View Full Version : Parts Classifieds
- parting out a 94 green grey metalic z28
- LS2 and LS3/L92 parts
- 1998 trans am fs/ft,turbo set up,heads,cam,etc,402 motor
- 2007 LY6 ac bracket
- ls6 engine
- NX NXL Nozzle kit
- Wolfe 6pt bolt in roll bar
- EWP wiring harness, aftermarket maf, steel braided fuel lines
- Truck coils w/brackets & harness + PCM
- FS: CCW Drag Pack
- Pac Auxiliary Audio Input Interface
- tan 2001 trans am seats
- LT1 Ported Intake & Trickflow Throttle Body
- 15x10 Weld Draglites
- hinson motor mounts
- Stock F body motor mounts
- FS: black left side camaro mirror
- Faceplated t-56 1900.00
- TCI Streetfighter TH350 for sale with stall
- TH350 for sale
- LS1 F-body AC bracket & pulleys
- FS NEW ECU/PCM, FTRA, STB, Slave/Throwout, wiring harness, shift knob
- victor jr ls1 and accufab gotta go
- 3:23 10-bolt, heads, Kenwood KDC-BT948HD, Monsoon
- Door handle trim
- Bigstuff 3
- WTT/WTS Eagle 383 rotating assembly
- Gto diablo programmer
- diablosport trinity tuner
- Parting out 98 Camaro Tan Leather Interior
- convertible sub box for 4 8"s
- 2- Nitto NT555 285/40/17
- FS: ls2 stock heads, intake, injectors, cam, etc
- ZO6 Rims / Wheels Gun Metal
- FS: Jesel Rockers L92, .800 lift springs, morel solid roller lifters
- AMS 1000 boost controller
- F/s: Fidanza ls2 aluminum flywheel gm ls7 clutch and pressure plate
- Billet 4150 Throttle Body
- Vic Jr and Aeromotive fuel rail
- 10 bolt housing, torque arm, rotors, spark plug heat shields, open to offers
- PRICE REDUCED AGIAN 10lb.texas nitrous technolgy nitrous bottle
- 5.3 longblock part out
- Lots of Nitrous Outlet Parts/ kit
- Stock 2000 Camaro SS wheels-PAIR
- 00 trans am A pillar ebony panels $35 shipped
- Pedders XA Series Coilovers *GTO*
- Camaro Ground Effects
- FAST 4150 Throttle Body & Dry Plate Kit
- Mtx Thunderform, Alpine Type R 10"
- Precision Turbo 88mm .96 t4
- s10 turbo kit
- ls2 tb, ati super damper (vette), powerbond ud pulley (vette)
- Dual gauge pillar for 97 - 02 Fbody T-Top
- 7955 Comp Pushrods 7.40
- Zex nitrous kit, nearly new. Sale or trade
- FS: Magnaflow Tips
- Walboro 255 and LS1 camaro taillights for sale.
- MSD optispark, blaster coil, aeromotive LT1 fuel press regulator
- CNC'd L92 Top end setup.
- WTT: RPM Built 4L60E + Yank TBSS3600 stall + Trans Cooler for T-56 Swap
- Parting Out a 95 Firehawk
- Camaro tail lights, marker and park lamps,T56 shifter & misc parts
- Fast 90 Intake
- 98-02 Camaro Brakes Front and Rear
- LS1 OE LUK Clutch kit
- FS: SLP Headers(new jet hot coating) & Catted/Off Road Y Pipe
- SLP Blackwing Air Lid with boot and clamp *RARE*
- Hypertech Power Programmer III #30025 1999- 2004 F-body / Corvette LS1 & LS6
- Painted GTO Fuel Rail Covers + Lighted 06 GTO Steering Wheel Controls
- Manley Exhaust Valves NEW
- Areomotive fuel pressure regulatorSOLD!!!!
- Pat G Comp Custom Spec Cam
- FS - DBW pedal, truck mounts
- Ported/Milled Perimeter Bolt castings: NEW
- FS - LS1 a/c compressor
- FS - C6 K&N intake assembly
- WTB: Ls1 camaro/trans am Oil Pan asap
- 93-02 camaro/trans am sail panel
- SOLD -Holley LS Swap Oil Pan *BNIB*
- Procharger p1-sc
- Firebird/Forumal/Trans Am Driver Side Air Bag
- Gto spoiler/5.3L truck parts
- LS1, LS2 and LT1 TA Interior
- BMR LCA relocation brackets for sale$$$$
- McGard m12x1.5 lugnuts and locks chrome
- Current Performance swap fuseblock, GTO PCM, misc LQ4 parts
- LS6 Intake
- WTT: 2000 SS for Fox Body
- Fuel rail covers for sale on Ebay
- Pacesetter 3" Off Road Y Pipe
- Motron 60# Injectors $285 Shipped
- 17x8 platinum widow wheels
- Moser 12-bolt, 3.42's & suspension package
- bbk ssi intake/ 80mm throttle body
- ls1 k-member and steering rack
- FS: STOCK STUFF (clutch, head bolts,
- FS - Mock up parts
- Brand new kooks 1 7/8" race headers
- 90mm FAST LSX Intake
- LS1 .051 MLS headgaskets
- Ls1 longblock, nitrous kit, 926 comp can spring kit, 7.425 push rods
- Pacesetter LT's (never used), Stock LS1 pistons & rods, truck manifolds, and more
- k@ n fip kit for sale
- Wolfe 6 point bolt in roll bar
- 01 WS6 Wheels
- 6 gauge set - SCx redline
- comp cams 7.4 pushrods
- MSD 8969 Digital Window Switch
- N2MB Wot Box
- diablosport predator tuner
- Brand new in box Fast 102 intake
- Nitrous outlet 102mm plate and hardline set
- tci super street fighter torque converter ls1 3500-3800
- Nitrous Works Wet Kit
- LS Engine Swap Pan
- AJE mu-7050 Trans crossmember
- Slp lid
- mustang swap headers
- FS or trade: LS2 intake manifold and 92MM Cable TB
- 17" black c5 Z06 replicas
- gauging intrest on my exhaust set up
- (4) 245/50/16 Eagle GS-D3 on Snowflakes - SOLD
- NItrous Outlet Digital Progressive Controller
- Nitrous Outlet LS1 78mm EFI Dual Stage Plate
- 1998 ls1/t56 harness w/pcm
- Turbo Electronics
- Brand new nitrous 90mm plate kit
- Corvette vigilante converter
- LS6 Intake Manifold setup
- NOS Bottle Heater
- Pat G Cam
- SOLD: Complete 243 Heads
- New Nick Williams 102mm DBW TB NEW
- Madman Racing LSX universal motor plate set/steel mid plate (new) $250 shipped
- stock 241's w/ trick flow springs $100
- AFR LS1 230cc fully CNC ported, 65cc chambers, Small Bore, complete w/parts
- Street Slayer Single disc 6 puck clutch like new
- LT4 heads, intake, and 1.6 rockers
- Moser 12 bolt, built 4l60e, SLP hdrs, 48lb inj., FTI tc
- BNIB - LS2 MSD coil wires.
- FS: New PT7675CEA Turbo,Intercooler,42lb Green Top Injectors,10 Bolt w/ 3.42
- HSW Plate kit with accessories, Stock wheels
- Parting a built 2002 camaro
- Fs: Nw 102mm tb
- Comp 224 cam
- 00' trans am part out. 7 days only
- 60lbs injectors,arp main studs, chicago
- Race Star, Dark Star 17x4.5 Brand New, Cheap
- LS1/6 fuel rails with -10 fittings
- BNIB: SLP Performance PowerFlo Exhaust System
- brand new 93-02 fbody moser12bolt
- Comp 55-444-11 Cam-
- 2001 black slp Camaro ss part out
- Spicer u-joint for stock fbody driveshaft
- 42# Injectors and LS6 Fuel Rail
- spec stage 1 and crane quick lift rockers
- 2 eagle 4.000"crankshafts F/S
- Foxbody swap parts-AJE,Dynatech,etc.
- Arp head bolts pre 04 ls1/ls6 SOLD
- Cameron billet converter 3600-3800 4l60e
- CTS-V LS6 oil pan & pickup
- 42LB Ford Racing SOLD!
- Cammed ls1 motor
- Siemens Deka 80lb/h Injectors
- Brand new ported DART PRO 1's
- Nitrous Camshaft BTR
- FS- HSW Interface & Microedge Plus Controllers
- 95lb/hr Fuel injectors + Driver Box
- LS1 Cam LS1 Water Pump LS1 Dual Electric Fan *PICS ADDED*
- Vigilante 2800 stall
- MSD Blaster HVC-II Coil (LS1 Distributor Guys)
- Tsp 3" ory
- brand new ls1 racetronix hotwire kit 99-02 plastic tank
- 4.8/5.3 block crank rods pistons ls rockers and more
- Trick Flow 7.500 pushrods $60 shipped
- Price dropped! Fs ported 806s,coils,lifters, & lq9 stuff
- Fs: Chrome camaro ss 10 spoke wheels (il)
- Camaro halo headlights, 02 camaro muffler
- ETP 215'S FAST102 tb,Fbody balancer
- Vortech v1 t-trim
- Holley dis waste fire coils w/ls plug and play for holley
- stock z28 spoiler black
- 05-06 GTO Volant CAI
- ls1 longblock, heads, long tubes and more
- 10 bolt rear end Ls1 solddddd
- Spicer Yoke *SOLD*
- FS (Chicago) : 19" CCW 505A w/ like new Michelin Pilot Sport tires
- 12 valve part out 98 3500 DRW cummins
- Fs: Turbo Kit, Turbo Accessories, LSx pans, misc. LSx parts
- Edelbrock Eforce E-force Supercharger Kit 2010+ Camaro
- KOOKS Mufflers!!
- Truck coils, autometers, truck manifolds ect.
- Stock, Performance, and Nitrous Parts
- Aftermarket wheels and tires (cheap!) FS...
- MagnaFuel 525 Fuel pump, filters, regulator, and Y
- comp cams 918 valve springs $80
- 98-02 camaro black billet grille with bowtie
- F/S C5 Black Z06 Seats
- Spohn Solid LSx Motor Mounts
- price reduced current performance wireing harness for s-10
- FS: LS2 (1?) front cover gasket, front main seal, and crank bolt
- 26x11.15x17 mt streets w/rims
- Trickflow 225's, Fast 102, Injectors, throttle body, etc...
- WTT: 35th Anniversary SLP grill for black SLP grill with silver ss emblems
- LS2 intake manifold bare ($175)
- 01-02 WS6 Speedline wheels. Will sell seperately or together Missouri
- LQ9 intake, fuel rails, injector, and throttle body spacer
- LS1 and GTO parts *update*
- Slotted brake rotors and BW clutch fork f/s
- $10 sale
- Gto (ls2) fuel rail
- Aeromotive A-750 Fuel Pump and Fuel Filter
- New Vortech V-7 YSI
- Daytona Sensors Wego 3 Wideband/Datalogger
- Nitrous stuff/Wideband Controller for cheap
- NW 102 mm Throttle body
- EFI Live FlashScan V2
- LS1 oilpan, accessories, conversion parts
- For Sale or Trade Billy Boat (B&B) Shorty Headers for a C5 Corvette Great Condition
- Wet nirous kit
- Kooks 1 3/4 headers with Matching Y-Pipe
- built 80e with triple disk vigilante converter
- **1999 Trans Am T-Top Shell...Totally stripped**
- WTS/WTT- LT1 w/ LTCC and ups and t56 ready to drop in 330rwhp
- Kooks headers 1 7/8
- 8" Cameron converter glide/th350/th400
- Yell Terra Rockers
- fresh powdercoated zr1 black wheels
- comp cam, greg welds(race stars), tires
- New Nick Williams 92mm cable throttle body
- 93-94 msd opti spark
- LT1 Meziere standard pump, water pump housing, 160 stat, temp sensor
- CANTON Trans/ Diff overflow catch tank
- ls2 valley cover
- LQ9 LQ4 Intake Manifold
- Fs 2" kooks headers
- WTT Large Tial blue wastegate spring for small yellow/red
- 58 piece air tool set,like new
- Hoosier 335-17 (NEW) Mounted on (NEW) 17x11 ZR1's
- wtb 02+ ls6 cam
- ls1 intake,heads,cam,valcovers
- FS: Tick Stage 2 Built ZO6 T56 and OEM C5 ZO6 Seats
- FS:3.42 Diff, Torque Tube, ZO6 Brakes and MORE C5 PARTS
- 2007 LY6 6.0 water pump
- G.I wtt my t56 for th350
- 1998 z28 steel fuel tank and 255 walbro pump
- vvt camshaft & 4 lump gear (stock)
- Slp lid
- 01-02 SLP MAF Brand New!
