View Full Version : Parts Classifieds
- Smoked headlight and turn signal covers
- Stock rear parts and driveshaft
- HP Tuners Pro SOLD
- FLYCUT LS1 Pistons and rods!
- nano 4500 and 15# bottle with remote opener also
- LQ9 parts
- (2) Garrett Turbos
- 17/18 CCW Classics with C5 offset and nitto drag radials.....FS/WTT
- steering wheel and air bag for sale
- SLP heavy duty ported oil pump
- ** LS1 Brake Master Cylinder***
- red corvetter valve covers.
- FS: Innovate OT-2 w/ iPhone/iTouch/iPad interface
- C5 ac compressor
- F/S: LS3/L92 Piston & Rods
- Subthump Subwoofer Box
- Harris Speed Works Nitrous kit
- Nitrous Accessories heater, purge, switch panel
- SLP subframe connectors SFC
- LT1 or equivalent SBC Stock Roller Lifters + some
- FAST 33 LB Injectors - Brand New
- Brand New in Box - Texas Speed Catted Y-Pipe
- C5 Calipers Front + Rear! Rebuilt w/ Custom Powercoat
- NOS system universal wet kit
- Stock ls1 intake with throttle body
- WTT/FS 18x9.5/10.5 c6 zo6 machine/black wheels&tires
- 2002 Trans AM wheels
- LS7 lifters - Brand New!
- Coated Flowtech LS1 Longtubes and Y-Pipe
- Wtt- built T56 for built rear end
- 00-02 slp y pipe
- GMMG Oval Tips "SOLD"
- SOLD BMR Torque Arm - chromemoly full length adjustable with new digital angle finder
- Camaro and Corvette parts and turbo exhaust housing
- SLP ls6 heavy duty ported oil pump
- DBW throttle body
- MSD Optispark for 95-97 LT1/LT4
- 6.0 liter block,heads,rotater,wiseco etc
- 3200 fuddle converter
- Hurst quarter stick shifter and spacer for old style converters
- need t56 bellhousing /t56 cross mount
- s10 lsx swap longtube headers
- ported ls2 heads, 90mm intake and cable tb, ported oil pump, 1.8 roller rockers
- Trick Flow 7.350 pr's
- sold
- ARP LS1 Rod Bolts New in Package...
- ported ls6 oil pump
- Nitrous kit, 2 cams, Underdrive pulley
- WTT UMI adj tunnel mount TA for normal length adj tq arm
- OE 97 Z28 Hood Pick Up Only
- WTB: stainless Corsa catback w/ 3.5in dual/dual tips
- floemaster 80 series
- Brand new trucker cam and VHP/CRANE 1.8 rockers (price reduced)
- single roller timing chain set
- WTT powder coated ZR1's for Drag setup
- F/S ls6 intake and Nos 78 plate
- F-Body Water Pump SOLD!!!
- AMW Black Catch Can with Bracket
- FT/FS ls1 short block
- FEELER: 2000 LS1 out of a WS.6 46k perfect condition.
- O.E. PERFORMANCE 120B (gm rims)
- Corvette LS3 FRC
- Corvette License Plate Cover
- 241 heads with LS6 springs
- Factory Corvette Shift Knob
- WTB: ls1 misc engine parts/ sensors
- FS: Comp/TD 1.8 shaft mount rockers
- F/S Harris speedworks microedge
- Ford Motorsport 30# Injectors
- New LS1 pushrods (Stock)
- TSP stg3 CNC heads,Melling oil pump,stroker cam!!
- Livernois Stage 2 LS6 Heads
- Boost Controller Setup - MSD 7562 Grant McCrary Setup
- WTT/S 335/35/17 Hoosier and 26x11.5x17 et street
- Built 4L60e and FTI 4,000 stall
- Cleaning out my shed, LS1 parts . . . .
- FS - TPS, IAC, and MAP sensors
- c5 corvette corsa pace car exhaust (chicago)
- 93-02 BMR Red Tunnel Brace New In Box
- WTT C5 Z06 Rims 18x9.5 with Tires
- ls1 front brake conversion kit for lt1
- Set of Hoosier R6 Tires 275/40/17's & 315/35/17's plenty of life
- 18x8.5 & 19x10 O.E. Performance 120B's WTS/WTT
- New Textralia OZ700 Clutch(Z Grip) & Goodyear Eagle F1 Supercar 295/35/18's (7/32nds)
- Hickock Fullhouse wheels w/like new Michelin PS2's (17&18's)
- Interior and seat parts
- LS1 T56 tranny
- GI Fresh from the machine shop LS7 Block
- NEW Nitto NT-01 Drag radials 245/50/16
- 2000 Camaro SS parts
- 93-02 UMI Performance Tubular Adjustable Lower Front A-Arms
- 6.0 complete intake/tb/fuel lines
- Ls1 engine need gone ASAP!!!!
- SBC 350 and msd ignition parts
- comp cam 236/242 615/612 lift
- Nasty performance fuel rails, 90mm Nitrous TB plate and other items.
- clean out. gm exhaust and cams
- 2OTL in really bad shape
- weld prostars
- wtb ls3 victor jr. intake & roller rockers
- TCI Super Street Fighter 3500 Stall Converter f/s
- slp lid stock maf
- K&N CAI, Borla Catback
- TCI flexplate for 4l80e swap.
- LS6 Heads - 1 complete, 1 damaged
- Stock LS1 Intake and Exhaust parts.
- Vic Jr w/ direct port n20 kit
- ws6 6 speed console BRAN NEW $150.00
- 99 LS1 injectors / truck manifolds
- Fs: Tr6060
- Misc LT1 parts F/S
- WTB: LS1 F-Body PS bracket
- turbosmart 48 and 50 wastegates
- NIB 160* Thermostat w/ housing $50
- 243 Heads
- Kenne Bell Boost A Pump BAP Brand New Never Used!
- wtb weld prostar fronts and 275/60/15 drs
- lifters
- Roller rockers
- T56 manual crossmember for lsx fbody
- 233/239 .598/.603 113lsa cam SOLD!
- FS: Random Technology stainless catback f-body *lowered price*
- Keene Bell Boost a Pump
- C5 Z06 sway bars
- Lunati Dished Pistons
- Patriot Gold Dual Springs
- Gm maf
- Selling my Brand new EPS 226/234 cam and patriot 650 spring package
- ultimate torque converter 9.5"
- Bnib Texas speed 408 rotating assembly, callies and wiseco with lq9 block
- Scoggin Dickey Billet Throttle Cable Bracket
- Wtb ms3 cam.
- 241 Heads with Patriot .650" spring kit
- ls1 3bolt FTI Cam Super Low miles Cheap 300 shipped
- AI 226/234 camshaft
- Fiberglass doors & Lexan 70-81 Camaro-Fiberglass dashboard universal fit
- NXL direct port and other nitrous parts
- Clevite race coated mains MS-2199 HX
- Borla XR-1 (40085) -New- QTP E-cutout motor, BCM, Snap on torque wrench
- FS: TSP Giant Cam 248 / 254 112LSA
- Wtb: Umi lca p/n 2039, LS1 Rocker Trunion Complete or Kit, BMR/Strano/LT1 Eibachs
- BNIB Lunati Valve springs good for .660 lift F/S
- Wtb udp
- Sts Rearmount Turbo
- *SOLD* Forgeline RS 17x11 wheels
- 317 heads
- Stock Firebird Springs
- ls1 f body pan covers comp lifters and more look inside
- BMR bolt on relo brackets for 10bolt
- SLP Camaro SS Car cover used
- Raptor shift light
- LS1 fbody Pacesetter Longtube Headers f/s
- **** FOR SALE HRE 547R wheels w/Nitto Invo tires*****
- 6LE rear valence
- Complete Big Stuff 3 setup w/4l80E harness
- Parting out 2001 SS
- Strange rear brake kit
- Wtb misc
- PLX Wideband and PLX Gauge
- Tbody,intake bolts STB FAST valley,WP bolts,vette fuel rail covers, ls6 springs
- ls1 ebony console
- ls2 intake manifold, 7.400 pushrods
- Moser 12-bolt Rear end with control arms and torque arm and anti-roll bar
- FS: Heads/Cam LS2
- Calibrated Success DVD - $215 shipped
- Tan seats and Carpet
- Comp Cams 1.6 rockers, Stock rotating assembly, AC Compressor, Rims and more.
- Brand New LS7 clutch with RAM Aluminum flywheel and ARP Bolts
- Stock upper/lower a-arms
- Brand New Comp 7.425 Pushrods
- Wtb rear suspension
- Yank ss3600, BMR Xtreme T/A and crossmember
- Brand New Custom Comp Cam 231/238 LSL/LXL Lobes
- 241 heads
- K&N intake for C6Z
- SOLD Tick Remote Speed Bleeder for clutch hydraulics
- OEM Camaro Emblems.Lower price.
- billet dip stick lokar SOLD
- slp dual roller timing chain (needs oil pump drive)
- FS: 2 Sets of GTO FRCs
- Fast fuel rails
- LS1 Engine
- th400 jw ultra bell transbrake !!!!!!!!!!!!!!!!!!
- 2" Kooks headers, ceramic coated
- Set of 4 speedline wheels with 2 tires
- Parting out '98 trans-am in nw ohio
- tsp 7.425 pushrods, ppg shopline silver metallic paint
- Garage clean out Camaro Parts Cheap
- hp Blow Thru carB.
- 13"cobra brake kit new! $300 plus shipping
- WTT: My 18" C6 replicas for your 17" wheels
- Wtb ory ypipe
- 2002 4L80e 4 wheel drive
- SOLD! = T/A LT1 Tail Lights
- C5 Wagon Wheel F1 Supercar tires
- Trans am and Chevy sign
- Camaro 4L60E for sale
- Stock LS1 intake and throttlebody
- BRAND NEW Front Right and Left Powerstop Brake Rotors
- Brand New 04-06 GTO Slave Cyl
- 2002 trans am passenger headlight 56k miles
- Ls6 Valley cover with knock sensors and harness
- LS1 Bell Housing
- Parts needed 93-97 camaro, headers, kmember, susp, and lots more
- GTO 18" wheels and Continental tires
- Weld pro star look alikes (jegs) 15x8 $200 shipped obo
- 98-02 camaro dzus rails bolt on fenders
- LT1 PARTS UPDATE !! stock and performance
- ls1/2/6 intake manifold rails slave oil pump
- APS Twins kit with upgrades SOLD!!!!
- stock GTO oill pan..
- Lt1 t56 bellhousing
- LT1 Powerdyne Supercharger kit
- 4 channel abs module
- Gm 85 maf
- FS ((( new AUTOMETER Cobalt Water Temp gauge)))
- ls1 short block, covers, ls1 heads, and other stock parts
- 2 toyo proxies T1R
- walbro 255 inline pump-walbro 255 intank pump-grey leather seats!!!!
- Engine Stand, Patriot Springs, MAF , TB and More
- LS1, LS6, 6.0L, 5.3L, L92, Vortec engine parts, TB, rockers
- SLP Dual/Dual, MAC Mid-length Headers
- F/S: 2-Hoosier 275/35/18 Road Race tires
- Want to trade! OR sale!
- Ignition Coil LT1
- 2010 Camaro SS oil pan, oil cooler, low oil level sensor, and bolts
- Stock Throttle Body
- Stock Clutch Disc
- Procharger D1SC
- LT1 T56 with bellhousing
- Autometer Ultra-Lite gauges
- WTB Visor (Driver) Ebony
- Camaro and Trailblazer ss parts ..pic heavy!!
- OH: Stock 2010 Camaro LS3 Exhaust Manifolds: 5K Miles
- Wtt/wtb 15" billet specialties fbody
- LS1 GTO front sump Aluminum Fabricated oil pan
- Ls1 Y-body oil pan, F-body exhaust, valley pan, alternator bracket
- GI: ls6 intake plumbed w nitro daves money maker kit $700
- 4.11 Ring & Pinion - 12 Bolt
- Six speed inc. T-56, mcleod twin disk and quicktime bell housing
- LS6 Yellow Valve Springs
- f.s hurst billet plus $160 shipped
- Intake and Headers F/S
- AFR Springs,retainers,locks
- Stock F-body A/C system!!! SOLD
- Taylor Spiro Pro 8mm Plug Wires (SOLD)
- sold
- Felpro LS1 gasket set *cheap*
- PRC Stage 2.5 LS6 Heads, Mickey Thompson Drag Radials
- LT1 Solid roller cam kit with springs and lifters
