View Full Version : Parts Classifieds
- 1998 LS1 Harness and PCM. (manual)
- Polk Audio DB 6750 6 3/4" Components - Fits Trans am, Camaro?
- sold!!!!!!
- LS1 Oil Pan F-Body Camaro - Bargain - Needs Minor Repair- $100 !!!!
- 1998 Trans Am Interior parts!
- 342 Gear and Pinion for for a 7.5 10 bolt.
- LS6 intake setup, Corvette LS1 cam, LS2 cam sensor, rockers, Vortec parts
- Slp dual dual
- Stock 4th gen exhaust
- new flowmaster merge
- 317 (243 clones) & 5.3
- 99-00 LS1 engine block
- 4" Magnaflow tips, 2.5" inlet
- Ls1 Beck Sheetmetal intake (SOLD)
- Cometic 3.910" x .045" gaskets
- FAST 90mm intake manifold
- Chrome SS 10 spokes
- stock "cat back" off 01 z28
- Stock z28 spoiler
- F/S Brand New Diamond 15516 4.000" -13.7cc Dish Piston Set for Boost Sold...
- Take off 799 Heads W/ New .650 PRC Springs!
- Jesel J2K shaft rockers for ETP heads
- ETP 11-degree cylinder heads
- Solid roller 408 for sale, carb'd with distributor
- nitrous outlet 78mm plate/ k&n fipk intake
- 317 heads 81,000 miles
- FS/FT heads and cam ls1 pullout complete and mikes trick shift built th350
- 42# Racetronix injectors
- cometic 3.910 bore .045 thick gaskets
- .600" Bee-hive SDPC springs and stock LS1 pushrods
- FS-C5 Intake box
- c6 stock exhaust parts
- Edelbrock Victor Water pump and pulley (8896 & 8898)
- Koni coilovers price drop
- innovate Lc-1
- 3.55 8rib procharger pulley
- nitrous outlet 78m hardline plate kit .
- BNIB Zex widonw switch
- hypertech power programmer 3
- C5 shifter with threaded handle and z06 shift knob!!
- BRAND NEW 243 heads-SOLD! SOLD! SOLD!
- UMI bolt-in Relocation brackets
- Stock TA rims + tires
- NOS direct port kit(SOLD)
- Eibach Pro-Kit - SOLD!
- LS2 timing chain + FMS ported oil pump
- Misc. stock and aftermarket ls1 parts...
- FS Chrome 16" Z28 five spokes w/tires NO RASH
- Free LT1 parts...
- factory ls3 parts
- Cable-x x30 speedometer box
- Midwest chassis ( MWC ) fab 9 for sale- used
- 05-06 GTO exhaust,SLP loud mouth II catback.
- ***l92 vic jr - elbow - 90mm throttle body***
- 18" Black and Machine finish Wheels GTO
- Eagle forged rotating assembly! 383/408
- 65lb injecters
- Cometic head gasket - 4.030 bore .040 thick
- 4 Chrome Camaro 5 spoke wheels with tires
- FS: Metco fuel rail adapter
- silver 98 ta rims 16 inch
- 2000 Black Ws6 Ls1/M6 Partout
- FS-5.3L Flex Fuel injectors + (pigtails optional)
- FS: 2002 engine harness & pcm
- Art Carr 2004R Torque Converter- Buick Grand National / T-Type
- stock ls1 driveshaft
- LS Oil Pan
- Ls6 Intake !! $350 Shipped !!
- LS Solid Motor mount plates
- Lightly used NOS system Components!
- 241 heads
- Ls1/LT1 Parts
- Spec 3 + modified with aluminum pressure plate
- Cnc ported 799 heads
- Bosch 42lbs injectors
- L92's Brand New Bare Castings Stage 2 Ported & Worked Sold...
- 04-06 GTO Parts, Nitrous, Kooks, Tick, Monster, Spintech, and MORE!
- UMI k member w/o motor mounts
- Harwood WS6 Fiberglass Hood, painted GM Bright Red w/ stripes.
- 2 New Nitto Invo's
- LT1 "643" Casting Heads
- Ls2 intake manifold
- LS7 Clutch $275
- rebuilt lq4 in tn
- Tick Adjustable Master Cylinder and Slave Cylinder
- textralia twin disc <100 miles
- Garage Cleanout: A&A C6 Vortech, LS2 Cam-Springs, QA1 coilovers, AC DELCO Water Pump,
- 1999 throttle body
- 34000 stall forsale and OEM C5Z wheels/tires!
- 1993 -2002 Moser 12 Bolt 33 Spline Posi
- heads and tuner
- 3 gauge pillar
- Underdrive pulley for sale
- fs- ls1 corvette dbw throttle body
- 3 channel F-body rear disk brakes
- ATI ls balancer
- Nos 05169(ls2 90mm plate) Complete kit and Fast 90/90 $1850 shipped!!!!!!
- LS2 injectors
- Katech carbon fiber LS valve covers
- looking for gmmg
- FS: Pair of CHROME OEM 10-spoke SS wheels w MT radials
- Trans am & camaro parts
- FBody A4 shifter and cables
- msd timing twister
- New 4" DMH electronic cutout, New PBR Rear calipers FOR SALE
- FS: Fbody Aluminum and Steel Driveshafts, LS2 LS3 Fuel Rail,
- FS: HPTuners Pro, NGK AFX wideband, Calibrated Success DVD package deal.
- Lots of LSX aftermarket (some stock) parts
- 238-242 114 LSA 605 lift Cam
- PSI LS3 Conversion Harness
- forged 347 carb to oil pan for sale
- GTO Headers SLP midlenght coated with down pipes
- Burkhart chromoly lower and upper a-arms PC black 93-02 f body
- DropZone Springs (rear only)
- LS3 intake, complete, take off, like new
- Nick Williams 102mm TB
- Delteq brain box
- H/C/I LS2 longblock with TFS 225s, FAST 90, YT Ultralites, and more
- Fbody oil pan,pickup tube,windage tray
- ls6 intake painted and ported throttle body-PRICE LOWERED..
- Two PTE 6765 Billet turbos
- t56 for parts/rebuild
- B&M Ripper shifter
- T56 trans and Twin Disk Textralia race+street disk <100miles
- 799s stock take offs, clean can send pics
- lt1 cam for sale
- WS6 Wheels
- T/a doors
- T/a charcoal door panels
- 98-02 Camaro SS center console ebony black OEM
- dark grey leather seats
- 04 GTO Engine Harness + PCM
- Midwest LS1 style 3500 stall converter FS
- Corvette z06 manifolds
- GMMG Stainless Steel Catback Exhaust
- 2001 CAMARO SS FRONT CALIPERS [40k miles]
- Zr1 wheels & tires for sale or trade
- Mcleod Street Twin W/aluminum flywheel...fresh rebuild
- FS 04-05 GTO Rack and Pinion
- SLP "SS" Grille
- LS1 Intake Manifold and other things.
- Set of LQ9 Flat Top Pistons With Rods
- S&B Air Filter With Reverse Cone
- C6 LS2 Exhaust Manifolds
- good stuff for sale here, look and see
- *Feeler* built T56, spec clutch, wilwood master
- Tfs 215!!!
- Need a clutch after Maggie install. LS6 Intake, TB, MAF, Misc parts
- 2000 Camaro TB/Fuel Rail and Injectors and other things
- MTI Lid
- LS1 Lindy Fly Cutting Tools
- Ls Smoothed Valve covers
- fast Toys 98 clear air lid for trade!
- Built top end ls1 (guaging interest)
- W2W built LS T56 Swap stuff
- umi k member w/o motor mounts
- cam for sale 228/222
- Fbody a4 engine harness and computer
- Complete Nitrous Kit w/ tons of extras
- Fast 92mm intake, ported
- Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module
- Near complete L92/LS3 topend swap *lots of pictures*
- PCM, Monsoon Radio
- F/S Callies Compstar Crank 4"
- WTB 3" over the axle single pipe
- Ls6 intake manifold for sale
- Parting out my turbo build
- LS1 F-Body Fire Sale - Nitrous, stock, yada yada
- fresh lq9 in tn
- WTB 99-02 LS1 Fbody wiring harness ANY condition
- Garage Sale! Aftermarket Performance parts and OE Replacement
- Fresh T-56, McLeod Bellhousing, McLeod twin disc clutch, master, etc
- 04-06 GTO parts
- Monster Stage 3 clutch
- 4.8/5.3 motor
- LS1 MAF and Stock Bellow
- Zexel Torsen 3.23-up differential
- FS: Used McLeod Twin Disc Clutch (RST) w/ flywheel
- Yank SS 3600 FS.
- zr1 OEM 17x9.5 chrome rims with nitto tires
- PRC stage 1 LS6 heads, MSD6010, Vic Jr carb intake for LS, Autokraft pan, more
- LQ4 longblock + extras
- Zex Nitrous Stuff
- LM7 Procharger Kit, LS1 generic longtubes
- Burkhart chromoly tubular upper and lower A arms for 93-02 f body PC black brand new
- GTO SLP mid length headers coated and stainless downpipes with HF cats PRICE DROP!!!!
- 2000 Trans am red doors, side skirts black dash and alot more
- Nitto INVO 345/25/20 (2) Like NEW!
- FS NX 10lb (full) bottle with remote opener
- Aeromotive 13301 Regulator/B&M Street Bandit
- Brand New Fast 92 Intake Manifold
- Ls3 Holley high ram intake
- G/I major part out 2005 cammed m6 Gto low miles, mods
- LS1 Intake/TB/Fuel Rail and Injectors
- Meziere, LC1, ARP, Aeromotive, Caspers, 04 ZO6 MAF, o2 sensors, Omega thermistors
- Batwing pan FS
- LS1 go fast parts, DART Pro 1, ARP
- Koni DA Rear Shocks
- Lunati .660 lift valve spring kit
- Super T-10 4 speed manual
- Nos Nitrous Kit
- T56 w/ Bellhousing
- FS: chrome c5z06 wheels + nitto NT05 (295/35/18, 275/40/17)
- Kirkey lt calipers
- Tach, Cam, MT ET Street Radials......
- complete set of charcoal leather seats
- FS Racetronix 37 lb/hr injectors
- eibach lowering springs 150 shipped
- ** MSD 2351 Boost-A-Pump Like New **
- ** 225/225 Duration 581/581 Lift on 113+1 LSA CAM **
- JE forged 408 pistons
- New rear slp/eibach springs & bilstein shocks
- MASSIVE parts sale. Spohn, BMR, Rims, 10 bolt and Part out!*PRICE UPDATE*
- 2006 LQ4 parts
- low mile Ls1, 9in and 4l60e for sale. cheap
- FS: (4) WS6 wheels
- TA WS6 Hood, Hacth & Rear Bumper
- HSW/Cold Fusion solenoids and dual nozzle kit
- Superior axles for 7.5" rear - bnib
- 2005-2010 Mustang Floor Mats
- Manton 11/32 7.625 pushrods and shims for TFS heads/stock rockers
- Low miles ls1 ls6 stock rockers
- SOLD ***Price Drop*** - Brand New In Box Ed Curtis (Flowtech Induction) Custom Cam
- ls6 spun rod bearing
- Crower PN 00240 Compu-Pro Performance Level 2 Camshaft with Lifters
- Lucas/Delphi 42lb Injectors **HUGE PRICE DROP**
- 1999 Corvette Wagon Wheels
- Goodyear Eagle F1 Supercars 295/35/18's with 7/32nds
- Z06 Replica 17" 275's Goodyear F1
- Huron Speed Turbo Kit Special Offer!
- UMI torque arm,BMR LCAs, Panhard rod, rear springs, Ported TB, Fuel rails
- Bottle Heater & MSD Digital Window Switch
- Motive 4.10 Gears and Install Kit
- FS: RPS BC3 carbon carbon tripple plate Clutch ****CHEAP****
- ls6 intake
- steel wheels: 215/55/16 snow tires
- Bogart D10 Wheel Set
- Parts for sale! Exhaust parts, injectors, more!
- stock 02 ws6 front and rear coil springs
- new tsp chromolly pushrods
- stock pushrods,oil pump,timing gears and plug wires
- Torque arm needed
- stock fbody master cylinder
- R.J.S 5 point harness
- valve cover spacers/ valve covers
- Rollmaster ls1 double timing chain set new in box
- Stock low mileage 28lb injectors
- Koni DA Front Shock
- autometer mini shift light
- ARP Head studs
