View Full Version : Parts Classifieds
- Misc parts Gto oil pans etc
- l92 5.3 leftover parts NEED to sell before it all goes to the scrap yard
- wideband gage
- WTB whiper cover?
- 6le carbon sail panel, racetronix hotwire kit, 317 heads
- master power t61 turbo (x2)
- prostar trade for zr1s 11rears,or c5dd
- LS2 Throttle body, 85mm MAF, MSD Dashhawk
- random F body parts
- 414 Iron block fresh arp gridle $600
- 2004-2005 Predator tuner for GM V8's corvette GTO Silverado and more
- LS7 FAST 102mm intake manifold with factory fuel rail kit and injector spacers
- HP Tuners MPVI Pro GM
- WTB Weld Draglite 15x10 and 15x3.5 thank you
- Brand New Weld Prostars 5x4 on Hoosier Drag Tires
- 04 GTO ported MAF. Price drop! SOLD!
- Last of the LS parts
- 2005+ Corvette cargo net
- Misc. Parts Some brackets and 3.8 stuff
- Camaro part out !!!
- High performance ls parts for sale
- WTB GOOD stock axles
- 99 corvette parts
- 01 manifolds
- Trans am vizage GFX
- Stock Tail lights for a 98-02 trans am.
- Driver side headlight for 98-02 trans am
- Aftermarket Air Lid and Ram air box
- wtb ls3 heads
- wtb vic jr carb intake for l92 heads
- Sun visors (NEW) Grey in color
- 2000 Y2k for sale. For Corvette, Trans am and camaro
- CALLIES MAGNUM XL CRANKSHAFT: Part number apz39v-XL 3.185 Stroke
- LS9 MLS head gasket set ..(new in package)
- bosch 60# and booat a pump
- MSD super conductor wires LS1/LS2 *SOLD*
- Custom Torq-Thrust 2 center plates
- 241 heads
- NEW L92/LS3 heads complete
- LS swap parts, ecu, harness, intake Ect..
- LT1 ScanMaster
- MSD Digital 6 Plus
- Garrett T-6 GT47 1.08 Exh Housing
- Several parts for sale
- Valve covers, oil pump, for sale
- FS: new Aeromotive Fuel pressure regulator.
- sold!! stall converter yank pt4400
- 2007 club car golf cart gas $3500 or trade
- hardened pushrods,throttle body
- Corvette LS3 water pump
- Parting out 1993 Camaro 383 LT1 T56 FAST XFI
- Firehawk Wheels
- F body Pacesetters for sale
- sold delete thead please
- O2 Senor Extension 12" BRAND NEW!
- drag set up/gto parts
- Stock 10 Bolt rear
- Texas Speed 7.425 CM Pushrods
- MS4 camshaft - NEW
- LT1 ScanMaster
- MSD Digital 6
- Freddy Brown reverse manula valvebody.
- WTB LS7 Intake Manifold
- FOR SALE: Moser 9" /w Aluminum Housing and 4.10 gear slightly used
- Nitrous Kit for sale
- Windshield wipers complete
- TnT nitrous power ring with nozzles pics added PRICE DROPPED
- Katech Billet Manual Tensioner
- New 90MM NX Plate Kit W/ Gen X Kit
- PRC 227 heads, ms4 cam, Yella Terra rockers
- Fast billet fuel rails new
- C5 LS1 Parts
- Hydro Dipped L92 intake and Accufab TB
- comp trunion upgraded rockers
- Ls7 Fuel Rail and Injectors
- ls1 smog pump
- LS1 Alternator w/Bracket
- 98-04 LS1 LS6 Fuel Rail
- LS9 piston oil squirters
- vigilante 3600 converter
- Full 5.3 for sale
- Chrs1313 Ram Air + Air Box (Non-A/C Verson)
- LS1 intake Manifold
- SLP under drive pulley for 99-02 fbody
- factory monsoon radio
- Last of my LS engine parts
- FS - LS9 ZR1 Engine project
- lots of ls parts 243 heads,waterpump,balancer,cover etc
- LS1 Direct Port and NX Window Switch
- 04-06 cadillac cts-v engine wiring harness
- Callies Magnum Crankshaft
- 1998 Camaro PART OUT
- 42lb green top injectors
- Aeromotive 13129 bypass regulator
- Billet wheel HX52 Holset turbo..fresh rebuild!
- LS1 F-Body Water pump
- REAL Siemens Deka 60lb injectors..like new
- FTI th400, billet converter, SFI flexplate
- Comp Cams LT1 280XFI-HR13 XF cam brand New
- LS Motor 76MM Remote mount turbo kit
- FS: LS1 / T56 Engine Harness, PCM, Coilpacks, ls2 Engine Accesories w/ brackets
- 1.7 Harlan Sharp Non Adjustable Rockers
- 396ci and Level 3 T56
- 2x built 4L60E, suspension, inj., SLP exh. stock short block
- SOLD SOLD BigStuff3 (BS3-004-004) SOLD SOLD
- Solid roller cam KAUFFMANN valve springs ign coils front drag springs pushrods
- Katech rod bolts less than 100 miles!
- rear cailpers
- Texas Speed 10 Bolt Rear End Package
- Stock Ls1 engine parts-used
- G8 GT L76 Intake Manifold, Fuel Rail, Stock Injectors
- FS: Hypertech power programmer 3 99 LS1 Trans am or z28
- FS: LS6 78mm Ported TB, Injectors
- 44lb High Impedance Injectors LS1 Length *Low Miles*
- Carbs/fast wideband
- Alternator Relocation Bracket
- Complete holley highram - nitous system
- f/s complete LS3 and TR6060
- Koni Universal Coil-Overs
- Garage sale, Engine building tools, ETC ETC ETC
- Walbro GSL394 fuel pump fs
- new STS kit for chevy truck (GT 67)
- Rear Spring Isolaters
- Camaro SS Floor Mats & SLP Exhaust tips (gen4)
- 91mm Comp Turbo For Sale- Billet Wheel-Triplex Ceramic Ball Bearing-0 Miles On Turbo!
- MWC Fab. 9"
- F1R Procharger Kit
- LSX PCM's DBW & DBC
- LS2 Crankshaft/Intake, Eaton Supercharger - Prices Lowered!
- K&N x-stream 14" x 3" filter
- Autometer 5" tach and boost gauge
- Katech manual tensioner, KWIK alt bracket - truck
- 30lb (36lb @ 58psi) SVO "red top" injectors
- Sold.....
- Chrome FireHawk Wheels for sale !!!
- 85mm MAF *Low miles*
- Gauging Interest Forged LS1 Long Block
- Slp exhaust
- (8) 85lb/hr Delphi Injectors
- 2 sets of 317 heads with rockers and stands
- ls1 383 stroker short block fs\ft
- HOLLEY EFI pump 12-890 NEW
- LS1 block, Rollmaster LS1 timing set
- Edelbrock intake with NX Kit
- ls3 intake
- Siemens Deka 60lb injectors
- Garret GT91.....
- lm7 MAF
- Trinity T-1000 Tuner
- Monster Level 3 clutch/Pressure Plate/Flywheel
- FS- NX Kit, FJO, Bottles, Nitrous Mics.
- WTT/WTS Custom painted FRC's and SLP lid
- Taylor 8mm Spiro pro wires FS...
- LS1 F-body coil packs
- LS7 push rods fs
- 05 LS starter fs
- Rear control arms!!
- LSX 454 Bowtie block rear cover and new rear main seal
- 247/263 Custom Grind Cam +idle video
- 15x10 cragar prostars
- LS6 intake tb bolts sensors maf fuel rails and injectors
- NOS Brand Nitrous Plate
- cnc ported 243s ss valves prcs
- LS1 longblock, LS3 take off parts and more..
- FLT Level 4 4L60E | FTI SRL 4000 Billet Lockup Stall Converter (Less than 1000 Miles)
- Trans Am Honey Comb Tail Lights (PRICE DROP 5/28/13)
- PRC .675 EHT valve springs
- LS7 stock dry sump oil tank and lines for sale.. no pan.
- Garage Cleanout...stuff added 6/4
- F/S LS2 243 heads and timing chain
- Magnafuel 625 pro tuner fuel pump 4301
- 2010 LS3 block that needs fixed
- NIB UMI boxed weld in Sub-frame-connectors
- New front mount distributor kit
- Stock cats
- 1998 Z28. Cam/Stall/4l65E Part out Feeler..
- 2002 LS1 PCM ECM 6 speed
- HRE 547 3-piece forged 18x9.5 & 18x10.5 wheels For Sale Possibly trade
- PAC 1519 springs brand new in the box $200
- Nitto NT05R Drag Radial // 315-35-17
- TNT Nitrous Ring
- LS1 intake manifold & Throttle body
- This is a STEAL!! A Must sell!!!
- Innnovator west 8 rib Crank Pulley
- Stock like new 85mm maf screenless zo6
- S10 LS Swap CPW Long Tube Headers
- WTB: ts 224 or tsp228r
- LQ9 Parts
- LS6 Intake 4 Sale
- 44lb EV1 Injectors
- LS1 Fans for sale
- FS: nitrous outlet 102 plate kit
- 1 7/8 headers for sale
- Usmc helmet
- Corvette Ls1 Intake and Throttle Body
- 2001 ls6 short block
- arp stuff new in box
- Tony mamao ported fast lsxr102, cathederal type
- ARP Pro Series Head Studs
- LS6 LS2 valves
- Gm485
- Worked heads stock parts
- Vigilante Converter 3500 Converter th350
- FS: New - American Racing TTM - 2.5 inch center caps
- Chrome TTM's F/S.. (SOLD)
- stock truck accesories
- ls3 418. callies, weisco,comp, lunati,
- UMI LCA's Rotor-joint Brand new / LT1 Intake
- 2 Mickey Thompson ET Street 26x11.5x15 tires
- Ls1 intake and throttle body, non hurst stock shifter
- FS: FAST 102mm LSXRT Intake BNIB
- New Stock LT1 clutch disc
- Rod and main bearings - King and Clevite
- Nitrous Outlet Adjustable Wet kit FS: BRAND NEW!
- Lots of parts need to go garage cleanout 02 ss rims,block,heads ect.
- wtb fbody ls1 oil pan tray and tube
- Comp Cam XER273 LS - SOLD
- 241 heads, valve covers, stock rockers PRICE DROP
- Hurst Billet Shifter w/UMI Short Stick
- 2000 Auto harness, PCM, Throttle body, mounts,MAF, truck coils, valve covers, sensors
- Brand New, Never Used Chris1313 Ram Air
- Ls1 intake
- bad(not blown) LS7 rebuildable shortblock for sale in GA.
- A few more items for sale, console lid and oil filter adapter
- MSD/1050 Dominator/B&M/Misc. Parts
- 98-02 F-body ls1 Maf
- NRG Quick Release Hub kit with Spec D Steering Wheel
- Ls1 fuel rails
- New QA1 DS701 rear single adjustable shocks only
- (2) 3" Dougs Cutouts (Non electric - can add any motor)
- LS swap Hooker manifolds
- FS: stock LS2 90mm throttle body/new pac 650 valve springs
- Yellow and Blue Springs
- F/S Aruns Stage 3 Blower Cam, Like New
- F/S LS7 Lifters (fits ANY LS motor) like new
- Going LS, everthing LT must go!
- 383 LT1, Spohn complete suspension red in color upgraded ends
- flex fuel injectors
- Several sets of pushrods
- ls1 fuel injection system ,edelbrock,bosch,fast,psi,versafueler,lingenfelter
- RH 93-02 Firebird Trans Am Ground effect (White)
- FS- 3.45 Gear, LS9 Cam, LS9 Springs
- Clarion indash dvd player
- LS3 ring sets NEW
- LS3 pistons
- LS1 arp rod bolts
- 98+ headlights and o2 sims
- Ford Racing 42lb injectors for SOLD!!!!
