View Full Version : Parts Classifieds
- New UMI Panhard relocation kit
- 243 Heads
- Patriot Stg 2 heads and Vrx4 cam
- Truck and Fbody Manifolds
- 10 bolt ta girdle
- delete
- WTB-LQ4 piston rings
- FS: Complete ls1 240sx AC system
- Set of Rocker arms and 99-00 LS1 heads
- psi 1511ml springs nib sold!
- slp rockers, melling oil pump, timing set
- 04 LQ4 parts
- Strange 4.30 gears for s60/dana60
- WTB stock exhaust sys flanges
- For Sale Harland Sharp Roller Rockers
- 3.42 gears for sale oem 7.5
- New in Box: NOS Progressive Nitrous Controller P/N 15834NOS
- Almost new SVO 30lb Injectors
- 8 rib pulley 4.25 and tensioner (USED)
- WTT C6 rims for C5 z06 rims
- (4) almost New Yokohama tires 275/40/17's
- Tremec T56 Transmission
- ***precision 91mm upgrade...
- ***turbonetics Y2K 82mm
- brandnew on3 70mm turbo
- Low Mile G5X3
- 02 ebony leather seats front and back
- 6.0 non egr manifolds and 6.0 valve covers
- Granetelli lid w/ FRAM air filter
- SLP longtubes, loudmouth, and dual dual tips PICS ADDED!
- Progressive nitrous system
- WTB: Lower Air Box Assembly for 2001 Camaro Z28
- LT1 Long Block w/ 24x LS1 Conversion
- F/S LPE ported LS 317 heads, dual patriot spring kit and optional crane rocker kit
- Heavy Duty T56 Shift Forks
- Input shaft lt1 t56 tremec
- Updated: Summer Sales Event
- Pacesetter F-body 1 3/4" headers with race mufflers
- 243 heads with Patriot dual valve springs $500 shipped
- LS1 - 5.3L - 6.0L - 4.8L parts
- New SLP CAI for LT1 - SOLD!!
- Flowmaster catback - BNIB
- Weld ProStar 15"x10" - 7.5" backspacing - SOLD
- lsx turbo hotside
- wtb stock fuel sending unit
- Brand new (8) msd coils!!!
- L76 engine and T56
- Patriot Dual Gold Valve Springs/random parts
- 224/226 cam,circle d stall Fs
- Drag susp. partout Bmr, nitrous mount, ect...
- New PA K Member FS for ls1
- **PARTING OUT** 1998 LS1 4L60E Camaro Z28 Black
- F Body Oil Pan
- WTB=.650 springs
- Falken Azenis RT-615 315/30/18 almost new
- For Sale: .030 mahle pistons
- Wilwood 4 piston brake calipers
- MISC f body parts
- Weld Prostars
- comp lifters, pushrods, slp timing chain, oilpump in box
- 4500k 880 HID bulb
- FS: Comp Hardend Pushrods
- Valve springs single PSI LS 1511ML SOLD SOLD!!!!
- Ls1 oxygen sensor extensions and simulators
- Need***** ls3 and lq4 parts ls fox swap headers
- 42#svo green top injectors fs
- Interior, engine, springs, pedals, driveshaft, etc.
- MSD 8.5 plug wires 400 miles
- For Sale Comp Cams Double Roller Timing Set
- 99+ 411 pcm
- fs: Texas Giant camshaft
- 2" 3rd gen swap headers and exhaust
- Lingenfelter TRG-001 58x to 24x conversion box
- Super Victor Carb intake Modified for 4500
- Ls1 parts for sale
- SOLD SOLD ground factory f body rear brakes for 15 drag wheels
- Truck parts for sale
- Brand New in the box Manley LS1 H Beam rods
- LS3 / L92 Block Std Bore
- Gear Vendors Overdrive for th400. Add overdrive to you 3-speed!
- ford mustang brake parts 99-04
- Drive by wire dbw Tac module pedal and harness $110 shipped
- Stewart Components Ls1 Water pump (for use with GMPP front drive distributor)
- SLP Lid Amsoil Filter many other parts
- Meziere electric water pump EWP WP319
- 1993-2002 Front and Rear Pro Glass Non tinted NEW
- FS: LSX swapped mustang turbo hotside and turbo
- ***AEM trans temp...
- ***Hallman boost controller...
- 6speed pedals/xmember/2000 steering wheel/
- Direct Port Nitrous Setup
- ls6 408 stroker
- still have some good LT1 parts for sale CHEAP!
- 1998 - 2002 F-body Tick adjustable master cylinder
- street car part out
- 98-02 camaro rs/z28 oem ground effects! Piks and Prices Updated!!
- Power Steering Pulley
- 97-04 corvette, or 04-05 cts-v throttle body
- Fs fuddle 3800 stall
- Ls3 water pump. Brand new!
- Ls3 6.2 block. Brand new!
- Chrome ZR1s 17x9.5
- Pro charger J bracket from true tech performance
- 243 YELLOW SPRINGS low miles
- K&N FIPK ls1 $130 shipped!!
- ***Brand new 8.8 Detroit Locker with 4.10 gears***
- Cometic .040 ls1 head gasket!!
- SLP lid
- Brand New GM MLS Head Gaskets for LS1 (3.910 bore)
- Price dropped!! 64k miles complete ls1 engine fs
- Stock Rockers
- AFR 225 Heads
- S488 Borg Warner W race cover t6
- 2 Sets of QA1 Shocks and 3 Sets of 7.400 Pushrods
- Jesel Mohawk 1.8 rockers LS1/LS2/LS6
- TCI 2600 Stall
- Comp Cam 216/220, springs,pushrods
- LT1 Monoblade TB
- FS: NEW Morel/Lunati Roller Lifters
- T56 1-4 Dog Gear Set and Syncros
- 2000 LS1 Motor Mounts with Prothane mounts
- Parting Out: 99 SS Camaro
- NEW Manley Pro Series 4340 Stroker crank
- fbody parts left over demod sale
- 07 LS2 Bare Block, lower price
- FS: ARP 2000 Rod Bolts
- LS1/LS6 Prothane Motor Mounts
- Ported LS1 Throttle Body
- Manley Pro Series forged pistons New
- LS1 Intake Manifold without EGR
- LS6 Intake Manifold w/ Fuel Rails and Injectors
- F-Body Magnaflow Catback PN#16723
- Moser Axles and Moser 3.73 Gears
- 2000 Ebony M6 top console F/S
- C6 Fender Liners
- **LCA Relocation brackets BMR**
- Mallory HyFire VI (685)
- *SOLD* LS6 Coolant Crossover/Block Offs BRAND NEW
- 404ci shortblock,PRC stg3 317s,FAST 90/90 plus more!!
- Fs: Ls3 stock oem heads like new
- HSW 90mm plate
- HP Tuners Pro Unlimited 04 GTO Unlimited 02 Silverado and Sierra
- Flex-A-Lite Radiator
- Hotchkis springs
- Brand new LS1/LS2 harness w/411 pcm
- TNT F1 Wet Kit for Sale 75-150 HP Shot, LT1 Power Plate
- Brand New ZO6 heads/valley/valve covers
- black Zr1's with road race tires
- Hypertech power programmer 94 fbody
- 2002 Corvette Z06 Cam FS
- 00 a4 engine harness SOLD
- FS: 93-02 Fbody Eibach Front Sway Bar
- Valve springs AFR 8019
- FS: Kirkey Seat
- fs: strano springs
- WTB Stock Rear Coil Springs
- Total 10 Bolt Rebuild. Brand New!
- Misc Parts- Turbo/LS Parts
- LS1 Intake bolts, ls2 timing cover, water pump bolts,FAST 78mm Intake,tb
- Cleaning out the basement
- wtt original 17x9 zr1 wheels
- WTB: 2001 5.3 upgrades, list inside. Vendors welcome
- Paging LAMAR! Also have heat sink coils with harness and brackets
- Comp XER camshaft 224/228 112 + 2 0.581"/0.588"
- FS:Stock Rear shocks Decarbons, Stock Panhard Bar CHEAP
- LS T56 Muscle Car Conversion
- 02' Z06 15k LS6 heads with yellow springs, sodium valves
- WTB decent 98-02 roller or front clip
- SOLD Hotchkis rear lower control arms SOLD
- Precision PT88 turbo and blanket.
- AFR 205 heads
- Comp 226/222 turbo cam.
- SOLD SOLD Gorilla locking lug nut set ALL 20 locks
- Fs: Rare clear lid !!
- Bosch 220 lb Injectors Like NEW!
- Sold
- Tsp ory 3"
- LS 60lb injectors, HPTuners Pro, PRC 650 lift springs
- Torque Arm
- Interior Parts and OEM Modules w/ Pigtails For Sale
- OEM CTS-V 6 Lug Wheels Powder coated Satin Black
- K&N Air Filter
- for sale 243, 862 heads and ls6 block with rods and crank
- Chrome Zr1's, BBK TB and spacer, etc..
- Camaro partout on ebay
- C5 Parts
- WTT sn95 bullit 8.8 rear for foxbody 8.8
- For Sale: 03' Z06 Ls6 intake manifold and Shaner S2 TB
- LS1 Rear brakes
- **FS 2006 GTO PCM/ECU M6 Trans**
- QTPs, TNT, TH350, Yank, Misc...
- stock 5.3 engine parts- take offs
- SOLD t-56 6speed transmission
- New LS Gen III Gasket kit and covers
- Low mileage LS1 from '01 Vette with water damage.
- Yank SS3600 Converter Free Shipping No PayPal Fee's
- FS: Great condition 4l60e with bell housing and crossmember
- FS: (2) Mickey Thompson ET Street Drag Radial II 265/40/18
- Ls 408 shortblock callies/wiseco
- Camaro Seats and Head bolts
- Siemens 60lb fuel injectors EV6
- WTB ls7 lifters and more....DOD delete
- WTB mecham aero tail
- 4th gen parts 4/s
- 17x9.5 zr1's in chrome for sale with tires
- FS: Pro 5.0 (Shipped price)
- Circle D 6l80/90 Converter
- pin on glasstek hatch, comp eng shocks
- Camaro Wheels and ZR1 Caps FS!!!!!!
- Msd front mount distributor
- torsen limited slip 10 bolt 7.5" differential
- Stock LT1 parts F/S
- Misc '04 Corvette parts
- Snow Performance Stage 2 Boost Controller Meth kit $200
- 91mm 1500hp refresh rebuilt Garrett Turbo ONLY $750!!!
- G2 Springs, CE Rear Drag shocks, KYB adj struts, 22s for Trailblazer
- 120lb low imp Injectors for sale
- Gauging intrest in a vortech ls1 fbody aftercooler system
- Intercooler
- 02 Trans Am gauge cluster
- Crank Pinning Kit, BRAND NEW
- Gtech PRO
- FS: Comp billet turbo ball bearing
- ZR1 Rims
- LT1 SuperVIC with Custom Elbow
- Direct Injection Nitrous Kit (NXL)
- WTB ls1 t56 input shaft and front plate
- LT1 Hooker Y Pipe ORY POLISHED NEW
- LS6 Orange Stripe valves springs and PRO 5.0 short stick
- WTT 275# qa1s for 300# qa1s
- Fresh SPEC Stage 4 Clutch disk and Pressure plate
- Built 4L60E
- Genuine Bosch 36 lb injectors LS1 LS6 Trans Am Camaro
- ARP LS1 oil pan bolts FS
- Stock Truck Intake Manifold with Throttle Body (cable)
- Trans Am Plate Filler from a WS6
- 2008 LY6 6.0 Valve springs, retainers, locks, and pushrods. (SOLD)
- Matched set SBC pistons. Brand new in box! For .30 over 350. SpeedPro.
- rethreaded 03-04 cobra knob
- F-Body oil pan, pick-up, dipstick
- FS: Black w/ chrome lip torq thrust M 17x9 replica
- 2008 LY6 6.0 Balancer/crank pulley
- 2008 LY6 6.0 VVT cam, cam gear, timing cover, and LS3 tensioner
- 2008 LY6 6.0 exhaust manifolds, non EGR
- 2008 LY6 6.0 Truck oil pan, pickup, gasket and windage tray
- 2001 camaro ss 10 bolt
- NX kit, EFI, 15lb bottle! bottle heater! new
- LY6 6.0 to 4L80 flywheel (SOLD)
- 01 Trans Am T56 TRADE for 4l80
- Parting 04 GTO
