View Full Version : Parts Classifieds
- T56 6 speed from '00 TA less than 5,000 original miles
- NEW Wilson elbow
- ported LS6 oil pump housing
- Fast 102
- LS3 Block, Darton sleeve stroker baseline
- WTS/WTT Brand new Fast ls1/6 fuel rails w/fittings!
- LT1 cam FS 226/234
- lsa new gm bare heads
- Turbo technology race kit f/s + few other parts
- M/T tubes ( only used for mock up )
- 315/35r17 BFG GForce T/A Drag Radials
- Stock LS1 Intake, EGR, and AIR system.
- set of bosch 160lb injectors
- new ss hood 98-02
- fFAST sets of fuel injectors ls2 80lb injectors
- 3500 stall 98 ws6 trade for stock stall
- KYB AGX Front Struts
- NIB Yella Terra YT 6645 LS2, LS2, LS6 Brand New
- Koni Rear SA Shocks
- New BMR Lowering Springs
- Morel Link Bar limited travel lifters for LS engines
- Brand New Go Fast Parts From My Turbo Car
- edelbrock timing cover, comp ultra gold 1.8 rockers
- misc parts
- Nitrous Outlet 97-04 Corvette Switch Panel
- Glowshift Elite 10 gauges - nitrous, narrowband af, oil temp
- comp r lifters comp pushrods and ws6 wheels 42 lb injectors
- Nitrous Kit FS
- SS Emblems, Z06-Style Z28 Badges, and Chevrolet Script Emblem
- WTT My Brand New 1982-2001 6LE Leather Seats and Brackets for your mint stock seats!
- faceplated t-56
- 04-06 Pontaic GTO Eaton Truetrac posi 28 Spline
- Wtb stock pulley
- ls2 corvette entire clutch system for your ls1
- hooker catback 3" and bmr lcas
- 92mm Throttle Body [COLOR="red"]SOLD[/COLOR]
- FS-DMH Cutouts
- Passport G Timer by ESCORT For Sale
- Valve covers and coils
- **PICS INSIDE** 06 CTS-V Oil Pan 3200 miles LIKE NEW $150 SHIPPED!!!
- Face-Plated T56
- Eibach Pro Kit Springs - SOLD!
- WTT: MTI clear lid for SLP or similar lid
- TSP 7.4 Pushrods, Injectors, Sweet Thunders, 3.5 Powersticks
- Pioneer subwoofer in Fbody custom box, kicker AMP, Hand ported TB, edelbrock elbow...
- Scorpion 1.7 roller rockers
- Srp flat top pistons
- Tan Camaro door panels. Excellent Condition!
- LS6 Cam SOLD
- L76 Intake (new)
- F-Body T56. Sold
- Spohn Solid Motor Mounts, SLP LM Tips
- LQ4 Short Block SOLD
- Delphi/Lucas 42# Fuel Injectors
- CCW Drag Pack - FRESH rubber
- FS: TFS heads, push rods, HS roller rocker package
- LSX 408CI turbo motor NEW, built by HKE
- PowrMAF, FIC injectors, Procharger parts, and Misc items
- 5.3 DOD valley tray for sale
- Autometer Ultralite Wideband, Boost Gauges, 2 1/16", C5 Double Pod
- 2 sets of comp 7.400 .080 p.rods
- Bare Dart 205's, motive 3.42 ring and pinion
- f/s rps twin carbon flywheel ps plate
- FAST 90/92 nick w tb
- WTT/WTS sweet thunder catback for magnaflow!!
- lokar 700 r4 billet dipstick
- Misc. For Sale.....
- FS: Used cam, BNIB H&R springs
- FS: BNIB Coated Pacesetter LT's
- SOLD: Brand New TSP 228R Cam Package
- Innovate Motorsports LM-1 Wideband Air/Fuel Ratio meter and 98 Throttle Body for sale
- fs:102mm umi tb
- Turbonetics turbo (Hurrricane) 72mm
- ls3 and 383:fs
- Precision 67mm Front Mount Turbo Kit (PICS,VID,DYNO)PRICE DROP 2300
- Ls1 wiring harness
- Lq4/Lq9 6.0L Iron Block Brand New
- LS6 oil pump, Comp 7.450 pushrods, 05 CTS-V oil pan
- 99SS Parts Car
- TB connectors vette up to 04
- Volant CAI 05-06 GTO
- Jegs 15x8 Stars with ET Drags
- FS: Fuel pressure regulator return style
- WS6 Speedline Center Caps Brand New
- 6spd swap stuff
- 4 channel 3:42 f-body rear
- WTB Wiring Harness
- 4 Channel ABS Module
- Nitrous Outlet bottle mount
- 98 T/A Exhaust Manifolds
- LS1 valley cover
- 2000 Corvette seats
- Oem ls1 camshaft, ls1 intake, stock shifter , slp strut tower, (PRICES REDUCED)
- LS3-style intake assembly
- LS6 Block $600 O.B.O.
- 2000 z28 part out !!!!!
- PCT Stall converter 3800-4000 ls1 4l60e
- roll master double roller
- WTB TSP Catted Y pipe
- Ralbert00 good seller
- Steering joint for f body 98-02
- Glowshift 3-gauge a-pillar pod
- Steering column with tap/paddle shifter
- Honeycomb Taillights
- 799 heads & 5.3l engine
- FS - LS6 clutch kit - 3k miles
- LS1 Parts
- Monster level 4 clutch for sale!
- Star Mountain Motor Vacuum Pump + Air/Oil seperator + Acc
- LS7 lifters / doubble roller timing chain
- LS1 parts
- WTT LS6 or WTB FAST 90 or 92mm
- profesional products intake bbk tb
- procharger piping
- Patriot golds dual spring .660, new valve seals
- Comp Cam, any part #, or custom, new!
- Monster clutch billet steel flywheel 12 NEW
- SPARE PARTS CLEANOUT!!! heads,pushrods,rockers,misc, etc...
- LS1 K member with motor mounts
- C5 Corvette Parts
- Eaton Posi 12-bolt 33-spline 4-series Almost new!
- HEATER CORE, K&N cone filter, T56 Crossmember
- FLT State 3 4L60E with 0 miles, shipping to FLT 03-20-12 for complete rebuild
- Stock Steel and Aluminum Driveshafts
- TFS Sbc heads, etc
- SPOHN swaybar relocation kit..new
- FS OBDII code reader INNOVA 3110
- T-rex cam and misc. parts
- FS/FT-Fresh 317 Heads(New Valve seats,New valve seals) or trade for 228R cam
- LS2 standard bore Aluminum block
- Tick Master Cylinder
- 3.73 ring and pinion for 12 bolt
- shocks, lifters, rockers, t56 main shaft... 36k miles when removed
- 112 gto maggie kit
- LS2 rods and pistons with arp 2000 rod bolts
- B&B Billy Boat Long Tube Headers FCOR-0446 New in Box $950 Shipped!
- melling oil pump
- 4L60E truck tailshaft- SOLD!!!
- Bola tips
- Custom spec cam
- LS6 intake with injectors and rail - SOLD
- Ported S/R Torquer Heads! Part #042670
- 93-02 camaro rear exhaust valance for round tips
- Convertor
- Powerbond LS1 SFI crank pulley
- Brand new ls3/l92 rocker arm's and stands
- Stock 28LB LS1 Injectors
- WTB Escalade engine cover
- Tpis tb 90mm
- Nitrous Outlet 90mm plate system with extra's
- Brp lsx chevelle headers
- jegs pro star wheels. 450.00
- LOOK!!!!! COMPLETE 241s 26k mi.
- 17x9.5/17x11 American racing trackstar s wheels
- Ws6 speedline wheels
- T56 to 9in driveshaft
- bbk long tube headers and ypipe, slp exhuast loud mouth 1, cutt out, ss hood,
- Diamond 4.030 boost pistons
- Driving Gloves
- Hub Rings
- F-body manual pedal assembly
- 241 heads with bee hive springs
- Stainless Works 3 inch cats and oval exhaust tips
- GMMG Oval Tips
- A few misc camaro parts for sale and SS wheels!
- Ls2 pistons, floating pin rods
- overhauled LQ4
- LTX left over parts
- Left over LSX parts
- STS turbo kit complete $1600 shipped
- HSW wet kit + purge + bottle heater
- LQ4 cam,f-body/truck flexplate, coils
- FS: Zex nitrous system..Complete with auto bottle heater!
- TRADE: PP Polished 85mm manifold for LS6 or a FAST setup plus cash on my end
- WTT Snowflakes for Salad Shooters... (In KS)
- WTB: Stock Mass AIr Meter (MAF) in South Fl
- 99+ Racetronix fuel pump, harness and body ground upgrade
- Roller Rockers
- ls6 cam out of a 04 cts-v and crane valve spring compressor
- 1998 camaro part out
- Pro street rims and tires nova camaro drag race Mickey Thompson
- F/S LS7 valve springs
- WTB T56 - got ROBBED now need a T56!? :/
- Fast 90/92 intake and tb
- Vortech V1 T trim, 4 bolt main, Crower rods
- stock vette cam 30K, lq9 balancer, corvette balancer
- C5 Slp loudmouth
- 05 6.0L harness and pcm
- Many LS parts, many new
- synergy 2 Step, Black visors,STock 60,000 mile gauge cluster, line lock and more!
- Heat sink coils, brackets, and harnesses.
- Stock 17" GTO Wheels with Summer Tires (Roselle)
- Kooks 04 GTO 3" mid-pipes with cats
- Pat G cam for sale
- Weld alumnastar wheel center (1)
- SVO 30lbs injectors (red tops)
- Complete 6.0 truck intake with fuel rails and throttle body
- Lq4 6.0 lsx carbed t/k motor
- New Siemens Deka 60 lb/hr Injectors
- Diablo Predator U7193
- f/s stuff u dont need but u may few parts added
- Mustang fox Ls swap exhaust
- C6 Z06 Custom exhaust X pipe, Corsa Tips, ls7 Manifolds, ls7 Catalytic converters
- FS: Ported LS1 Throttlebody cheap!
- Ls7 clutch assembly and hv dty slave cylinder
- LS3 Intake Manifold/Fuel Rail/Injectors/MAP Sensor/Bolts
- FS: LS3 G6X3 Cam
- comp cams cam, trick flow pushrods, ls6 oil pump
- FS: C5 Magnesium Wheels
- Factory ls1 and lq4 parts
- wilson 4500 throttle body
- Asa cam, low miles
- SLP Driveshaft Loop, True Duals, Stock Springs
- LS transmission mount NIB 6-speed or Auto
- Jantzer ported TB
- 1.7 Non Adj- Yella Terra Ultra Lites LS1/LS2/LS6 FS-
- ls6 valley cover brand new with gasket
- Stock LS1 injectors
- SLP ls6 intake manifold, lower airbox shelf, SLP lid, K&N filter
- Callies Magnum, Stock Oil Pan, GMPP Valve Covers
- Dr. X-Link, Manley 7.4 Pushrods, Intake Bolts
- LS2 Fuel injectors
- 2009 5.3L & 4.8L Engines
- Pair Used 243 Heads
- All sold
- AutoTap OBD2 Diagnostic Tool with HP-Compaq Tablet PC with Bluetooth & Wifi
- (2) Walbro 255 Inline fuel pumps
- TSP bullets off the true dual setup
- LS1 heads, LS1 camshaft
- 275/40/17 Riken Raptor Tires
- l92 truck front accessories lsx ls1 ls2 ls3 6.2 6.0
- wtb ls1 ported heads
- FS LQ4 parts 317 heads etc
- Cam, 7.450 pushrods, Comp Rockers
- Sold please delete
- NEED ASAP LS1 alt/ps bracket
- WTB used meziere water pump
- NOS wet kit with heater,purge two bottles and more
- ATI Damper & Cog Pulley Kit
- Charcoal Leather TA Seats(Power) Price drop
- WTB fast 102 intake for Gto ls2
- slp lid
- Delphi/ Lucas 42 lb fuel injectors
- LS1 Intake Manifold Complete
- C6 Z06 Procharger 8 rib D-1SC kit
- BNIB 82-02 F-Body Rear Air Bags
- Ls2 injectors , autometer tach adaptor,ls2 maf
- RAPTR CAM, Shipped Overnight
- Fast 90 intake manifold
- Borla Catback Stock Throttle Body and Vette Fuel Rail Covers
