View Full Version : Parts Classifieds
- Tahoe/Yukon Running Boards
- Tow Package/Reciever For 1/2 Ton Chevy GMC
- 5.3 Vortec Intake Manifold Cover
- BMR strut tower brace (Red)
- ZR1's 19x12 18x9.5
- Lower control arm Relocation Brackets
- FS: brand new fast big mouth 92mm tb
- CTS-V Calipers for sale! Upgrade for F-bodies!!!
- HKE 370 shortblock built for RPM/SPRAY
- AFR 215 V2 Heads
- looking to trade full ls1efi set up for ls1 carb set up
- Nitrous Express Direct port system $450 shipped
- Hurst billet shifter and stock C5 shifter knob
- Moroso spiral flow 3" diam. bullet muffler
- lq4, 400 trans, ls6 intake
- ls1 block with some stock internal parts
- Spohn K-member, LT1 P/S, + More
- 4.8/4l60e 4wd version 100k + miles with wiring / comp ( WILL PART OUT )
- 4.5 BS Weld prostars 15x10, t56 t/a bracket, clutch master/slave and braided line
- ( SOLD )dirty dingo ls water pump spacer / vent hose kit brand new
- dirty dingo ls series idler pulley relocation bracket with belt
- 93-97 T/a fenders
- Brand New Garrett GT42! Big turbo! Price drop!
- Neal TH400 trans & PTC ProMod Converter (TH400/LSx)
- Diablo Sport Handheld Tuner Forsale (LS1 Fbody)
- TH400 bellhousing and trans shields
- 2 Michelin Pilot Sport Tires Brand New
- GTO Pacesetter Coated LT's w/ 05/06 Mids
- FS: 42lb green top injectors (SOLD)
- Ported Throttle Body and MAF Ends with Sensor
- late GM car drag pack
- 2001 t56
- SOLD @@ LS1 5.7L Engine Computer PCM ECM 12200411
- 98 LS1 intake SOLD!
- 95mm REV XTREME BILLET LS1/LS6 DBW TB 280$ SHIPPED NEW
- Racetronics 42lb Injectors NEW
- EPP Driveshaft
- FS random parts
- Lt1 parts
- Windshield wiper motor and linkages '98-'02 Pontiac Firebird
- Fuddle LS1 3200 Stall Converter, fresh.
- 2002 SS - SLP Wrecked 43,000 miles Part Out
- 98-02 Pewter Trans Am door emblem NEW!
- forged 370 for sale
- FS- Factory PS cooler, Control arms, and Panhard bar *8/22 PRICES REDUCED!*
- NIB: QA1 Coilover kit: $500 Shipped.
- BACK UP FOR SALE.... Lca & relocation brackets 2 sets
- 90mm 4 bolt DBW TB
- K&N Filter for LS1 F body
- F body demod GI. FM5's, ARH, Baer, Fast 102
- valve covers,msd wires,coil packs,spintechs,ram master,accufab,much more
- K-Member and misc.
- B&M Ripper Shifter
- FS: New STS twin turbo for corvette
- Black Z06 wheels WTT/WTS
- Seat harness + Wolfe racecraft
- MS3 camshaft, Melling Oil pump
- Yella Terra 1.7 rockers 250 shipped! *SOLD*
- LTx GO FAST PARTS> A1000 fuel system. N2O, Rocker Arms, EWP, Header Bolts, Opit etc
- Used Delphi 85mm MAF
- LS6 Intake Manifold complete low mileage assembly
- 15x10 Drag Wheels with 28x11.5w Drag ET's
- 97-04 corvette p/s reservoir and mount bracket
- 97-04 Corvette harmonic balancer LS1/LS6
- 1999 corvette mass air sensor
- 1999 corvette DBW throttle body
- GM corvette P/S pump with new pulley
- Gm 97-04 Corvette Alternator P/s Pump Bracket
- Gm drivebelt tensioner ls1/ls6 new
- brand new 2010 bmr tunnel brace
- 2010 stock half shaft
- 28lb ls1 injectors
- procharger j bracket,fmic,slp lid, zr1s,qa1 springs, rear slp blisteins
- stock 04 gto driveshaft
- FS: LS1 Head stud ARP/ Mahle powerpack 3.905
- Diablosport Tuner and NOS nitrous plate
- F/S or trade- New Ebony 98-02 WS6 Seat Cover with lunbar
- C6 Twin Turbo Kit *FOR SALE* - Completely custom!!!
- Fs ls2 intake manifold
- Ls1 ARP head studs
- Strange DA Rear Shocks & NIB 4500 Nano Kit
- F/S Polished Strut Tower Brace, halo Ring,Ashtray lids Ebony
- NEW RHS tall-deck LS race block 4.120 bore -- limited time discount
- LS starter
- ACPT Carbon Fiber Driveshaft Great Shape
- Lq9 Rods and pistons with arp rod bolts
- LS2/LS3 intake, LS3 Cam, Yellow springs
- 2004 gto parts stock
- 78 mm tnt power ring
- Monster Stage 3 clutch NIB
- stock ls1 timing chain & sprocket
- 98-2002 LS1 Casper Vplus Fuel Pump Booster
- stock ls1 valve springs
- YANK 3600ss and MWC torque arm
- stock valves off of 02 camaro ls1
- F-body oil pan kit for trade/sale - need H3 kit
- LS6 Blue Valve Springs New
- I need an ls2 water pump
- Detroit Locker 31 Spline Ford 9 inch
- AFCO rear double adj shocks and MWC driveshaft loop
- Black ZR1 wheels with tires
- 4l80 w/almost complete conversion
- New Falken Azenis 18's
- Modded ls1 harnes n computer
- 2010-11 Camaro JBA catless midpipes
- F-body Shearer fabrications custom high horspower intercooler and custom piping new
- Borla Tips
- UMI TH-400 transmission cross member with torque arm relocation
- Brand new American racing headers
- racing TH350 swap, all star, stainless braided, intercooler, manifolds, etc...
- Wildwood pinto rack 98-02 Camaro/Firebird
- Driver side door 98-02 WS6
- l92/Ls3 edelbrock victor Jr "carb""
- Ported Stage 2.5 5.3L Heads - 862 Casting
- FS: LS3 Valve Springs
- FS: Holley EFI fuel pump w/ Holley filters and fittings
- FJO 2 Stage Progressive Controller and PLX Wide Band and Gauge and Data Logger Cable
- 3rd gen Camaro hood & door. 4th gen PCM, Hvac control
- PRC 215cc CNC Ported LS Cylinder Heads
- Fs. Brand new Moran racing injectors 500lb / hr set of 8
- Comp Cam LS1/LS6 (#54-444-11) lift @0.050 224 int./230 exh., lift .581/.588
- stock LS1 parts: heads lifters cam plate rods pistons covers rockers mains
- Parts added QA-1 fr/rr UMI SUSP!!!
- FAST 102mm Cathedral Port Intake For Sale
- sold
- Updated LS6 Intake, Clutch,SLP Long Tubes, SS berger Panel,
- Aeromotive A1000
- local pickup only pearland,tx
- LT1 Meziere Electric Water Pump, MSD Optispark, and SLP headers
- L99/L92 heads and Patriot 8401 spring kit
- D585 Truck Coils - high output
- Nitrous outlet 92mm Nitrous plate for LSX
- DBC Truck wiring harness, out of a 2500 silverado
- E85 Injectors
- (Brand New) LS2 Alum. Block $925
- (New in Box)Oliver Connecting Rods (6.125)
- super cheap JBA catted mids , valve cover spacers
- SOLD! BMR Lower Controlling Arms
- 27k Mile Stock Shocks/Springs/Panhard
- NEW GODSPEED 50mm BOV
- PRC 650 springs, pushrods, TS19 cam CTSV
- Semi complete Ebony leather interior 01 WS6
- LS Parts for sale
- MPT70 70mm Turbo .68 a/r
- 93-02 Camaro RKSport Spoiler FS/FT
- **Stainless works catback with cutout**
- BFG 275 Drag Radials
- NEW SLP LMII, OEM Lid, & Emblems (big pics)
- comp cams pushrods 7.350 length F/S ; stock rockers F/S
- SLP Loudmouth I Resonator... practically new
- FS NOS Billet 10lb Bottle Brackets
- OEM GM/SLP Chrome SS Wheels With OE Goodyear Eagle F1 WTT Welds, Racestars, Billets
- For sale The Tuning School tuning guide
- ls valve covers, 98 pcm CHEAP
- Edit! All prices Obo! Ls6 cam M12 t56 and 04 gto part out
- !!WTB!! aftermarket engine management, 3 bar MAP...
- NIB ACL +10 Rod "H" race bearings $80 shipped
- 98-02 Camaro fog lights
- Strange S60, torque arm, ta relo, drag sway bar.
- Cleaning garage stock & aftermarket parts CHEAP!
- Stock shifter, stock CD player, Stock Intake w/ K&N Filter
- 1999 WS6 Exhaust COMPLETE
- 12 bolt 3 series 430 gears
- Efi live v1.2 scan only, upgradeable! 0411 PCM also.
- A4 swap parts *(Trans cooler, A4 console, Pedals, etc)*
- 94z28 lot of goods
- Spec 3 + modified with aluminum pressure plate
- (4) Stainless Steel 3" Lap Joint Exhaust Band Clamps
- OEM LS7 Manifolds For Sale $120 Shipped
- 1998 F Body PCM
- Chrome Replica Z06 Wheels with Nexus N3000 Tires
- Ls1/ls2 parts/accessories/ intake/heads
- 7.400" Hardened Pushrods
- 2004 GTO Factory Catback Exhaust
- Stock T56 out of a 99 TA
- GTO Factory Driveshaft
- Stock G8 GT mufflers F/S
- LS6 Intake off 2004 GTO
- meziere water pump / jesel rockers
- FS: Factory Hurst shifter
- Brand new ls1 oil pan and pickup tube
- Iron block/turbo/6.o heads
- patriot .650 dual valve spring kit. 160 shipped
- *A/C Parts* Compressor, Condenser, Dryer, Lines, and HVAC Controls
- 98-02 slp driveshaft loop
- Professional Products 85mm TB
- McLeod Racing Master Cylinder, Torque Arm, **CHEAP**
- Hendrix Engineering Steet Slayer Clutch / PP and Spec Steel Flywheel - LS1 Style
- 98-02 camaro headlight covers
- 7/2 MORE seatbelt guides, tips, emblems, other stuff
- LS parts - ARP cam retainer bolts, ls6 coolant plugs, trans bellhousing cover
- Tick Adjustabe Master and GM Slave
- Flow Chargers, BAP, Kenne Belle Boost A Pump
- 12 Bolt 1968 Camaro Posi 4:10
- NEW: (2) American Racing 17x11 Salt Flat Wheels
- 1998 Corvette: Rolling Chassis Complete
- ls style vic jr and other parts
- Cleaning out the garage pt.2
- L99/L92 heads and Patriot spring kit
- Cleaning out the garage pt.1
- ASP LT1 underdrive pulleys & belt
- 2010 Camaro LS3 intake for sale
- Fs cam kit
- FS/FT: Corbeau A4's w/F-body rails
- american racing long tubes
- ls6 intake & t/b and few other parts
- LS6 Steam Crossover & Blockoffs
- YANK PT 3500 converter
- OEM LS1 Starter with bolts & heat shield
- MBA Ws6 Center caps and Shift Knob
- WTB: 99-01 harness and pcm! paypal ready
- SOLD SOLD 36/42 lb. Bosch Fuel Injectors $175.00
- SOLD SOLD NEW Caspers Hot Wire Fuel Pump Harness for '99-'02 Camaro/Firebird
- Stock 10 Bolt 4gen
- Manley Pro Series 4.125 piston
- Superchips Cortex 2950
- Brand New FAST 92mm ported intake
- FOR SALE - Whiplash Cam, original version
- Katech/IWIS LSx Timing Chain
- Comp Cams LS1/2 Rocker Arm Trunion upgrade
- Texas Speed Cam and Head Package for Sale
- LS3 Conversion Harness PSI
- FS 98-02 GM Camaro SS spoiler
- garage sale lsx/fox/race car
- FS: McLeod Original Street Twin clutch, new in box
- FS: AC DELCO rotors and pads for Corvette C5, Z06, etc.
- FS racetronix 42# injectors (EV1) $250 shipped
- Vogtland 1.2 lowering springs
- ls1/ls2 parts
- Yella Terra rockers, Fast fuel rails, Richmond 4:10's, 3:42 rear end 4 ch
- 10 rib crack pulley and 3.40 pulley
- B&m short shifter
- FS-C5 Intake box
- Sold
- 92 mm fast manifold used $750 shipped
- Sold
- Professional Products ls2 fuel rails
- C5 Z06 calipers
- Sold
- Sold
- Sold
- WTB - Mayhem cam
- Weld Runners and Slicks for Camaro Firebird with Good Tires/Drag ET's
- detroit locker 35 spline with 4.10 richmond gears ford 9"
- Charcoal Trans Am interior plastics
- Victor Jr l92 EFI intake...BRAND NEW
- Nitrous electronics & More!
