Black Interior Seats Door Panels Trim Panels 12 Pieces
- Set of Drag Skinnies and Rear Tires
- Custom Asanti Wheels!!
- l92 truck intake manifold with pics!
- Fikse FM-5's 17x9.5 & 17x11's
- FS: 2010 Camaro Clutch & Flywheel
- 243 LS2 heads for sale in TX $500
- pacesetter lt,ory,lm1 cb
- complete ls3 inake manifold fuel rails and injectors fast adapter
- ls1 lq4 truck intake complete and manifolds
- MAF ends, DS bar, Cobra CB
- Trick Flow Stainless 2.04 Intake Valves
- Selling my Harland Sharp 1.7 Rockers
- C5 Z06 Titanium Mufflers
- Vfn 3 inch bolt down ss hood
- t56 for sale
- Tci flexplate ls1
- New 241 LS1 heads
- coan th400 converter, 94 4l60e, hughes th400 deep pan
- Truck intake with EGR stuff
- Trans Am tail lamp
- Brand New vented opti-spark
- Truck intake w/ DBW throttle body
- LG G5X3 114 Camshaft
- bnib probe forged dished pistons for 383 .040
- Black LS1 covers
- 5.3 Engine and tranny Package
- Brand New Michelin Pilot Sports, Goodyear F1's, Hoosier R6's!!
- FS: F-Body Fans
- Nascar CF COT show car wing
- FAST 78mm Intake Manifold & FAST Throttle Body
- Misc. Fbody parts?!
- F/S or Trade PT106
- Fbody swap, built th400, converter, crossmember, driveshaft
- Brand New In Box Motive 3.73 gears & Bearing kit
- NIB 6litreeatr fiberglass tweeter pods
- 76mm Ball Bearing Magnum Turbo.
- FS: 2004 Pontiac GTO ECM
- Ls7 parts/ wcch ported ls7 heads
- Gen IV E38 ECM SOLD!
- Ls7 clutch w/flywheel 5k miles
- WTS Firebird Formula Tail lights with center, Exhaust Cut out. 3.8 Parts
- prc .675 lift springs
- WTS/WTT Heads
- WTS/WTT Heads
- WTS/WTT Fast 90/90 Set-up
- lunati blower cam and supoporting hardware BNIB
- Wilson FAST 90/90 Nic Williams
- Racetronix LS1 to LS2 Cam Harness & used ls1 rockers & c5 intake
- ls6 intake
- FS:Forgeline (2) WC3 - 18x9.5, 5 x 4.75"
- LS1, LS6 Heads, Tsunami Cam, Springs
- NIB K&N air filter w/ gasket
- ls9 cam
- Lsx mustang swap driveshaft
- BMR TH350 trans mount LT1
- FS: Stock ported TB
- Ls1 Parts
- Billy Boat Headers! Cheap
- Autometer Narrowband C2
- Ported LS3 Manifold, Nitrous Outlet Plate, Drag Wheels/Tires
- F.A.S.T. 102mm DBC Throttle Body
- TNT Nitrous System
- t56 trans part out (new parts list)
- TSP 228R Cam still basically brand new
- 5.3 block and other 5.3 parts
- 98-02 Fbody Air Conditioning system - COMPLETE
- Fuel Injectors 42lb Delphi 01D030B $250 Shipped
- 64mm turbo
- 347" stock cube nitrous ls1 record holder engine
- Kiwklift for the Texas guys
- SLP Z28 SS 98-02 New #12369963 Hood
- FS/FT: Like New 315 Nitto DR's
- 98-02 Trans Am Tail Lights
- Misc. F-body parts etc.
- LS3 intake
- LSX Performance parts Everything must go
- PA turbo Kmem, 37# inj, pacesetter LTs, TSP ORY, Comp918s
- Moser 9-Inch 3.50 Gearset And 31 Spline Detroit Tru-Trac
- Parting Out 1999 NBM Trans Am
- FAST 90mm
- 17" factory ws-6 wheels and tires
- NEW 145amp and 160 amp alternators F.S.
- Holden HSV Fuel Rail Covers
- 2001 White Camaro ls1/t56 roller partout
- LQ4 Parts - intake, camshaft, pushrods, valve springs
- TSP LS6 oil pump
- C6 Z06 stock shocks
- LS1 Long block
- ASA cam and valvetrain
- LS1 Engine mounts/ clam shells
- NOS RPM Window Switch with pills - Installed, never used
- AMS 1000 Boost controller
- Supercharger Cam $260 shipped
- Ls mustang swap driveshaft
- Spec Stage 3+ clutch
- FS: 7.350 chromoly pushrods
- Holley coil covers / slp lm2 muffler And x-pipe
- White eye phone 3G 8g
- Several parts for sale
- TSP 7.40 Pushrods like new
- T56 For a LS1 Setup, LS7 Clutch, McLeod, UMI
- Magnaflow catback with cutout welded on
- need some help...
- 85MM MAF and adapter
- 5th Gen Camaro bowtie emblems
- Corbeau VX 2000 seats FS
- 10 Gallon Aluminum Fuel Cell
- Weld Alumastar 15x14 and 15x4 w/tires
- FAST 102 Throttle Body (right cable drive)
- AC bracket, condenser, c5 wheels/tires
- 2011 Camaro LS3 Motor 7k miles upgraded with ECS cam, springs,etc.
- 60lb Injectors, 3.70 Gears, Misc Stock Parts
- C6 Factory wheels and tires 3/4 tread
- Percision pt7668s turbo t4
- LT1 PCM, Springs/Shocks, 94 Factory Bose
- Big Cam, Katech tensioner, Msd 2 step
- 16" wheels
- 98 - 02 Firebird Muffler
- truck muffler
- 98-02 bumper reinforcement
- aluminum drive shaft
- lca & panhard bar
- 4l65e forward housing
- 1999 Z28 T56 engine harness/ECU
- Part out 1999 Camaro SS
- stock 4l60e with yank 3400 ..
- VFN Sunoco hood DECALS
- Comp Cams 7.350 chromoly pushrods
- Touren wheels with locks
- Brian Tooley spec'd camshaft
- FS: OEM LS2 valve covers
- FS: stock complete LS2 heads (243 casting)
- Throw out bearing FS
- 4L70E Transmission *CHEAP*
- TBSS AWD Transfer Case *CHEAP*
- Jet Dynamic Spectrum Tuner 14005 3 Vehicles Left
- LTX for sale
- LS1 Katech Heads
- 2 engine harnesses for sale ls1/t56 and ls1/4l60
- 243 heads with Patriot Dual Valve springs
- 317 truck heads lq4 lq9 $125
- Yank extreme 4000 nitrous converter
- GTO Oil pan LS2 Complete
- NOS mini 2-stage progressive
- Nitrousoutlet automatic heated nitrous bottle bracket
- Firehawk wheels, Black wing lid, and LS6 valvetrain
- Dynatech Vortex Insert Cone 3 1/2 inch
- The Lingenfelter oil cooler adapter
- LS2/LQ9 pistons
- Delphi 57 lbs Injectors
- Dynatech split flow race mufflers
- head cam set up for sale
- ls1/ls3 injectors
- 98+ Camaro Taillights and berger panels
- 2000 silverado for parts
- Trying to finish my LS swap sale
- New complete PRC 2.5 6.0 heads forsale or trade.
- Ford svo green top 42lb fuel injectors
- 2004 gto part out 6 speed
- camaro ss hood and wing
- camaro 12 bolt
- LT1 Flexplate, Pedals, Automatic Parts, etc.
- Garage sale,LS1 engine block, 241 heads,intake,Clevite bearings, engine parts, cheap
- 2 cams for grabs
- 317 Heads FS
- Tons of parts for sale suspension, engine, and exhaust bmr, alston, hotchkis, SVO
- 99 TA Airbag DS/Leather Mirror covers
- WTB LS6 cam
- WTS Brand New LS6 Ported Oil Pump
- 10 spoke SS wheels
- DBW pedal
