View Full Version : Parts Classifieds
- Turbonetics t72 .96 a/r - roughly 1,500 miles
- LY6 complete intake, wiring harness, exhaust man, cam, etc.
- Drag Wheel setup and TH350
- SOLD LME L92 based 416 stroker engine SOLD
- Zex tps switch, msd wires, factory stall converter
- WTB: 6.0 Iron block
- 348” LS1 Turbo Motor/All Pro Heads
- FS: Build 4L65e
- Nice 243 heads
- Raptor single mode adjustable rpm shift light
- f-body parts for sale---------
- Baer Mustang Brake kit
- LT1 revmaxx 4k stall
- WTB fast92/ls2tb/LT1 stall
- PredatorU7198/ported LS6 throttle body&more
- F body parts
- Master Power 76mm Turbo
- 3500 stall converter
- MSD LS 2 step part # 8733
- 1998 LS1 Harness (6 speed)
- BMR Torque Arm Relocation Bracket.
- looking for an ls1 coolant crossover tube front to rear hook-ups
- cams
- Procharger support bracket
- LS1/6 Fresh Shortblock
- E cutout, cometic, 853, zr1, Mickey Thompson
- Garage Sale! New items added!
- FS: Nick Williams 102MM Throttle Body - Used - $400
- 98 pcm with frost base tune/ purple fast fuel rails
- LSA Heads
- BNIB forged Manley rods
- T56 bellhousing, Drag Wheels
- 48k mile 6L90e/converter with transfer case
- Brand New LS2 Flat Pulley Water Pump, Valve Covers, Valley Cover
- Turbo, 60lb Injectors, 05 GTO Parts, Etc
- T56 Transmission, bell housing, shifter - NW Indiana
- LS1 T56 transmission -- low miles -- SOLD
- WTB: 5.3,5.7, or 6.0 shortblock or long block
- For Sale : LS6 intake & TB
- LS1 Fuel Rails
- Extra 5.3 parts
- Precision torque converter 3200 stall
- 35th LE center Cap up for sale
- A few Stock 95 T/A parts for sale+ LT1 Canton Valve covers (PA)
- Stock Hurst shift knob
- WTB: 7.5 gears 3.42 or 3.73.
- UMI Performance Camaro/Firebird 82-92 Torque Arm Relocation Kit/Transmission Crossmem
- Fresh TH400, zero miles on rebuild.
- 1999 Z/28 Roller CLEAN! Extras F/S
- 4th gen Radiator and Electric Fans & other stock parts!!!
- Trade BMR springs for low mile WS6 Springs
- Monsoon CD player
- polyurethane bump stops
- *USED* Nitto DRs 275/40/17
- Ford Windstar electric fans
- Ls main cap removel tool
- LSx swap mounts for 86-91 RX7
- SOLD. NIB Fast 92mm Cath. Intake. SOLD
- F/S D1SC kit and more
- LS3 injectors
- GTO ext door handles & Walbro 255 fuel pump ///PICS
- 26x11.50x15 QTPs
- 18x10.5/9.5 Z06 Motorsport Wheels and Toyo RA1 Tires
- factory aluminum driveshaft
- Random Stuff
- parts for sell
- F1a procharger
- B&b mufflers cut outs corsa tips an other exhausts
- LS1 Stock Throttle Body TB
- FS: Hickock (FM10 Style Wheels) Goodyear GS-C/GS-D3 Tires -- Arlington TX
- Lookin for 17in RTS or drag lights black?
- Richmond 2 series 3:73 gears
- Built T56 for sale
- FS: 243 heads
- Oem Gm zl1 hoods factory painted
- Comp Cams 875-16 "R" lifters NIB
- GMMG catback for sale
- banks programmer (truck)
- parts for sale
- Type R's/Amp/Wiring Kit
- 2000 Camaro/Firebird Service Manuals + Dealer Brochure
- Gm gen iii 5.3 6.0 lq4 lq9 lsx d585 ignition coils w/brackets and wire harness
- Dual Fuel pump setup, With rails, wire harnesses and hobs switch. 99-02
- Ms4 and springs
- 19" VMR Staggered Rims and tires.
- Huron Speed Alternator relocation brackets
- FS: strange front pro drag brakes
- 98-02 Camaro front fenders SOLD!
- Trans am HID setup, Underdrive harmonic balancer, and more! PRICES LOWERED
- LS3 complete heads FS
- TFS Trick Flow 235cc cathedral port Heads, barely used
- Fikse FM5 17x9.5/17x11 with tires for F-body in TX
- Sold sold sold
- Diablo Intune
- Hughes GM Powerglide 2 speed, rated @ 1700hp
- Parting out turbo Camaro
- LS1 IAT sensor, stock throttle body, stock MAF w/ pigtail
- Nitrous Oulet Plate kit (50-200hp)
- LSx conversion ECT sensors
- sell or trade 6.0 parts
- Built T56, Swap Package, Spec 3, and Wilwood Adj. Master Package.
- Ls6 cam and springs
- 4th gen Camaro parts/misc.
- 98-02 Firebird Silver Blackbird Decals & Asp 25% UD Pulley Sold!!!
- Chrome ZR1 wheels- new Nitto tires
- LS1 ARP Headbolts..97-03
- Ls1 stock cams, valley cover, 98' valve covers & rockers
- SLP fan switch
- LS3 Parts: Crank, rods, pistons and cam
- [SOLD] - Any interest in an SFI bellhousing for LS engines/T56?
- FS: Nick Williams 90mm TB
- holley hi-ram intake for ls3 heads
- Bogart D10 Skinnies/American Racing Torque Thrusts FS!!
- polished conversion brackets
- Set of 4 Winter Tires 225/55R16 Dunlop Graspic DS3 - $225
- Sold!
- PTM 90mm throttle body
- GMMG catback less than 4,000 miles FS !!!SOLD!!!
- 6 speed tremec t56 with clutch and throw out bearing and
- NIB 408 rotating assembly/ springs/push rods/ lsx102 rt
- 5th GEN CAMARO WHEELS 18"
- Full exhaust
- Ls6 intake
- 4L65E. Keisler stage 2 built.
- Zex nos kit for sale or trade for Gto parts
- Spohn Solid mounts and Truck coil packs
- Gunmetal C6 wheels 19" 18" mint w/tires
- 2000 T/A ABS module/actuator SOLD
- Circle-D 258mm 3400 Converter
- Lq9
- Go-fast parts!
- Trans Am Parts 98-02
- 2002 pontiac firebird trans am ws6 for parts
- FAST 90mm fuel rails and lines p.n. # 30-54023
- FULLY BUILT 6.0L LQ9 engine w/ oringed block and head
- Yank converter, 90mm TB, Xlink
- 317 headsfor sale
- FS: Pontiac Monsoon Speakers
- ATI Crank Pinning Kit
- WTB: F-body LS1 Harmonic Balancer for non-AC
- fs: ls6 lifters new in box
- Ls3 injectors
- FS Pushrods
- '04-'06 GTO Tinted Tailights by Jorge
- LS1 intake, TB, Injectors, and Fuel rail
- MEGAPORTED Edelbrock TPI setup
- 2002 ws6 trans am body parts
- Custom Kooks ORY with 3-1/2" cutouts
- 243 heads with many other parts
- Fs:Ported Fast 90 with Nw92mm tb
- drag wheels ( new)/gto stock stuff
- WTT Machined Stroker LQ9 for LS block
- Tick SNS torquemax stage 3 cam Brand New
- used mcleod RST clutch 6k miles
- built 3.90 diff dss shafts, corvette
- m6 t56 corvette
- ls1 longblock
- LS3 corvette exhaust manifolds
- 5.3, 6.0 exhaust manifolds with 2.5'' v-bands welded on
- TR CheaTR V3 cam
- 5.3 and a few ls1 parts bought for swap
- BNIB UMI performance driveshaft loop for longtube headers $90 shipped (SOLD)
- Founders Relocation Brackets BRAND NEW Black Bolt In - SOLD
- Yella terra adjustable rockers
- Fan shroud and 17" GM fan with wiring pig tail
- LS1 water pump F/S
- Ford green top 42# injectors
- FS:weather guard tool boxes and ladder racks for 8ft bed
- New Lunati Dual Valve Spring Kit
- Worked 243's $525
- NOS plate, LS1 intake, Fuel rails
- Super vic with nitrous outlet Spray Bar F/S....
- F/s Alpine CDE-133BT Head Unit and Install Items
- PS Delete Alternator Bracket
- Nitrous outlet, trick performance progressive controller
- hypertech 3 for 00' f-body $100 obo
- LSA Heads - brand new, with valves & springs!
- NEW CNC Heads - Save $200 - Stage 1 LS6 Texas Speed PRC 243 799
- fs lt1 arp head bolts and main studs
- NIB CME kit...SOLD
- Non-EGR manifolds (2 Sets) LQ4 Oilpan, Water pump
- Comp Cams 231/247 617/624 113 LSA cam
- WTT: TT2 275front 315back
- Ls1 WS6 High-Rise Lower Air Box, modifieLs1 WS6 High-Rise Lower Air Box $200 obo + sh
- LT1 Firebird Sidemarkets/Flashers fits Trans Am / Formula $25
- LT1 stock MAF sensor $45+ship
- LT1 155 mph Gage Cluster $110
- pr double valvesprings
- Spool, matching 33 spline Moser axles,4.10 gears for 93-02 F body Moser 9 "
- F-Body LS1 Alternator Bracket,WS6 Hi-Rise Lid Base..pics uploaded........
- Master Power MPT70 & MPT76
- 4l60e swap kit
- Alt. relocation
- TNT F1 nitrous kit with power ring!!$250
- 4L60 w/brake and converter
- 4l60e
- Ls1 motor! No intake rails or injectors
- Stock Firebird/Trans Am parts, 5.3 parts, Walbro
- BMR tubular front suspension,flaming river rack,shocks,springs
- 2001 Camaro SS M6 part-out
- aem truboost, truck manifolds, spohn solid mounts, -6 stainless trans cooler line.
- New 4inch qtp cutout,hp tuners pro with credits, Chicago
- Garret Gt-91 Turbo
- HURST BILLET T56 shifter = SOLD
- ls in a fox turbo kit
- Corvette c5 red brake calipers 1997-2004
- 423 LS Iron block 13:1 N20!
- FS: Kook 1 3/4 Headers and Kooks O/R Y Pipe
- LS3 motor parts
- WTB: LS1 Camaro oil pan, pick up tube, and windage tray
- Last chance 4th gen charcoal leather seats
- Sold!!! c5 corvette manual shift knob and stock f body shifter
- SLP bowtie grille, and SLP 160* thermostat NIB
- Performabuilt 4L60E LT1 FS OR TRADE
- 00 4.8L Truck Pcm
- LS7 Titanium Rods set of 8
- <15k mile 2006 gto t56 transmission
- FS - BOV 's, 3.42 's, Underdrive pulley, etc...
- LS1 Solid Roller Setup
- GMMG Catback...SOLD
- Garage sale stuff
- Firebird Phoenix Manual Shift knob
- on 3 turbo kit
- Ls3 misc
- Big Power partout, tranny, fuel system, turbo kit etc
- Intrax Lowering Springs
- Textralia twin plate exo-skel clutch
- Brand new Spicer 5-460x and Tick slave shims
- some stock/oem stuff for sale
- BNIB GoPro Hero3 Black Edition
- KDI Ported 1.9 Blower Case + Nitrous Spray Bars!!
- Interior plastics
- New Tick adj. Master Cylinder 4 Sale
- Want!! 2002 Camaro SS OEM hood
- 2002 F Body LS1 A/C Compressor, pulleys, and lines USED
- 93-02 F-body battery
- WTB: 6L Block
- Stock LCAs and Ebrake handle/cable
- LS1/LS6 Parts New 7.425 Hardened Pushrods $75 Shipped - CTS-V Slave Cylinder $60
- C6 corvette wheels 19x10 18x8.5
- LS1 TB/MAF/Intake
- precision 39mm wastegate *like new*
- Misc parts pushrods rocker arms d585 coils springs covers etc..
- Ls1 hotcam. Brand new!
- 99 LS1 SS camaro gauge cluster 42k
- FAST 90 Intake and 90 Throttle Body
- precision gt4276 turbo freshly rebuilt
- 2009 corvette ls3 6 speed manual vert major part out, nothing wrecked
- FS: Weld 17X4.5 2.0 Alumastars Chrome Chevy Bolt pattern
- Ls3 heads with rocker arms and springs
