View Full Version : Parts Classifieds
- Zo6 wheels with 275/40/17 tires
- LS1 Alternator Relocation Bracket Kit
- Apexi AVCR boost controller
- Walboro 400, Stock Z06 injectors
- Greg Banish beginner's dvd **SOLD**
- 2000 6.0 Liter LQ4 4L80e Dropout
- FS...247/251 cam...LS2 Timing chain...stock rockers
- Pro 5.0 Shifter (Power Tower for T56)
- Sold***
- 6.0 and Ls1 Parts
- HID Ballast
- The $25 and under Sale...
- 04' GTO harness/ECM modified by current performance
- Pacestter Headers and Delphi 42lb injectors
- LS3 corvette K&N intake
- 98 LS1 4l60e take out with conversion parts
- Edelbrock 750 Carb and Calibration Kit For Trade/Sale
- Patriot Stg3 LQ9 72cc Heads Complete w/ Springs **$550**
- NIB Hooker Tips
- WTT t56 setup for built 4l60e
- comp cam short travel race lifters(BRAND NEW)
- 2006 Pontiac GTO Stock Parts
- fuel system parts
- LS6 243 Cylinder Heads
- BMR used non-adjustable torque arm
- stock 3.42 gears pics
- Lg g6x3 cam
- Dirty dingo truck idler pulley relocation
- Magnaflow Quad Tip Stainless Catback - Sold
- BBK SSI Intake Manifold - Sold!
- NEW PICS ADDED: Magnaflow 4" Dual tips SS trade for FAST with cash
- 17x10 Weld RT-S Wheels + Mickey Thompson Tires
- Nitrous Outlet Nitrous Noid; NX iceman solenoids F/S
- Front and rear black out kit, C5 Z06 wheels
- ls1/gto/wheels, part out
- Fs:6l80 converter
- [IL] FS: Spohn Lower Control Arms, Non-adjustable, Poly bushings $65 shipped
- 2003 5.3l, cammed, milled 853s
- FIC 52lb LS2 Injectors
- (BRAND NEW)Holley Dominator In-Line Billet Fuel Pump
- 383 ls6 block, Ported 243 Heads
- 5.3 Motor Intake to oil pan
- Isky cam
- Stock 4l60e only 50k miles! Perfect working condition!
- FS: NOS Nitrous Filter $32 shipped
- * SOLD * Alternator Relocation Bracket/Belt Kit for Truck Manifold Turbo People
- LS3 headed Custom supercharger setup
- F.S L92 Escalade top end. Assembled heads/Rockers/L92 truck intake.
- WTB. Disc changer CD holder
- Flowmaster merge pipe
- LE LT1 Custom Cam with valve springs/retainers
- 98 c5 ls1 throttle body and air pump
- Hastings stock LS2/LQ4 piston ring set
- 60lb FIC Fuel Injectors For Sale and Adaptor Harness- LIKE NEW! $250 Shipped!
- Porter Cable 7424xp with assorted pads(like new)
- LT1 heads and intake
- F-Body 6LE Splitter
- SDPC CNC LSA Heads Assembled & Bare NEW
- FS: 98 Head Lights and Fog Lights w/ Brackets
- 18x9.5" Wheels! SOLD!
- FS: LS Parts - Spohn Panhard Bar, M6 Pedals, Center Console, T-tops, driveshaft
- FS 2006 LS2 GTO Engine Harness & DBW Throttle Body
- Wtb: ls3 coils ASAP
- Performance Parts & Stock
- Fast 36Ib Injectors
- LT1 Ported Heads
- GMPP ASA Cam
- PTC 4000- 11K miles- 400$ shipped
- SOLD SOLD 2001 Corvette DBW TB $55 shipped
- Racetronix 42# injectors - SOLD
- Big cam, C5 manifolds, F-body bushing kit
- 4l60e lost 3/4 good for rebuild pickup only
- LS6 Intake Manifold - $300 + $shipping
- LS2 Based 408 Brand New
- FS: Prostar front runners, FRCs, and a FMIC
- 2 Corsa 6 inch round mufflers with tips.
- BBK 80mm Throttle Body For Sale
- Corvette Alternator
- LY6 engine, 6L80E transmission and transfer case 2007 HD
- Vigilante 3200
- Corvette red Fuel Rail Covers
- HSW 78mm Nitrous Plate
- Misc F-Body Parts
- Brand new Big Nasty cam 240/244 108lsa
- Ls2 fuel rail, ls3 injectors, fast ev6 too ev1 set
- If you want to do a 4L80E Swap you need this!
- 4l60e vigilante torque converter, spohn lsx solid motor mounts, Aaron's 6061
- Head studs for 97-04 LS1 blocks
- Bogart D10 wheels for 93-02 F-body
- bare ls1 intake
- Full Jake's Stage 3 4L80E Swap
- LQ4 complete intake setup and valley plate...
- Nasty Performance Fuel System
- with tubular k member w/upper and lower a arms
- FS: 2008 C6 Comp Grey GM Stock Split-Spokes
- Holley HR Intake LS3.....
- a few Lt1 performance parts for sale
- 6.2 Shortblock 800 Miles... **Reduced**
- Turbonetics Harris Speedworks Nitrous ls3 l92 and more
- Must sale:Ton LSpart:coils,pump,lifters,chain,oilpan,c atback,pulley,cam,coversPICS
- BMR Polished Radiator Support
- TSP 224/228 & AI 241 heads
- Truck Manifolds
- exedy twin disc clutches
- 2 stock maf and 1 stock throttle body
- ls7 oem rocker arms
- accufab 4150 throttle body
- Gm LS7 single plane intake
- WTB SS front Grill polished and Koni or Bilsteins shocks and springs
- Texas Speed Fbody Headers
- varrstoen wheels Price Drop 5/2
- Manual pedal assembly $75 shipped
- LS2 injectors under 5k miles $80 shipped
- LS3 take off injectors only 5k miles $105
- True Duals **$100** (new pics)
- 408 Build for boost, F1R set up and 4L80e
- GTO Spares w/ M&H Front Runners
- 3026 powerstick chambered mufflers (GMMG)
- Fbody parts, nitrous kit and parts, etc.
- Firebird Cloth Door Panels (NO CRACK!)
- LS2 GTO Parts & 240sx Sikky LSX Headers
- F/S Nitto NT05 335/30/19 tires like new!
- camaro parts ls1 -lt1
- LS1 GM Seals and Melling Oil Pump
- '93 - '02 Camaro/Firebird rear well sub enclosure for 12" subs (Orlando, FL)
- Trick Performance digital N2O controller
- Holley Harness - Injector & 4l80/4l60
- LS3 EFI VICTOR JR., ls3 head gaskets and ls3 rockers
- SOLD - Procharger kit - SDCE - FMIC - Meth - Etc
- edelbrock motor mount swap adapter plates
- 98 WS6 Parts from **PRICES LOWERED ALOT***
- 96lb fuel injectors
- 2001 Z06 (LS6) Cam 64k miles great shape!
- 102mm TB, X-Link, Katech Tensioner Truck
- torque converter, msd wires, bose radio
- New FAST 92mm intake & 90mm nitrous plate
- WTT AFR 225 72cc
- FS: Brand Spanking New BF Goodrich g-Force T/A KDW2 Tires
- ARP Main Studs *NEW*
- LS3 Throttlebody *NEW*
- LS2 C6 Corvette press. Plate clutch flywheel intake and cam F/S
- FAST LSXR 102 intake with rails for cathedral port heads
- Precision 7675 .81 Housing
- Front Koni DA with springs
- Spohn Chassis Mount Torque Arm
- FS: c6z wheels/tires for base corvette
- 383 ls1
- 427 ls3
- turbonetics midframe 78 T4 turbo
- ls6 intake, throttle body, fuel rail
- stock ls1 cam and rods
- ls2 intake manifold throttle body harness pcm shifter cam
- UNLOCKED Diablosport Predator 01-04 Chevy GMC Duramax
- 4 "bfgoodrich g-Force T/A KDW 2" tires 255/30zr20 $150 for all 4
- G-Force Pro Eliminator SA2010 Legal Helmet, Mint Condition
- 98-02 camaro, Brand New smoked halo headlights
- FAST 102mm Intake
- LS9 injectors, stock LS1 parts, C5 corvette parts
- Black OEM Z28 Spoiler
- LS6 Intake
- Tan Leather seats. Front and Rear.
- black C5 z06 wheels
- OEM C5 Z06 rims for sale
- 2002 Z28 Partout (updated pics and video
- fs hp tuners pro 350.00
- 95 firebird part out. Scanmaster, Crane Rockers, MAF, PCM, Injectos
- LS6 Intake manifold
- Lingenfelter CNC-Ported 243-casting LS6 heads – Flow 320/224
- FS - ECS Oil Takeoff Block; 72lb LS3 injectors
- 2001 SS Camaro Factory Cooling fans, $65.
- WS6 Exhaust, true duels, pace setter heads and more
- turbo smart E BOOST-2 ebc
- GI short block ls2
- Wtb 93-02 TA Camaro rear exhaust mounts
- OEM Factory 98-02 WS6 Hood
- T56 Six Speed: Less than 40k miles and refreshed
- hughes 22-2500 stall converter
- Lou Short Stick FS - 52501-SS
- Autometer 3240 shift light brand new
- LS1 T350 built with trans brake, Hurst shifter, UMI cross member
- Slave Cylinders Lightweight Flywheel and Weld Lugs
- TRUE dual 3" for F-body with full length headers.
- SOLD SOLD brand new ls7 lifters! 110 shipped
- old sbc parts, throttle body, coils, injectors, cheap!!!
- Magnacharger MP112 sold
- LT1 OBD II Auto Tap Scan Tool & JET DST Tuner
- SS/ZR1 wheels/tires
- 99 Z28 Windshield Washer Reservoir and Pump
- SOLD NEW NX EFI Race Kit
- LS2 GTO Parts + S13 240sx SIKKY 1 7/8 Headers
- SLP 85mm MAF with pigtail
- LS6 yellow beehive springs
- x link 3.0 throttle body adpter
- Acceleronics versafueler and 160 pound injectors
- FS Transam/GTO misc: Wing LED, Stock 17's,6.0 Emblem,Leftside Transam Taillight
- LS1 Comp Cam (227 223 .614 .610 115) 80lb Seimens Injectors, ARP Head Bolts, LS1 MAF
- Lt1 nitrous Harris wet kit W/58mm nitrous outlet plate and mallory 685
- LS6 used valve springs.
- Sold
- Several parts with a/c
- Lingenfelter LNC-001 Two Step / Launch Control
- 95 LT1 Long block alum heads
- Billet Specialties Street lites/MT drag radials.
- WTB: Exhaust Hanger Assy for Magnaflow Kit
- 160lb fuel injectors
- Snap On ethos plus touch screen diagnostic scanner
- Rear tan leather seats
- LT1 AFR 180 heads for sale...
- FTI 3200 stall for fbody or GTO
- Sainless Magnaflow Muffler, Powerglide Fbody Crossmember
- 78mm Nitrous Plate
- L92 Ls3 6L80E Complete 42k
- New Racetronix fuel pump and hot wire kit 99-02 SOLD!
- FS: 6.2L L99/LS3 Short Block 26k miles
- Diamond 4.030 pistons, Stroker- used, SOLD
- LS1 intake
- FS: 4'' Silicone coupler 45deg red
- TIG Welded Stand Alone Fuel System
- ALL PRO Intake
- Brand New ALL PRO INTAKE
- 6.0L Block and other parts
- Comp Cams Beehive Valve Springs (Set of 16)
- Cadillac CTS Gibson Exhaust
- Holley 90MM DBC T/B
- Weld wheels (like new)
- 100% complete built TH350 trans
- FLOWMASTER Cat Back Exhaust system
- Grey Interior plastics, Black Leather Rear Seats, Door Panels
- American Racing 1 7/8 to 2" step headers for GTO
- B&M Pro Stick
- EPS 226/234 .598/.601 cam 113+2
- camaro and TA interior
- Nitto DRs and GTO wheels
- LS1 fans for sale
- LT1 style T56 midplate
- WTT LS2 for L92
- Center console (older model ss)
- '95 T56 input shaft for LT1
- FS: Brand New...Never Used LS2 intake manifold and DBW TB
- Built T56
- WasteGate
- Fs qtp lt 1 3/4
- HOOKER HEADERS 351 swap with ls flanges for foxbody
- 04-06 GTO ARH Stepped 1 3/4 to 1 7/8 Headers Excellent Condition
- 2000 Camaro parts
- Hurst shifter for T-56
- FS: Firehawk ROH Rims + 2 Center Caps
- LS3 Injectors
- UMI 2 pt. SFC'S still in box
- stock ls3 cam and other parts
