View Full Version : Parts Classifieds
- ls1 throttle body
- Diablo Sport Predator 2010+ Camaro ss NEW IN BOX
- Weld RTS, Billet Specialties, built t56, fresh 4l60. LOOK!
- WTB: Accufab 4150
- 2004-2006 gto parts, wheels, tires, nitto, nitrous, ls2 intake, ls6 intake, etc!
- 3rd gen camaro interior for sale
- Fast Intake
- Brand new caddy cts-v oil pan kit
- AIR and EGR Block off plates
- Stock LQ9 camshaft
- Stock GM Degree Thermostat
- L92 Valve Springs
- Built 4l60e, full wilwood kit, ls, lt1 and ford parts, new and used
- slp maf 01-02 fbody
- JGS 60mm Wastegate
- 1998 camaro z/28 LS1-auto part out , CAR IS SOLD
- 93-02 kenyy brown convert d-diamond, lt1 k&n 2002 SS mat
- Sold
- MSD boost a pump, 342 ring and pinion, Ls1 intake w/ rails
- ARP rod bolts, texas speed oil pump
- Chris1313 Ram Air and SLP Bellow with HSW Nozzle and jets
- 4l80e, cheap!
- freshly milled 317 heads
- new never intalled eps 230/234 cam
- WTB 215cc or bigger heads.. Dart or AFR
- WTB: Firebird dash pad and various interior panels
- heads,cam,lifters,pushrods,timing
- *HUGE* Spartan parts sale - Cams, Longtubes, Trans, Converters, Fuel pumps, etc!
- Cartek Stage 2 heads
- Brake pedal, hatch divider, factory lid
- wtb: 4l80 performance converter
- Edelbrock intake manifold/ignition kit w/Holley 750 double pumper
- Bogart Drag rims F body
- 22" rims/tires
- 4L60E Transmission/Converter/Flexplate
- 370 iron short block pics added
- 2002 241 heads with ls6 springs
- 97-04 LS6 LS1 BBK SSI-Series Intake Manifold
- 2000 alum. 5.7 block and more
- 240SX V8 Swap Part Out (T56, GTO PAN, ETC)
- Ls6 cam and springs
- Weld Draglites (Fronts Only) *SOLD*
- SOLD FS: Like New BOGART Racing Wheels
- (2) Ls6 Intakes, stock f body throttle body,
- 5.3 L33 parts - water pump, manifold, dip stick
- Comp Cams #11755-KIT 1.75:1 ratio rockers, guides, nuts, studs
- T56, twin plate clutch
- Stock Springs
- Fbody Turbo Kit PT88 *BRAND NEW*
- FAST 102mm cathedral port intake used
- Intercooled Custom STS Turbo kit
- kent moore 4l60 input shaft seal installer
- wtb passenger side valve cover
- Brand new 93-2002 f-body power window motor
- Complete Ms3 cam package for sale, lots of parts, look inside
- Set of stock rocker ams
- stock fbody lid and fram filter
- NEW ZEX dry kit with bottle PRICE LOWERED
- lt1 and ls1 parts, vette trans, heads
- LS2 LS3 LS7 Corvette DBW Gas Pedal
- Comp Cams pro Magnum 1.75 ratio rocker arms
- Fuel accesories
- 10 Bolt, Girdle, UMI relocation brackets and more
- For Sale
- Misc fittings, valve seals, headgaskets
- F/S 17x9.5 C5 DD (black/polished lip) Wheels/Tires
- LS1 / LS6 Engine Cradle
- 06-12 LS7 ZO6 Exhaust manifolds
- Misc. GTO Parts
- WTB: 1.7 SBC rockers
- Koni D/A fronts & S/A rear shocks
- 2000 LS1 throttle body and a BBK 80MM Power plus throttle body
- SLP Dual Dual Tips
- Revmax 3600 stall
- Please Remove
- BMR th350/powerglide crossmember HALF PRICE.
- ls1 stuff part out for a 402 build
- 2010 Camaro SS wheels
- 90mm LS TB from a TBSS
- LS1 Pistons/Rods
- LS1 FAST Fuel rails New in box $100 SHIPPED
- HP Tuners for all 1999 & 2001 LS1 fbody's
- parts for sale
- AEM Inline Wideband UEGO Controller - NIB
- Brand new TrickFlow 265 6 bolt heads
- 440LSX short Block 4299.00
- Aeromotive Belt drive fuel pump and mount.
- Shop cleaning part II
- Ls2 Fuel Rail Covers, Z51 Radiator
- BNIB Texas Speed LS6 ported oil pump
- XER281HR, Comp 7.4 Pushrods, Trickflow dual springs, Titanium retainers
- WTT Lights
- Trans Am Plate Filler
- Oem ws6 emblem
- Intake/Fuel Rails/TB/MAF others
- LS2 Intake and MAF
- ls1 intake manifold, stock cats
- wtb: Front Bilstein struts and 1LE springs
- 241 heads, 3600 stall for C5, A/C Compressor, truck oil pans,
- Harris Speed Works Bottle Heater
- FS: 2002 camaro cluster and PSI pigtail
- SLP Camaro SS floor mat set Ebony (neve used)
- Summit Racing Oil temp/Trans temp gauge NEW
- Stock parts from 2002 Z28
- OTC 6697 Damper Puller and Hawk damper install tools
- FS: LS9 injectors
- LS1 Intake, TB, MAF, Harness, Fuse blocks, etc
- GM Musclecar pan
- WTB ATI Super Damper
- Fast 4150 TB for sale
- Mast 2pc 4150 FI Intake
- used tick master
- 1963 chevy II project for trade for built rear/built t56, ect
- LT1 A4orT56 PCM & 6spd Engine Harness
- Trickflow 7.350 pushrods
- PRICE LOWERED AGAIN!!! BRAND NEW Diablosport Trinity Tuner
- JL Audio (4) 8w6 Subs *new*
- LS Edelbrock Headers Cheap
- 3 in Random Tech Cats NEW.... NEW 3in V bands seperate
- NEW LT1 eagle cast 383 crank
- 3400 Precision Vigalante Stall
- McLeod Adjustable Master $150 Plus Your Stock MC
- TH350 swap
- LS1 Engine Wiring Harness with 4l60e computer
- erl throttle body 102mm dbw
- SLP Lid
- LS3 SLP 25% Underdrive Pulley
- VFN 98-02 WS6 Hood
- SLP 25% UDP Slightly Used
- 3 Sets of LS1 HEADERS and Y-Pipe
- BMR torque arm and crossmember
- LS1 Fuel Rails
- Nitrous bottles, 2 custom
- SVO 42# Green Tops SOLD!!
- NX Gemini Nitorus Kit
- LQ4 engine parts.
- F/S LS1/LS2 Edelbrock 245cc heads by West coast racing cylinder heads
- Pro-mags, Guideplates, Valvesprings
- B&B Exhaust + ORY/cutout **Price Reduced**
- engine trans harness and pcm
- 243 heads and gasket kit.
- Predator Tuner.
- FS: RO_JA Formula 5 wheels
- like new 305 30 19 / 235 35 19 / 275 35 18 HANKOOK VENTUS V12 EVO TIRES
- Hotchkis performance subframe connectors
- Full Trans am brake system!
- 411 red/blue ecm 802 blue/green ecm & harness
- Fuel pressure gauge, Fuel line....
- MILD CRANE CAM,PAC 918 springs
- FS: 04-06 GTO GMM Ripshift Race Version
- wtb: Front Bilstein struts, and rear 1LE springs
- Camaro turn signal lever
- Modified Stock MAF from a 2000 WS6
- LS1 ARP Head Studs
- NEW L92 heads/valves
- Aftermarket Torque Arm for Sale or Trade
- WTB 7.4 hardened push rods
- Items I have laying around
- Ls2 intake fs/ft
- WTT: CTS-V Oil Pan for Stock F-Body
- New Callies LS Dragonslayer 4.125 crankshaft, 24 reluctor.
- Painless harness and PCM for 97-98 LS1, $500 shipped!
- wtt or wtb fast 102 intake and tb
- 93-97 Camaro grille
- F body STS turbo kit
- Pair of slightly used Afco 8" Coil-over springs 450#
- Built 4L60E with custom stall...300 miles on it!
- Comp Cams ls1 tensioner/Spoolin perf alt relocation bracket
- TSP cam/1998 Camaro parts
- SPEC Stage 2 clutch
- NEW Nitrous bottle
- Autotap ATUSB Hardware
- ls1- lt1 maf translator plus
- weld drag lites and tires
- Kooks 1 7/8 F-Body LT's
- Ls6 heads
- NOS Window switch, RPM TPS based
- rebuilt 5.3 shortblock or complete feeler
- Ebony interior
- 98 Z28 Gray Interior
- WTT/WTS: BLS High Beams
- Hypertech Max Energy and SLP 85mm
- True fire firebird hood for sale
- 05 LQ4 6.0 71k miles
- lq4 parts
- LS1 Stuff + More
- Stock Z28 Spoiler (Black)
- Stock Throttlebody C5
- SLP Ram Air/Cold Air box
- 99-02 T56 Harness with PCM
- Factory and performace stuff for sale
- Interior parts, Front clip, and rear differential
- NX EFI single nozzle shark nitrous kit *SOLD*
- c6 wheels 17''
- For Sale HP Tuner
- FS (((C6 Seat Rails)))
- misc. parts/ TA driver & passanger taillight
- Cam/Spring Kit/Push rods For sale
- Forged 6.0 long block LS
- FS 01-02 WS6 17" Speedline Wheels for reg WS6 Wheels
- FS: 2010+ Camaro Procharger 3-Core Intercooler & Piping...
- Lunati connecting rods, CCW Wheels & guage overlay
- borla exhaust c5 corvette
- LS1 crank pulley
- timing chain, oil pump, motor mounts
- direct port kit
- Left over parts, some good some bad...
- *98 Z28 Roller Partout*
- Ls wiring harness oem un cut dbw 24x and 58x
- 241 heads + ls6 springs.
- Patriot 243 heads
- FS: Ported LS7 Heads w/ springs
- chrome c6 wheels
- FS: 224/224 .581/.581 116 lsa Cam
- fs:tsp ms3 cam 114lsa 250.00
- ET Streets w/ 10 spokes
- Pacesetter Ceramic Longtubes, ASP pulley
- Camaro/Firebird parts (SS HOOD GRILLE, center console, HVAC display)
- Trans Am & camaro part out. MANY parts here! CHEAP
- 98-02 F-body Water Pump
- 120# injectors
- Stock LS1 Harmonic Ballancer Pulley
- Nitrous stuff, 10-15Lb Bottles, gauges, N20 PUSH
- MPT 70 with .96 housing
- Complete Moser 9" like new, 5k miles w/ ds
- FS: M3 CSL repro wheels & tires
- 2006 GTO T56 Trans and all swap parts
- FS: GTO Diff Insert
- FS: ZR1 cam
- LS3 injector's, NGK BR6EF plugs
- Misc LS3 parts, clutch, flywheel...
- BNIB F-body Poly LSX motor mounts
- ASP Underdrive pulley
- Qa1 springs F/S
- F/S LS Supercharger/Intercooler setup
- tt2 south tx and 555r for sale
- coil packs
- ls1 intake with injectos tb and fuel rails
- 860 Heated Nitrous Bottle Bracket SOLD!
- New Polished F1R Blower
- F/S silver firebird door panels
- F/S Z06 Wheels
- New balanced HKE 383 shortblock MD.
- 97 Z28 Part Out
- Twin Walbro GSS 340s with Harness
- FS: 862's, NEW LS1 mls headgaskets, NEW ARP headbolts
- Hurst Quarter Stick
- 78mm DUAL STAGE PLATE. FS
- Advanced Induction AI Ported 241's and Custom Cam
