View Full Version : Parts Classifieds
- SOLD LS1 Longblock (Out of 02 TA with 66k Miles has LS6 Casting Block)
- 85 mm mass air, 7.4 pushrods
- ls1 valves
- '96 TA Part Out
- New F.I. Forged LS3 Longblock
- Precision 7675 CEA Billet wheel turbo **CHEAP**
- Ls parts
- 02 long block 27k miles
- Brand new momo seats/harness/mounts
- 275/40/17 MT DR with wheels
- Nitrous outlet setup ,dynatech headers,ls6 heads for trade for turbo
- Lt1 stage ii heads cam intake
- 05+ LQ4 Pistons/Rods
- Milled 317s with 1518 springs
- ls1 complete motor and rear drag set up
- Misc LS1, GTO, F body parts
- Mgw shifter for Fbody
- Camaro Sunoco Style 3" Cowl Hood 98-02 + Sunoco Stripe Kit
- Fs jbl ms-8
- TA Performance stud girdle/ 10 bolt
- LS1 oil cap
- wtt big cam ls1for a smaller ls1 cam
- 93-02 F Body Stock Front Upper Control Arms
- WTS-GM LS1 5.3L 327, 385hp & 372tq
- ram air hood
- Moser 12 Bolt FS
- Built 4l80e FMVB and a transbrake zero miles
- two 85mm slp mafs
- F/s boost gauge
- Stock 00 z28 exhaust
- Painted LS6 Intake, 90MM TB, and Quick 9" rear
- REDUCED Parting out 03 LS6 from Z06 Vette with 50k
- 350z LS2 swap kit. 2850shipped
- LS1 Intake & Fuel Rails
- 3rd gen parts, ls1 ported tb and injectors.
- hooker longtubes race mufflers and turndowns
- LT1 parts!!!!
- Siemens 60lb injectors
- Nitrous Outlet intake elbow
- Sold
- F/S: SLP bellows and LS1 MAF
- FS-4L80E and TH400, also other parts
- PICS ADDED 98 M6 pcm, ls1 M6 fbody pedals, NEW BMR drive line loop
- kooks headers stainless
- WS6 ram air base/box
- (SOLD) LS7 lifters and LS2 lifter trays
- 02 chrome z06 wheels
- Brand New YSI Head Unit
- Brand new GT4082 Twin Turbos
- GTO parts: B&M shifter, pistons and rods, misc.
- heads*springs*valves*covers
- built trans engine turbo kit
- stock 5.3 lm7 spring
- kooks 1 7/8 LT and 3 inch x pipe/Michelin ps2 315 30 18
- Fast Fuel Rails LSXR (Pics Added)
- *SOLD* UMI Torque Arm Kit 2203
- $100 shipped Powerbond 25% underdrive pulley 98-04 Corvette
- Bosch Blue 39# injectors p/n 0280156127 with adapters
- Yank 3000
- Ati TH400 w/ trans brake
- LQ4 intake manifold
- Efi regulator 13101 boost reference
- C5 Corvette Brake Calipers
- lq4 with 799 heads
- Chiseled fuel cell 10 Gallon
- 4th gen f body water pump
- O2 sims fast toys
- 99 ws6 wheels
- 2000-02 WS6 Speedline wheels&tires
- Brand New 9" Rear 78-87 GM G body - Malibu, Regal, Cutlass, El Camino, Monte Carlo
- 98-02 part out left overs lots of misc stuff
- **Brand New** 10.5 Inch Billet Torque Converter: 3600 Stall (Race Built)
- a few stock parts 2000 ls1
- LT1 New valve springs and heads matched for carbed intake
- Sold!
- SOLD!! 232/234 .595/.598 Comp Cam Kit
- turbo, intercooler, gears, main cap girdle for sale
- FS: T6 Single turbo setup + Borg Warner S475 turbo
- trans coolers
- Jeg Sport Star front runners FS
- 08 5.3L coil packs and brackets
- Two 24" o2 extensions for long tube headers BNIb $45 Shipped
- Katech Gen 3/4 Rod Bolts BNIB
- Torquer V2 Cam and Pre 04 ARP Head Bolts
- LS1/LS2/LS6 Parts, 3600 Converter, LS6 short block
- FS:custom 102 Throttle body w/ nitrous jets machined
- Some FBody Parts LQ4/LQ9 Parts. Window Motor, ECUs, Wiring Harnesses, LQ9 Intake etc
- FAST 90mm Throttlebody CHEAP!!!!!!
- WTT Fast 90 intake and rails for Fast 102 with rails
- FS: 93 Harness/Computer
- Fast xim coil-on-plug LS coil driver box & harness for ls
- JCS Turbo Fab single turbo setup for lsx swap fox
- MSD 7531 and HVC II 8261 Coil
- 5.3 truck coils with brackets
- MSD Ignition 6010 - MSD Ignition Controller for GM EFI/Carbureted LS Engines
- round tube K-member singal adj struts manual rack & a-arms
- lingenfelter ls6 cam GT2-7
- FS: Built 408 LS2 Callies, Dart Pro 1's, built for boost $6350 dropped again
- FS: LSX Parts
- ARP hex studs pre 2004
- lsx parts cheap:Livernois ported heads and wiseco pistons etc.
- BRAND NEW 2" primary header w/ 3.5" collector, LS7 in an F-body
- NITROUS stuff for sale
- Auto to manual shift knob adapter
- zex wet kit
- wtt hsw bottle opener
- MORE: 12/05/12 98 v6 camaro part out "PICS R N"
- GI: fresh ls1-383 forged shortblock
- LS1 FTW Lanyard - keychain
- GMPP LSX block-Brand new in box
- Truck oil pan, stock lifters, ported MAF ends, Water Pump F/S
- FS: Built LS7 complete Fast 102mm intake to wet sump oiling. 24x ready for your Fbody
- Spec Twin Disc P-trim Clutch - needs rebuild
- **Sold** NIB Harland Sharp LS Rockers ** Sold**
- 317 heads
- 2 24" o2 extensions Brand New in Box $45 Shipped
- race star rims and tires
- HP Tuners MPVI Standard Suite
- 444" Ls7 w/ Dailey Dry sump system
- LS1 Block,Crank,Heads,Headers CHEAP!!!
- LS6 intake and (2) TB's
- (4) Powerstop drilled/slotted rotors, HAWK pads for 1993-97 Camaro/Firebird
- Ford 8.8 4.10 gears
- QA1 coilovers for S10/ G body
- Weld Drag Lite Skinnies, Front Only
- Misc. F body parts, 6spd console, trans pan
- pacesetter ory pipe. $80 shipped.
- Safety Loop, Oil Pan, Stock LT1 Parts
- UMI HVAC delete plate (brand new)
- 5.3 shortblock part out!
- Fresh 06 6.0 (heads cam fbody acc)
- **New BMR Subframe connectors, panhard bar, torque arm, 1 control arm, and springs**
- Parting 01 WS6
- TNT 10lb nitrous bottle w/pressure gauge
- Tons of 4.8 and 5.3 parts inside!!
- 700RWHP+ fuel pump setup: 2x Walbro in-line fuel pumps, filters, AN fittings
- Spohn Tubular LSx Solid Motor Mounts - 1998-2002 GM F-Body
- WTT/sell cam 224/230 .581 .592 LSA 114
- Fender, Taillight Panel, Zr1s
- Powder coated MAF
- LS1 valley cover, Rocker Arm Pedestals, Lifter Cups; 4"-3" Exhaust Merge; Tensioner
- Everything is sold....
- Gauge cluster,idler pulley, Rod ends
- C5 engine mount pedestals
- Sold
- LSX parts ls1 intake, fuel rails.862 heads and more!!
- LS6 Valve Springs- Brand New
- f/s wilson elbow/throttle body
- f/s twin 4.5 intercoolers fbody
- LS1 383 Stroker Engine w/ Forged Rotating Assembly $2500
- Accel 40lb injectors. part # 01D114B.
- Left over parts sale!! Interior Suspension parts and more
- Brand new SJM line lock/abs delete kit
- like new ls1, 5.3 rocker arms
- 5.3 coil packs 5.3 valve covers
- 85MM Typhoon Intake, TB, Fuel Rails
- Ls parts
- SLP Jounce Bumpstop Spacers
- CTS-V LS2 6.0 Oil Pan
- 98 Camaro Part out - Ebony leather & Grey cloth - SLP
- 2008 l92 cadillac intake, water pump, oil pan and oil pump
- Abbott Cable X FS - Brand new
- SLP lid, base, air duct... etc... SOLD!!
- F/S - Lots of stock misc LS parts
- Slp totl
- hurst aftermarket short throw shifter
- LS6 intake and ported TB, powder coated white
- FS: 19/20 CCW T10 wheels w/ NItto Invos & TPMS Sensors for C6 Z06/ZR1/Widebody
- 2010 6.o liter chevy ly6
- Spoolin performance Fbody t6 turbo kit Fender exit- hot side only
- set of 4 Torque Thrust II 315s
- Fly cutters by lindy tools
- FS: LS6 intake, TB, LS6 heads, Etc.....
- 4th Gen Camaro Wheels
- LS2 Fuel Rail
- Ls1 fuel rail-SOLD. Also have truck intake pm if interested
- ATI LS1 Super Damper and ATI crank pin kit.....
- C5R Valve Covers
- Dual valve springs and LS1 upgraded rockers
- Snow meth kit #20010
- 2001 Camaro Cluster and PSI harness
- Rims 18 inch black
- Mass air slp 85mm , one month old, granitelli 85 mm mass air
- f body turbo kit retains a/c and all stock accessories location.
- ls6 intake, 243's and 226/234 cam
- Crane LS3/L92 Pro Series 1.8 Arms
- Few Turbonetics Turbos (TC78's, TC72's)
- qtp 2.5" electric cut out
- Holley/Delphi 50lb EV1 Fuel Injectors LS1 $250 shipped
- ls1, lq4 stock parts in good shape multiple parts
- wtt EFI Live V2 for Fast 90 - 90mm TB
- ls1 F body, ly6 exhaust manifolds flexplate front rear covers valve covers
- 160lb Bosch Injectors Low imp, RC 80lb
- F1 cogged procharger pulleys
- ls1 headers, y pipe
- Ls1 block
- F/s 30lb injectors red tops
- FS:Updated List*CTS-V LS6 Parts,Exhaust,wideband,Corsa,Gasket,Cam,Oil Pump,Kooks
- Aluminium intake manifold with 250 shot "direct port" injection
- th350 Circle D 3600 need gone asap SOLD SOLD SOLD SOLD
- 1600cc low impedance injectors new
- 1998 Ls1 motor
- built 427 plus performance parts
- LS f-body power steering rack and linkage
- Lt1/5.0/Misc. Cleanout! Trickflow, Hooker, B&M, BBK, OEM
- Wilwood 4 wheel discs + e brake + accessories! Early Mustang, etc
- Stock 02 f body manifolds, cats, n y pipe
- VFN 98-02 5inch Ram Air WS6 lift off hood. Scoop and hood Extended to Windshield
- 85mm BBK ssi intake- sold
- billet specailties street lites
- Random parts of 02 TA and SS
- Fast 4150 Throttle body (10 passes on it)
- 2000 T-56 trans 40k Complete 1,6000 shipped!
- LCA Relocation brackets
- 6LE brake brackets and stainless lines
- 5.3 Short blocks, 317 heads, Truck Manifolds
- DEMODDING SALE 4L80E Stall, Accessory brackets, 2nd gen swap headers
- For Sale: 1998-2002 LS1/LS6 Spark plug wires
- Ls header flanges
- 408 Stroker
- Ported 90 mm fbw throttle body (silver blade)
- Parting out 09 CTSV...
- Whipple Supercharger, GT45
- WTB: HP Tuners Pro and Wide Band sensor
- 2000 c5 wheels and 3 tires. $400
- Stainless Fbody Headers $350
- SLP CAI for fbody. ls1 or lt1
- LS1 spark plug wires NEW OmniSpark $35
- lq9 408ci stroker engine low miles cnc ls3 heads
- 2 5.3 Short blocks and 317 heads
- Holley LS7 Hi-Ram & NW 102MM TB
- UMI LCA $80 shipped
- 2011 Camaro LS3 stock clutch,flywheel,cam,injectors,intake,fuel rails
- SOLD SOLD nice auto ebony console insert and knob
- L92 for sale $3000
- stock rack an pinion
- speed inc alt kit
- FS: Rt headlight cover L headlight bezel trans am firebird
- FS: Trans am firebird right side mirror white
- FS: rear hatch speakers
- 98-02 camaro 6-speed center console complete
- FS: taillight wing nuts
- FS: HVAC controller camaro firebird
- FS: headlight switch lot (4)
- FS: dash switch fog light ASR trunk release
- FS: 3" aluminum factory driveshaft
- KOOKS 1 7/8 Headers, SDCE SPAL Fans, Comp tensioner
- FS: convertible seat belt guides rear drk gray
- FS: ebony interior window switch lock pass side
- FS: FS: triangle trim interior mirror cover 2 sets
