View Full Version : Parts Classifieds
- LS2 oil pan, valley cover, front and rear covers, crank pulley
- tnt nitrous bottle plus extras PRICE REDUCED
- WTT Vigalante 4000 for a tighter converter
- Monster Clutch Bogart RTs & 317 heads
- 2000 Trans Am WS6 Complete Part Out
- TNT 150 Nitrous kit
- misc. parts. ls1
- ARP LS1 stud kit, Comp Cams 7.40 pushrods
- Hidden Hitch for Fbody
- trickflow cnc'd 215s
- hardend chromoly 7.400 Trick Flow pushrods
- Tick Master LS6 Cam 60 lb Injectors, stock Top end
- Harland Sharp LS7 1.8 roller rockers
- Brand new ARP head studs pre 04 style heads
- Meziere LS1-LS8 Electric Race Water Pump (35 GPM)
- .650 prc springs and retainers need gone ASAP
- 130 amp one wire alternator
- Edelbrock 6570 headers
- MS3 Cam 237/242 114 LSA
- Moser 31 spline axles, Nodular center section, and locker
- Black -20 AN Fittings Grt 4 A2W intercoolers strts, 45 90 120 180
- ZEX Perimeter Plate with Nitrous Outlet solenoids
- Nitrous Outlet dedicated fuel cell <<SOLD>>
- Compstar Rods & Dragon Slayor Crank
- LS1 PCM bucket
- lt1 parts, 3in, 3out bullet muffler, stk fuel rail, flywheel.
- New Mallory boost reference regulator!
- 05 GTO fuel line
- LS2 intake manifold
- ls1 wet nitrous kit and purge
- WTS/WTT 18" Corvette thinspokes (Y2Ks)
- Greg Banish - Calibrated for Success DVD 1
- SLP TOTL, Howards 98215 springs, Raptor hood, Lunati custom LTX cam
- L76 intake, 90mm HSW plate, FAST 90mm fs & more!
- HP Tuners Pro for sale
- FIC 127lb injectors. F/S
- Nitrous kit for sale. Brand new
- FS: Precision 64mm turbos
- Nitrous outlet 85mm plate
- For Sale: LS1 Lifters, Spark Plug Wires, and AC Compressor Bracket
- Sealed Power E-938K Rings 3.897"
- 38 lb injectors, Stock Driveshaft, Fuel Lines, Fuel Rails, K-member
- Full-Race Borg Warner S300SX FMW and Full-Race custom intercooler **NEW**
- Moroso 63566 GM LS Series Electric Water Pump w/Adapter Blocks
- 01 Z28 Part out
- Lq4 part out
- 1999 Camaro Gauge Cluster with White Face Cover
- LS6 intake, Fuel Rails, LS1 Coil packs
- need stock lower control arms
- PA Racing upper and lower control arms,Chicago.
- WP319S Meziere WP
- FS: LS1 Strut tower brace, driveshaft loop, and more
- AFR dual springs takeoff .650 lift TI retainers
- Stock WS6 Springs (1996)
- Camaro Manta Stripe - Silver
- (4) Brand New Aftermarket Chrome 10-Spoke SS Wheels w/ Center caps
- 08 LY6 6.0 bare block
- Slp coated headers 1 3/4 with egr provisions
- 2000 ws6 ls1 trans am dash harness cheap
- Vented catch can
- lt1 scanmaster wideband guages xpipe
- Z06 and fbody parts cam,stall,ls6 valve springs interior,exterior
- Nitrous
- Go slow parts sale! Stock 27k parts and some other!
- Intake/tb sold!
- 158 Lugnuts & 47 Lug Nut Caps - WILL SPLIT
- 4 16" 5spoke firebird ABS Wheels w tires (CHEAP)
- Pcm 12200411 LS based engine
- Procharger 3.5" and 3.6" 6 rib pullies (pulley)
- LT1 Bare Block, Half-filled, shot peened, hot tanked - Local Pickup (South Florida)
- LT1 Canton Valve Covers
- Lt1 magnaflow cat back
- Ms3 texasspeed cam
- Custom sheetmetal valvecovers FS...
- 2bar map sensor, 5pt harness, alt relocation bracket, boost gauge
- WTT OEM black ss hood for black sunoco hood
- lower price TT2s, blower cam, mandrel bends fs
- 862 5.3 heads,TBSS speedo, LS2 cam and springs, tan carpet
- CP Carillo Turbo Pistons 418 Stroker
- Poly motor mounts and MSD window switch 8969
- Ls3 SDPC cnc heads, yella terra rockers, intake injectors
- F/S Brand New Axxess ASWC
- HPM, LCA's, QA1, Eagle, T&D
- Firehawk--- 1995 Center Caps- LS1 Hawk Nose Emblem, $120 for both
- Turbosmart Eboost Controllers, Eboost 2's and Street
- WS6 Lower airbox 4 Sale
- LS1 LS2 LS6 flywheels and LS6 clutch kit
- msd timing twister new in box never used ls2/ls7
- FS: Kooks Long Tube Headers 1-7/8" x 3" - Jet Hot 1700 Extreme Degree Sterling Silver
- Racetronix LS1/LS6 42 lb Fuel Injectors
- ported ls2 intake 92mm TB and ls3 fuel rail
- 1 3/4" SS headers from Quick time performance
- WTT\WTS TTM 17x9 17x10.5 ASAP
- Paint matched L76 intake, GMPP valve covers (Will repaint to color of your choice!)
- LOOKING FOR: Body/interior pieces
- vortech 6 rib 3.6 pulley
- HP Tuners Pro
- Garmin Nuvi 1300 LMT 4.3
- FS: Fast Ported 90mm intake, custom RK NA cam, TEA 243's, much more go fast parts.
- FTP 104MM Lid, Trade for 98MM or?
- Nib complete bearing kit for t56
- BMR lowering springs and bump stops
- Yukon 3.73 (2 series carrier)
- WTT/Sale Polished CCW classics
- GI: Fast 102 truck intake with fast rails...
- Texas Speed Ported LS6 oil pump
- Jet Hot Long Tube Headers F-Body *PICS ADDED*
- Stock parts (Truck coils/ heads/ intake)
- MS3 (magicstick 3) Camshaft
- LS C5/C6/Truck/Fbody garage sale
- Slp dual/dual muffler/tailpipes SOLD
- Fs Arh 1 7/8 headers
- LS3 LS7 valley cover and gasket
- 241 Heads and stock cam plus more!
- Brand New EmblemPros Automatic Ashtray Switch Panel
- some lt1 parts
- FTP 104MM Lid - All Items SOLD
- Ptm 92mm tb f/s
- Cometic 4.130" Head Gaskets
- Upgraded 4L80e
- Holley 90mm Throttle Body
- f/s c6 z06 black rims and tires
- Firehawk Center Caps
- WTT TCI LS -TH350 flexplate for a LS specific flexplate
- FAST 90 Intake
- Lt1 T56 Swap for sale/trade
- PSI Conversion Wiring Harness With Computer
- KB BAP, LS7 & LS3 Intakes 65lb injectors & More
- Yank PT4400
- Stock Master Cylinder With Drill Mod $30 Shipped
- BMR turbo kmember
- Ls1&t56 complete 01 ws6 drop out will ship
- FREE - Complete 2003 Truck Intake - SAN DIEGO ONLY
- Lq4 + 4l80 FS
- Harrop ITB intake, cam, springs, YT adj. rockers
- Fast Intake Stainless Hardware Kit
- Hooker Cat-Back Exhaust
- slp ds loop and 3" dyno max bullet
- 1999-2002 Trans Am gauge cluster (110k miles)
- BMR extreme torque arm
- ls parts ls6 oil pump, push rods etc.
- (((Autometer Guages))) Wideband/ Digital Boost/ Oil Temp
- detroit Locker
- Fully Assembled LS3 Heads
- NX Remote Bottle Opener
- Eagle H-Beam Rods CRS6125O3D2000
- FS: comp cams pushrods 7.45 @ .080 wall thickness
- AFR 205 Heads for LS1/LS6 10k miles
- Full-Race Tial MVR wastegates, Full-Race Tial Q-Valves **NEW)
- ATI super damper (f-body)
- (((BLOWER CAM))) brand new
- WTS: 22" USW Forged ZR1-esque monoblock wheels/tires
- wheel spacer/adapters
- ASA LS1 RAZOR single stage scaveng dry sump pump
- Aeromotive ls2 fuel rails
- 93-02 OEM Red Z28 spoiler
- 98 Camaro V6 roller or part out.
- kooks 3" x 3" header pipes with crossover and off road pipes
- Ls3/Ls7 42lb injectors for sale
- fast 102 (ls1)
- lt1 rubber elbow
- New AFCO DA Coilovers Front and Rear
- Hotchkis boxed LCA
- ABS delete block
- LS3 parts
- FS: New Autometer 5701 Boost Gauge $50 plus ship
- FS: Truck coils part number 12558693 with brackets and harness
- Msd 2-step for ls engines
- Kooks afterburner axle back for Pontiac Gto! low miles great condition.
- Ft only th400
- 1999 Corvette GM service manuals vol 1-3
- TA performance 10 bolt aluminum diff cover
- LOOKIN FOR A/C compressor
- eibach sportline springs
- Garrett GT42RS Ball Bearing Turbo
- 5.3/LS1 Parts
- LS6 Sodium Filled Valves (complete set)
- APS Twin Turbo kit Fbody
- Polished Edelbrock ls1 victor jr. with Aaron's elbow neck plus
- Complete LS6 Intake - Price drop
- CBR ls1 alternater relocation kit NIB
- wide variety of stock LS1 parts
- 5.3 & 4160e drive train
- For Sale or Trade / Weld Draglites 3 pairs
- Holley filter, Spohn weld-in LCA
- brand new drag wheels,gto parts.
- OEM LS6 Plug Wires (Red)
- 6.0L LQ4 shortblock, AEM UEGO, radiator, etc...
- aem wideband
- c6 wheels and tires
- Ls1 trans am parts
- Pioneer 12 Disc CD Changer CDX-M2116
- lq4 + wiring + MAF
- Misc. Camaro Parts
- 02 Camaro SS Engine harness/ECU M6
- applied nitrous system REDUCED PRICE
- LS7 Lifters NEW IN BOX
- PST 3.00" Chromoly 1350 Series with Forged Slip Yoke
- Hallman PRO RX Boost Controller
- Gauges
- LS3 Intake Manifold and Fuel Rail
- Trick Flow 7.400" Push rods
- Cloyes Hex-a-just timing sets
- Moser 9 Inch Complete- Chicagoland Area!
- LQ4 short block, L92 Heads, LS3 intake.
- New Texas speed cam package
- NIB Patriot Performance Stage 3 LS6 heads
- Truck harnesses and PCM's
- MTI Racing Throttle Body
- Harness and PCM from 00' A4 TA
- 4.10 9'' street gear
- Victor Jr. EFI with Cold Fusion Direct port
- ZR1 Factory X-pipe with under 100 miles
- ZO6 exhaust manifolds, cats, H-pipe, Bi-mode mufflers with mod
- 255 intank fuel pump
- need it gone Corbeau Froza seat
- Mocal Oil Cooler T-stat for sale!!!
- 4.125 scat crank 7 6.125 scat rods BRAND NEW
- LS7 brand new set of stainless exhaust valves
- Callaway Honker cold air intake for LT1
- ls1 lq4 408 lunati 4.0, diamond -2cc, DFW
- A-Body Full Turbo Kit
- FS:maggie 112 ls6 kit
- Rear 17" CCW classics, m&h 325's
- borla, camaro interior, body parts
- Two 4500psi Nano kits
- Gto 1 piece alum drive shaft, 42lb injectors, snow meth kit
- NOS remote bottle opener 14168NOS brand new in box
- FS: NIB Comp Link Bar Short Travel Lifters
- (2) NEW Chrome 10 Spoke Bowtie Centercaps
- Brand new GM LS1/ls6 oil pump
- Brand new LS1 O2 extensions (pair)
- 00 z06 injectors
- Bilsteins/Eibachs
- 2 ls1 intakes without egr and one with, Fuel rail and injectors throttle body also
- Lq4/lq9, 5.3, 6.0, 6.2 etc....
- f-body weld magnum 2.0's msd digital 7 weldon 2025
- NIB BBK Longtubes and Y pipe
- Complete ZEX Nitrous Kit
- Cleaning out garage sale
- corsa clones
- 02+ LS6 Cam
- SOLD___Manual steering rack___SOLD
- T56
- Garage clean out..Kirkey, Simpson, Batt Box, Elbow, Etc
- 93-02 camaro tail lights
- WTT th350 + cash for ls1 t56
- CCW Classics with Tires. Price lowered.
- LS1 F-body engine mount bushings and clamshells FS
- 1996 F-Body GM Factory Service Manuals
